"Arie Kazachin" wrote
If memory serves, that was the reason that SR-71 had been returned to service few years before being retired finally (at least, so far): sats were not flexible enough (remember, you can't refuel them and changing orbit takes LOTS of fuel). It was forced on the USAF by Congress. The USAF wanted to spend the money on more important stuff (like dormitories to get the enlisted troops off the economy, and off of welfare). You may not be aware, but most recce sats are nuclear powered, and the fuel to scoot them around does not have to be combustible. |
![]() "Gene Storey" wrote in message news:B0qFb.3428$6l1.2442@okepread03... "Arie Kazachin" wrote If memory serves, that was the reason that SR-71 had been returned to service few years before being retired finally (at least, so far): sats were not flexible enough (remember, you can't refuel them and changing orbit takes LOTS of fuel). It was forced on the USAF by Congress. The USAF wanted to spend the money on more important stuff (like dormitories to get the enlisted troops off the economy, and off of welfare). You may not be aware, but most recce sats are nuclear powered, and the fuel to scoot them around does not have to be combustible. Eh? While the use of nuclear power cells in satellites is not unheard of, I don't think any of our satellites are using any kind of nuclear-ion propulsion, and that the intel sats do indeed rely upon goo old fashioned liquid rocket fuels. Brooks |
![]() "Gene Storey" wrote in message news:B0qFb.3428$6l1.2442@okepread03... You may not be aware, but most recce sats are nuclear powered, and the fuel to scoot them around does not have to be combustible. I think your mixing two different power needs. If the birds are carrying nuclear powered energy cells that's simply for the electrical circuits. To move a satellite requires propellant (and it had better NOT be combustible) that once used cannot be renewed. Move the bird too much it becomes a paperweight. |
"Arie Kazachin" wrote If memory serves, that was the reason that SR-71 had been returned to service few years before being retired finally (at least, so far): sats were not flexible enough (remember, you can't refuel them and changing orbit takes LOTS of fuel). It was forced on the USAF by Congress. The USAF wanted to spend the money on more important stuff (like dormitories to get the enlisted troops off the economy, and off of welfare). You may not be aware, but most recce sats are nuclear powered, and the fuel to scoot them around does not have to be combustible. I do not know of any nuclear power _propulsion_ systems in present use. Even if there were, it would still have to throw something away from the vehicle to get momentum which means eventually it woudl run out of whatever it was throwing away. Even a cursory understanding of physics would lead you to conclude that satellite-based recon is scheduled for when the vehicle will pass over the target, and satellites are not manouvered on a target by target basis. Manouvering is done for station keeping, that is to keep the vehicle in it's desired orbit. For a narrow FOV instrument one presuems that attitude control will be used to capture the right target area when passing close enough. My experience is with civilian satellites, or rather with joint civilian/DOD vehicles like GEOSAT, but physics is physics. -- FF |
![]() "R420" wrote in message om... I for one think that the SR-71 has not only been replaced, but its replacement has been replaced. in other words, there have probably been two generations of ultra-fast spy planes beyond the SR-71. The SR-71 was made in the 60s. probably by the late 70s or early 80s, a sucessor to SR-71 was flying. and by now, the sucessor to the SR-71's sucessor has, at least been tested, if not put into service. OK, so now tell us what the successors were. You DO know that, right? |
"Ragnar" wrote in message ...
"R420" wrote in message om... I for one think that the SR-71 has not only been replaced, but its replacement has been replaced. in other words, there have probably been two generations of ultra-fast spy planes beyond the SR-71. The SR-71 was made in the 60s. probably by the late 70s or early 80s, a sucessor to SR-71 was flying. and by now, the sucessor to the SR-71's sucessor has, at least been tested, if not put into service. OK, so now tell us what the successors were. You DO know that, right? I find this topic fascinating; however, I don't believe that we have yet fielded a second generation replacement for the old SR-71 bird. My personal belief is that a number of technology demonstrators were probably tested from the late 1970s forward and that all the Aurora hype is probably unjustified as that program(s) was/were most likely cancelled in transition from manned recon to unmanned systems like high-res spy satellites and loitering UAVs. However, maybe in the 1990s someone decided to play it safe with a manned aircraft as well (keeping humans in the loop). The NRO must have some form of aircraft operating under its agency and for argument sake let's just say that it is probably the often talked about GENERAL-DYNAMICS F-121 Sentinel, a.k.a "Centennial" now speculated as LOCKHEED-MARTIN SR-100. There are so many post SR-71 designations: SR-75, 84, 86, 89, and 100. Who can tell which, if any, are true? The multiple agencies involved should someday soon divulge this information so we all can move on. Ashton Archer III |
"R420" wrote in message om... I for one think that the SR-71 has not only been replaced, but its replacement has been replaced. in other words, there have probably been two generations of ultra-fast spy planes beyond the SR-71. The SR-71 was made in the 60s. probably by the late 70s or early 80s, a sucessor to SR-71 was flying. and by now, the sucessor to the SR-71's sucessor has, at least been tested, if not put into service. OK, so now tell us what the successors were. You DO know that, right? Oh Oh! _I_ know! Aurora. -- FF |
