Drew Dalgleish wrote:
I used to just glue balsa fins and nose right onto the rocket engine. I also made a hand held launcher for non-vertical deployment ![]() I Wish I had of thought of using the engine to light firecrackers a cherry bomb would make a great finish to a flight. Back when I was a kid, model rocket engines were hard to come by, now they can be mail ordered. It's the firecrackers that are hard to come by these days or at least in socialist Oregon. Tony |
In article , Dan wrote:
Tech Support wrote: On Mon, 06 Oct 2008 21:55:27 -0500, Dan wrote: Tech Support wrote: On Mon, 06 Oct 2008 16:01:02 -0500, Dan wrote: Paul Dow (Remove Caps in mail address) wrote: Hello Walter, Thank you for that link. I wasn't aware that it is on the web. My friend didn't have the parts manual. He does have the 6 cylinder model, so that information should be very useful to us. Also, it looks like your posting did appear in the newsgroup. I think some newsgroup servers don't update very quickly. It looks like the messages on the newsgroup have migrated to a discussion about explosives now :-) Paul You say that like it's a bad thing. Explosives can come in handy. Example your starter dies, hand propping isn't working and you want to crank the engine, just remove a spark plug, put a handful of black powder in the cylinder, insert fuse and rag to act as a plug, light fuse and hop in. Explosives can also be used for emergency tire inflation. Dan, U.S. Air Force, retired ********************************************** Dan Why can't you put in cylinder and use plug to light off???? Big John I'm assuming the think won't turn over in the first place. If it can be turned enough to obtain a spark one can add saltpeter, sulfur, aluminum powder and confectioner's sugar in the proper proportions if one is out of black powder. Not that I know anything about the particulars, you understand. Dan, U.S. Air Force, retired ************************************************** ************************* Dan As a teenager I used potasum clorate and sulpher. Poured a spot on cement and kicked with heel plate and went off. Also put in a CO2 cartridge and set off with home made fuse. Made a powerful rocket (half a city block). How I ever survived growing up I don't know looking back. Big John Looking back I can see several occasions where I should have been injured or killed with some things I did. I proved launching a plastic model Saturn V is possible with off the shelf C engines. I also proved that didn't include going in the intended direction. There was also the day the WAC Corporal got it's engine inserted _backwards_. Hit the igniter, and "fffttt!!" the spurt from the ejection charge _was_ enough to lift it off the launcher, and it coasted straight up to about 15-20 ft in the air on the delay. *Then* the main part of the engine lit off. Stopped dead in the air and simply _shriveled_ into this oblong charcoal ash, that sort of fell/drifted back to the ground. After one got through the crying over the destruction, the memory was good for some (bittersweet) laughs. |
How to Remove Piston from Cylinder | Paul Dow (Remove Caps in mail address) | Owning | 20 | October 6th 08 10:01 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 8 | May 27th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Jim Burns[_3_] | Owning | 2 | May 24th 07 05:26 AM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Piloting | 0 | May 23rd 07 10:44 PM |
Oil in cylinder, other cylinder issues | Robert M. Gary | Owning | 0 | May 23rd 07 10:44 PM |
