Maintaining VFR altitudes when following N/S roads/rivers
Old August 26th 08, 04:59 PM posted to rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_25_]
Default Maintaining VFR altitudes when following N/S roads/rivers
"Wilhelm" luv2^fly99@cox.^net wrote in
"Mxsmanic" wrote in message
The rules vary elsewhere, but I "fly" only in the United States,
since I know
the regulations there better, and they don't change every 300 miles,
and I'm
more familiar with regions in the U.S.
You don't fly anywhere, you're nothing but a simmer flying a desk.
Neither do you, fjukkwit.
Bertie
Old August 25th 08, 02:17 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic wrote in
Dave S writes:
Is that a US only rule or universal? They refer to lots of lower
altitudes as flight levels over there in Europe where mx is..
You don't fly, period, fjukkkktard.
Bertie
Old August 25th 08, 02:35 AM posted to rec.aviation.piloting,rec.aviation.student
In rec.aviation.piloting Mxsmanic wrote:
Anyway, back to the topic ... it's true that I can fly in the general
direction of a road instead of following it precisely, but I find that it's
easy to get so far away that it's hard to see the road any more. Some
Interstates will turn west for miles, and then turn east again, and so on.
They stay in one direction long enough to get away from you if you are trying
to keep an "average" heading, but if you turn you have to change altitude.
Climbing and descending 2000 feet every few minutes seems like a lot for a
small aircraft.
You fly towards the point where the road meets the horizon, or more
likely, since the horizon is over 80 miles away at 4500 AGL, fades
into the haze, which since you specified VFR, will be at least 3
miles away.
This is trivial to do in a real airplane.
If you can't do it in simulation, the simulation is the problem.
Jim Pennino
Remove .spam.sux to reply.
Old August 25th 08, 02:50 AM posted to rec.aviation.piloting,rec.aviation.student
Bob F.[_3_]
it's
on.
trying
altitude.
a
small aircraft.
miles away.
Jim Pennino
Simulators have no problem handling this.
Regards, Bob F.
Old August 25th 08, 05:41 PM posted to rec.aviation.piloting,rec.aviation.student
Michael Ash
small aircraft.
Visibility must be really poor if you're doing this. I doubt an interstate
is making regular course changes of more than 90 degrees, so you should be
cutting the corners and seeing a maximum angle of 45 degrees to it. A few
minutes really shouldn't be taking you so far away from it that you can't
see it anymore. Even if you do get to where you can't see it, you're
presumably flying a course that will intersect it again soon, so you can
keep your position based on other landmarks until it heaves into view once
again.
I haven't seen anything in the FARs that provides a way around this for cruise
flight, except, as Bob has pointed out, flying below 3000 AGL. That would
work well enough in Iowa, and then the problem is solved. But over hilly
terrain it gets more difficult, and also other rules come into play for
low-altitude flight, such as the need to respect limitations over congested
areas, wildlife preserves, etc.
You could always try flying a glider instead. Nobody expects you to hold
any particular cruise altitudes there.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Dave S wrote in :
Bob F. wrote:
If you are below 3000' agl,
then the VFR cruising rule doesn't apply.
It's common in many parts of the world, but it's not universal. Th eBirts
use a quadtrantal rule, for instance, and in some countries th edivision
isn't N/S but E/W (Spain, for one, and Sweden has some funky rules too.
Bertie
Old August 24th 08, 11:52 PM posted to rec.aviation.piloting,rec.aviation.student
BT
What you are doing is not pilotage.
Fly a straight line based on compass and wind correction computations.
Time between visual points, towns, bridges, etc to compute ground speed.
Correct the heading slightly based on "observations" from pilotage.
just following a meandering river or road is not pilotage.
BT
Lou writes:
Why would you follow a road?
Pilotage. I try to practice different forms of navigation, and pilotage
is a
useful type of navigation for VFR flights.
Old August 25th 08, 12:12 AM posted to rec.aviation.piloting,rec.aviation.student
Jose Jimenez
But fun!
Old August 25th 08, 12:20 AM posted to rec.aviation.piloting,rec.aviation.student
Bob F.[_3_]
"BT" wrote in message
BT
Lou writes:
is a
What is it that makes you think he not practicing pilotage? What would you
call what he describes what he is doing? (reference please). We'll give you
a little time to read up on Pilotage, DR and Radio navigation and then you
can restate what you said.
Regards, Bob F.
Old August 25th 08, 01:26 AM posted to rec.aviation.piloting,rec.aviation.student
Michael Ash
My understanding is that you have just described dead reckoning with
occasional corrections coming from pilotage. Pure pilotage is simply
knowing where you are by looking out the window. When on the move, you
just keep looking out the window and keep updating your mental picture of
where you are. You may make mental estimates based on this of how long it
will be to get to the next landmark, but if you're doing actual
computation then you're beyond mere pilotage already.
Mike Ash
Radio Free Earth
Maintaining altitude Mxsmanic Piloting 45 May 20th 08 02:35 AM
if the genetic images can convict eerily, the chief farmer may hate more rivers Youssef Sadam Bin Duran Piloting 0 August 14th 07 12:47 AM
Maintaining currency/proficiency after getting my Instrument rating Gary Drescher Instrument Flight Rules 0 March 2nd 06 12:49 PM
Sun goes dark, rivers run red, Facetmobile webpage updated. Richard Riley Home Built 32 June 8th 04 09:02 PM
Secondary roads? D Grunloh Simulators 2 December 16th 03 02:04 PM
