On Oct 20, 5:45*pm, wrote:
On Oct 20, 6:43*am, flybynightkarmarepair wrote: RE the Ercoupe example: I don't like header tanks from a crash safety standpoint, and another vent, and a return line souunds like MORE plumbing to me. *Plus, this is a VW conversion, and if I used a mechanical fuel pump it would be on the TOP of the engine, plus they are not sealed like aircraft mechanical fuel pumps are, so this is a no-go. The Ercoupe design has worked safely and well for over fifty years. The lack of a header tank does not guarantee crash safety - nor does it's presence necessarily increase the danger. I've read an accident report where 2 POB died in an otherwise survivable Ercoupe crash due to the fuel tank splitting and soaking them in gas. Ignition happened, and they became human wicks. Others have noted ways of mitigating this via fuel cells, and while you make a pretty good argument, I'm not convinced. Fred Weick, the designer of the Ercoupe (although perhaps not this part of it...) also had significant input to the most numerous low wing production design, the Piper Cherokee, and it DOES NOT use a header tank. Strictly circumstantial, to be sure, but draw your own conclusions. The one pump in that design can either be mechanical or electric, it matters not. There are no vents involved in the design. The float gauge holes in the caps provide adequate venting. If you are forced to park outside in the rain, you simply put a cap over the cap. I don't like this at all. I don't like relying on the nut between the headphones to keep me safe from a significant hazard (water in the gas) in an airplane with as small a fuel capacity as the one I'm building. I want a screened vent of at least 3/8 in. dia. that exits the BOTTOM of the wing, but vents the TOP of the tank. There is one line connecting the two tanks which are located at the wing roots. If one wing is parked, or flown, a little low it makes no difference. There is a tee in the line that leads to the inlet of the pump. I recall a LONG argument on this forum (or maybe it was on a Zenith 601 forum - LOTS of that design fly with a system VERY much like you're advocating) about unporting a tank at low fuel levels and sucking air, that I don't want to rehash, but I'll just note that I'm firmly in the LEFT/RIGHT/OFF fuel selector camp for low wing planes with wing tanks. Gravity flow to a carburated engine is the safest and most reliable fuel feed possible, I agree, I agree, to the extent that I'd rather build a high wing airplane if plans for one that meets my mission requirements were available when I was first looking. The Aerosport Quail is the only HIGH wing all metal VW powered single place homebuilt aircraft I'm aware of, and it's not clear you can actually get plans, although a source iin Oregon is rumored. For a low wing plane with fuel in the wings, which I'm well convinced is safer than fuel in the fuselage, pumps are a necessary evil, and since they can fail, I'll take two please. William Wynne has done more engine installations by far than I have, and he's going this way; so am I. ================================================== ============ Anybody have anything to say about the fittings? That was my initial interest. Should I ditch the pumps I have and just bite the bullet and go with AN fittings per the exemplar? Do all those unions make sense?(heavy little suckers! Think of a ball of solid brass the diameter of a quarter for the 1/8" NPT size, and the diameter of a Susan B. Anthony dollar for the 1/4" NPT size, and they lighten the wallet to the tune of $13-20 per at the same time they increase empty weight) - given that NPT fittings don't seal anyway metal-to-metal, and you can "clock" them with SOME degree of freedom as long as they're at least slightly more than finger tight, relying on Loctite Pipe Sealant to keep them leak free? |
Survivable Ercoupe crashes where the occupant(s) burned to death (NTSB
Identifiers, no more static URLs for crash reports): SEA00LA136 NYC98FA107 CHI96FA034 Not clear this one was survivable, absent the fire MKC82FCG17 Pilot lived a few weeks, died of burns. NYC85FA222 "water and sludge throughout the fuel system" This IS not to conclude the Ercoupe is unsafe. Reading accident reports is always instructive and sobering, but it would take more analysis than I have time or energy for on a school night to reach solid conclusions. Drunks seem to be drawn to Ercoupes is one extremely shaky conclusion drawn from my reading of 50 fatal accidents since 1962, out of 482 accidents in the same time period. |
On Oct 20, 11:55 pm, flybynightkarmarepair wrote:
Anybody have anything to say about the fittings? That was my initial interest. Should I ditch the pumps I have and just bite the bullet and go with AN fittings per the exemplar? Do all those unions make sense?(heavy little suckers! Think of a ball of solid brass the diameter of a quarter for the 1/8" NPT size, and the diameter of a Susan B. Anthony dollar for the 1/4" NPT size, and they lighten the wallet to the tune of $13-20 per at the same time they increase empty weight) - given that NPT fittings don't seal anyway metal-to-metal, and you can "clock" them with SOME degree of freedom as long as they're at least slightly more than finger tight, relying on Loctite Pipe Sealant to keep them leak free? AN fittings are available in aluminum. They weigh almost nothing. Look for the blue fittings. But watch when you thjread an aluminum pipe thread into another aluminum fitting or tank boss; they'll grab and gall and tear the threads apart if you don't use some decent sealant. We use Seal-Lube, Permatex Aviation Form-A-Gasket, sometimes Loctite hydraulic sealant. Stay away from teflon tape. Dan |
On Oct 20, 10:55*pm, flybynightkarmarepair wrote:
