Maintaining VFR altitudes when following N/S roads/rivers
Old August 25th 08, 05:11 AM posted to rec.aviation.piloting
Wilhelm
Default Maintaining VFR altitudes when following N/S roads/rivers
"Morgans" wrote in message
"Bob F." wrote
Maybe I'm like the blind man touching the elephant here since I don't
have a lot of experience with him. So maybe I'll play along for a while
and see how it goes.
And the cycle continues, with different names, and different subjects, but
the same, never less.
Jim in NC
Not to mention the fact, you are probably arguing with Dudley.
Old August 26th 08, 05:02 PM posted to rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_25_]
"Morgans" wrote in :
while and see how it goes.
but the same, never less.
Yep, but with a bit of effort, you could change, you know.
Bertie
Old August 24th 08, 08:45 PM posted to rec.aviation.piloting
Lou wrote:
Why would you follow a road? If you want to follow a road, drive a
car.
VFR at night terrain avoidance.
To get from the LA basin to Chiraco Summit to see the Patton museum.
Jim Pennino
Remove .spam.sux to reply.
Old August 24th 08, 08:48 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Lou writes:
Pilotage. I try to practice different forms of navigation, and pilotage is a
useful type of navigation for VFR flights.
Old August 24th 08, 09:11 PM posted to rec.aviation.piloting,rec.aviation.student
Bob F.[_3_]
"Mxsmanic" wrote in message
Lou writes:
is a
This situation usually resolves itself.
If you are flying "pilotage" and at an altitude that the VFR cruising
altitudes applies, you will probably be picking out a ground reference many
miles away and cruise for some time before changing coarse. If you insist
on keeping you plane on the same coarse as the river or road then then you
are expected to follow the rule. If you are below 3000' agl, then the VFR
cruising rule doesn't apply.
Regards, Bob F.
Old August 25th 08, 12:32 AM posted to rec.aviation.piloting,rec.aviation.student
Dave S
then the VFR cruising rule doesn't apply.
Is that a US only rule or universal? They refer to lots of lower
altitudes as flight levels over there in Europe where mx is..
Old August 25th 08, 12:36 AM posted to rec.aviation.piloting,rec.aviation.student
Bob F.[_3_]
"Dave S" wrote in message
Is that a US only rule or universal? They refer to lots of lower altitudes
I can only reference FAR 91.159. Someone familiar with Europe will have to
answer that side.
Regards, Bob F.
Old August 25th 08, 02:07 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Dave S writes:
The rules vary elsewhere, but I "fly" only in the United States, since I know
the regulations there better, and they don't change every 300 miles, and I'm
more familiar with regions in the U.S.
The rules in France are stranger, and they change from country to country, and
Europe in general is very messy in this respect, so I just don't "fly" there.
If I were ever to get a pilot's license, it would be in the U.S. Since I
don't live in the U.S., that's one reason why I don't try to get a pilot's
license (but it's not the most important reason).
Anyway, back to the topic ... it's true that I can fly in the general
direction of a road instead of following it precisely, but I find that it's
easy to get so far away that it's hard to see the road any more. Some
Interstates will turn west for miles, and then turn east again, and so on.
They stay in one direction long enough to get away from you if you are trying
to keep an "average" heading, but if you turn you have to change altitude.
Climbing and descending 2000 feet every few minutes seems like a lot for a
small aircraft.
I haven't seen anything in the FARs that provides a way around this for cruise
flight, except, as Bob has pointed out, flying below 3000 AGL. That would
work well enough in Iowa, and then the problem is solved. But over hilly
terrain it gets more difficult, and also other rules come into play for
low-altitude flight, such as the need to respect limitations over congested
areas, wildlife preserves, etc.
So, I am open to suggestions, and I'd like to hear how other pilots (real or
virtual) deal with this.
Old August 25th 08, 02:15 AM posted to rec.aviation.piloting,rec.aviation.student
Wilhelm
know
I'm
You don't fly anywhere, you're nothing but a simmer flying a desk. If you
knew anything about the US regs, you wouldn't be asking the question.
Old August 25th 08, 02:23 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Wilhelm writes:
If you knew anything about the US regs, you wouldn't be asking the question.
I know a lot about the regulations, but perhaps you know more. In that case,
you can provide me with suggetsions.
Maintaining altitude Mxsmanic Piloting 45 May 20th 08 02:35 AM
if the genetic images can convict eerily, the chief farmer may hate more rivers Youssef Sadam Bin Duran Piloting 0 August 14th 07 12:47 AM
Maintaining currency/proficiency after getting my Instrument rating Gary Drescher Instrument Flight Rules 0 March 2nd 06 12:49 PM
Sun goes dark, rivers run red, Facetmobile webpage updated. Richard Riley Home Built 32 June 8th 04 09:02 PM
Secondary roads? D Grunloh Simulators 2 December 16th 03 02:04 PM
