contact terminology?
Old September 10th 08, 05:06 AM posted to rec.aviation.ifr
Mike[_22_]
Default contact terminology?
"Mxsmanic" wrote in message
Dave S writes:
Yes... YOU did....
Where?
TCAS uses at least one directional antenna. It is this antenna that
provides
azimuth information, independently of any equipment ATC might have. The
directional characteristic required for the antenna provides very low
azimuth
resolution, which means that bearing information on the TCAS display is
only
approximately accurate, unless the equipment substantially exceeds the
minimum
requirements for the system.
This is more or less correct. TCAS is also inaccurate in range compared to
a ground based sensor.
Air Traffic/Pilot Terminology [email protected] Piloting 32 July 24th 07 10:25 AM
VFR terminology in Class B Matt Piloting 17 February 27th 07 03:55 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
New Aviation Terminology DeltaDeltaDelta Piloting 45 December 4th 03 08:31 AM
Humour: CO DATA PAGE TERMINOLOGY CAT:BTN SUB:DES PGE:TRM Dave Kearton Military Aviation 0 September 24th 03 10:38 AM
