Mxsmanic wrote:
Bob F. writes: How many hours had they flown elsewhere before they visited those large airports? Doesn't matter. Its "experimental". I could have a million hours on an airframe and it still be "experimental". |
On Aug 29, 12:55*pm, Mxsmanic wrote:
My impression is that many aircraft are called experimental in order to get around certain troublesome regulations. Your impression is wrong. You were wrong with your first response. Why don't you respond to that and say something like; "sorry, I was wrong?" How many hours had they flown elsewhere before they visited those large airports? You were wrong and typed a lie. Now you are hiding behind these new questions. Ricky |
"Mxsmanic" wrote in message
... By definition, experimental aircraft have unknown characteristics. It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. Experimental aircraft do not have "unknown characteristics" any more than any other aircraft such as certified and military aircraft which are routinely flight tested in heavily populated areas. |
On Aug 28, 6:27*pm, Mxsmanic wrote:
By definition, experimental aircraft have unknown characteristics. *It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. You are right about the initial tests which is why I will be using an airport with nice large fields at both ends and no population centers within a couple of miles. That was a choice that I could make but is not available to every homebuilder. Most of our airports have been surrounded by housing developments which greatly restrict operations including those for non-experimental aircraft. |
BobR wrote:
On Aug 28, 6:27 pm, Mxsmanic wrote: By definition, experimental aircraft have unknown characteristics. It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. You are right about the initial tests which is why I will be using an airport with nice large fields at both ends and no population centers within a couple of miles. That was a choice that I could make but is not available to every homebuilder. Most of our airports have been surrounded by housing developments which greatly restrict operations including those for non-experimental aircraft. I'm using a field that is out in the middle of a bunch of soybean and cotton fields, at least for the initial flights. It is well worth the extra drive. Stuff is likely to hit the fan, and I want to have more options than a subdivision. |
Mxsmanic wrote:
By definition, experimental aircraft have unknown characteristics. It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. I dont know where you get your definitions, but you just proved how much you DONT know... |
By definition, experimental aircraft have unknown characteristics. * Anthony, you are wrong once again. Tell us all, did you get this information from a reliable source? You claimed to get your "one must fly by instruments" info from a reliable source. I asked you several times to give the source information which you never did do. Anthony, you are a liar. How about that long-awaited source information which you so conveniently ignored? Will you ignore even this request and continue your string of false information? Ricky |
On Aug 28, 7:27*pm, Mxsmanic wrote:
By definition, experimental aircraft have unknown characteristics. *It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. I |
By definition, experimental aircraft have unknown characteristics. *It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. In the context of this discussion 'experimental' is a misnomer. Many, if not most homebuilt airplanes are classed by the FAA as 'experimental', even popular kitplanes of proven design. -- FF |
"Fred the Red Shirt" wrote in message
... On Aug 28, 7:27 pm, Mxsmanic wrote: By definition, experimental aircraft have unknown characteristics. It makes sense that you'd want to test them out away from heavily populated areas. Boeing and other civilian and military manufacturers don't test out their new designs at LAX. In the context of this discussion 'experimental' is a misnomer. Many, if not most homebuilt airplanes are classed by the FAA as 'experimental', even popular kitplanes of proven design. Even a certified factory aircraft may be reclassified as "experimental". |
Experimentals To Be Banned To Rural Airports? | T. \Tim\ Timothy Haag aka HyoogeUmp56[_2_] | Piloting | 214 | September 9th 08 11:02 PM |
Experimentals To Be Banned To Rural Airports? | T. \Tim\ Timothy Haag aka HyoogeUmp56[_3_] | Owning | 129 | September 9th 08 11:02 PM |
2nd cellphone for retrieve/rural areas US | chris | Soaring | 6 | May 4th 08 07:47 PM |
Red Arrows banned from olympics - British PC strikes again | stevehaley | Soaring | 13 | October 5th 07 07:01 PM |
Airshows should be banned...Now! | Tetherhorne P. Flutterblast | Military Aviation | 28 | June 15th 04 02:43 AM |
