757 avionics
Old October 3rd 08, 05:13 PM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Bertie the Bunyip[_28_]
Default 757 avionics
FriarTuck wrote in
some questions if anyone knows the answers...
is 757 fly by wire or fly by cable?
Neither
The FMCS has full flight and landing capability, is it a separate
control system?
It can autland but it's seperate from the flight controls. You can
disengage it anytime you like.
It fails passive, which means you can manually oer-ride any time you
want.
The FANS network, is it capable of directing "goto location/altitude"
and "set airspeed to K" type commands to the plane?
Doesn't have one
Is the yoke and throttle a completely separate control system from the
FMCS control system or are they common?
seperate
is the throttle control in cockpit only routed through FMCS ?
No
I read that the yoke was capable of exerting more power on the
surfaces than the FMCS could, essentially giving yoke priority, is
that correct? If so can you describe how that works?
The stick will give more authority because the autopiot flies the
airplane in a more limited way than a pilot would. When it intercepts an
altitude, it does so smoothly with a limited G. A pilot can manuever the
airplane as abruptly as he likes, but of course, most do so just as
smoothly as the autopilot does.
Sometimes the autopilot isn't quite so smooth. If it gets "surprised" by
a track interception, for instance, it will be a bit jerky in roll, or
if it gets surprised by a pitch intercept it wasn't expecting and the
autothrottle gets a bit out of step it will pitch a bit harshly. Ridig
as a passenger this sort of thing is often felt in the back and mistaken
for hand flying.
Bertie
Old October 3rd 08, 07:23 PM posted to aus.aviation,rec.aviation.piloting
Neither
control system?
want.
Doesn't have one
seperate
No
that correct? *If so can you describe how that works?
for hand flying.
Bertie
Thankyou. Very informative.
At the risk of filling your forum with kookery - Speaking as someone
who seems to have experienced these things, do you think that, once
getting in the general area using the autopilot, Hani Hanjour (or even
Friar Tuck or myself - a low hours, head-up-arse PPL) could have
performed a 360 degree turn, pointed it at the Pentagon, and smacked
into it?
Old October 3rd 08, 07:49 PM posted to aus.aviation,rec.aviation.piloting
wrote in
FriarTuck wrote
s2:
Neither
control system?
want.
location/altitude" and "set airspeed to K" type commands to the
plane?
Doesn't have one
the FMCS control system or are they common?
seperate
No
an altitude, it does so smoothly with a limited G. A pilot can
manuever the airplane as abruptly as he likes, but of course, most do
so just as smoothly as the autopilot does.
by a track interception, for instance, it will be a bit jerky in
roll, or if it gets surprised by a pitch intercept it wasn't
expecting and the autothrottle gets a bit out of step it will pitch a
bit harshly. Ridig as a passenger this sort of thing is often felt in
the back and mistaken for hand flying.
Bertie
into it?
Yep
Bertie
Old October 4th 08, 12:52 AM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
FriarTuck
On Fri, 03 Oct 2008 16:13:16 +0000, Bertie the Bunyip wrote:
FriarTuck wrote in
Neither
you contradict yourself again and say its fly by wire to parris_k... why
is that?
control system?
want.
Doesn't have one
seperate
but you contradict yourself in another reply and say its shared, you say
the fmcs uses the same controls as yoke...
No
I read that the yoke was capable of exerting more power on the surfaces
than the FMCS could, essentially giving yoke priority, is that correct?
so if autopilot/fmcs could not be switched off then the pilot has no way
of over-riding the controls?
for hand flying.
Bertie
Old October 4th 08, 07:32 PM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
FriarTuck wrote in :
FriarTuck wrote in
Neither
is that?
Apparently it's because
A, you can't read
B. you're a conspirawhacko
C. all of the above.
Take your pick.
Bertie===
Old October 6th 08, 09:48 AM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
FriarTuck wrote in
Neither
No, he didn't. He said, over and over again, that it WASN'T fly by
wire. You're simply too stupid to understand what you are being told.
You ****ing braindead kook-sucker
Old October 4th 08, 01:52 PM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
Capt. Geoffrey Thorpe
"FriarTuck" wrote in message
Your best bet is to talk directly to one of our experts on using flight
computers and autopilots:
Geoff
Old October 4th 08, 07:33 PM posted to aus.aviation,rec.aviation.military,rec.aviation.piloting,rec.aviation.student
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in
That's just mean.
Bertie
Avionics Help Aero Dana Piloting 9 February 11th 06 04:08 AM
Used Avionics Jon Kraus Owning 18 October 18th 05 09:59 PM
Ew Avionics Jean-Paul BERRY Soaring 1 March 8th 05 10:37 AM
Used Avionics O. Sami Saydjari Instrument Flight Rules 40 December 2nd 03 02:53 PM
F-8 avionics Zajcevi Military Aviation 0 August 20th 03 11:00 PM