(snip) I recall a LONG argument on this forum *(or maybe it was on a Zenith 601 forum - LOTS of that design fly with a system VERY much like you're advocating) about unporting a tank at low fuel levels and sucking air, that I don't want to rehash, but I'll just note that I'm firmly in the LEFT/RIGHT/OFF fuel selector camp for low wing planes with wing tanks. Just one more word on the subject and I'll go back to lurk around. Since the Ercoupe design feeds the engine from the header tank, unporting of a wing tank may momentarily interrupt the replenishment of the header tank - but will not interrupt fuel flow to the engine. Indeed, when the wing tank(s) are empty, the fuel pump is just suckin' air. No harm, no foul. I remember when I was young and stupid (as opposed to now being old and senile), I left Buchanan Field - Concord, CA just North of S.F. and headed south in a '46 Ercoupe. It took 30 minutes to climb to 9.5K as I remember and we had a nice north tailwind. As we neared Los Angeles the cork float gauge on the header tank was on it's way down. I had a sectional on my lap and was going to fly the freeways down to Fullerton airport. Should make it easy. Hah! We hit the smog and horizontal visibility went to zilch. I could see straight down, so I followed the concrete. Then we came to an interchange. Do you know how many frippin' freeways there are in L.A.!!! I was so lost I couldn't find my butt with both hands. After 10 - 15 minutes of screwing around, I called L.A. Approach and confessed. Note: This was way before transponders were common in civil aircraft. They came right back with no help at all. Advised me to fly west until I saw water IIRC. All of a sudden, there it was. Disneyland! I turned the map around until it was right and decided the nearest airport was only a couple of miles in front of me. Trouble being, it was a Naval Air Station. I told LAX I was going to land there and they advised me that I would never take off again. They were able to give me vectors to Fullerton and I turned that way. The float gauge was no longer bobbing - it just sat still. I figured the engine could quit any second. In less the five minutes it seemed, we were approaching Fullerton. I called the tower, advised low fuel, was told to enter downwind and I was #15 to land. "Did I want to declare an emergency?" Thinking of the reams of paperwork sure to follow, I gulped, "Not at this time." We finally kissed the pavement and even taxiied off to the FBO. Fueling up, I paid for just 1/10th gallon less than the usable capacity of the three tanks. I never let the fuel get nearly that low again. Later in that same trip, we flew North into the Grand Canyon and then couldn't climb back up and out over the North Rim. But that's another story. Rich S. |
On Oct 21, 12:29*pm, wrote:
On Oct 20, 10:55*pm, flybynightkarmarepair wrote: (snip) I recall a LONG argument on this forum *(or maybe it was on a Zenith 601 forum - LOTS of that design fly with a system VERY much like you're advocating) about unporting a tank at low fuel levels and sucking air, that I don't want to rehash, but I'll just note that I'm firmly in the LEFT/RIGHT/OFF fuel selector camp for low wing planes with wing tanks. Just one more word on the subject and I'll go back to lurk around. Since the Ercoupe design feeds the engine from the header tank, unporting of a wing tank may momentarily interrupt the replenishment of the header tank - but will not interrupt fuel flow to the engine. Indeed, when the wing tank(s) are empty, the fuel pump is just suckin' air. No harm, no foul. Really good point. You and Veeduber may have convinced me to try a Header Tank solution, and FIND room for it. My gripe then will be No Pressurized Fuel in the Cockpit, but I think I can work my way around that by having the header tank VERY close to the firewall (maybe even in front of it...), with the pump, the gasolator, and most of the fittings ahead of the firewall. The next question becomes, how small can I reasonable go in the header tank? I'm thinking that for an engine that burns, at most, 4 gallons per hour, a gallon USABLE might be enough. I remember when I was young and stupid (as opposed to now being old and senile), Great story, I particularly enjoyed it as I know both areas well. Later in that same trip, we flew North into the Grand Canyon and then couldn't climb back up and out over the North Rim. But that's another story. Oh do tell! Either give it to us here, or e-mail it to me and I'll post it on my blog or on my website. Rich S. My sincere thanks for all the comments thusfar, yours, Dan's, Veeduber's, all y'all. |
This ain't rocket science and you aren't building a space shuttle. Gravity flow to a carburated engine is the safest and most reliable fuel feed possible, until you are attacked by Feherenghi using anti-grav phasers. ------------------------------------------------------------------- Agree. As with most engines, the VW fuel pump is driven at cam speed but it is NOT driven off the cam shaft, a significant difference with regard to its mechanical durability. It is driven off the crankshaft via its own gear-train. The pump is a two-chamber type in which the mechanical input serves only to extend a compression spring. The spring is then free to retract, the amount of retraction determined by the quantity of fuel drawing into the lower chamber during the extension cycle. In effect, the pumping action is performed by the spring rather than by the engine. Mechanically, the pump is isolated from the engine by a push-rod that is actuated by a pinion gear. The flexible diaphragm that makes up the floor of the lower pumping chamber has a useful service life in excess of 1000 hours, the push-rod slightly more than that. Output pressure is typically between 8 and 16 ounces, depending on the spring. Any flow-control valve, such as the ball-valve in the stock Solex carburetor, which typically has a pressure between 8 ounces and two pounds is sufficient to shut off delivery. However, any fracture- failure in the delivery circuit will cause the pump to spray gasoline in all directions. Wear in the push-rod is reflected by its length which may be meausred by removing the pump (two studs). Volkswagen provided three pump push-rods of different lengths. Failure of the flexible diaphragm offers a bit of visual warning in the seepage of fuel at the parting line of the pump. This is only valid for the early model, rebuildable fuel pumps, which is what I prefer to use on my VEHICLES. In an airplane I'm more comfortable with a gravity-fed system, even if that includes a header tank in the fuselage. The push-rod actuates a bell-crank in the base of the pump body, which is a white-metal casting. The bell-crank's pivot bears on the casting without provision of bushings or bearings. In a high-time pump it is common to see the bearing-holes worn to an oval. The pivot itself is held in place by a cotter key (early) or snap-ring (late) which is also subject to wear. The pallet of the bell crank calls for periodic lubrication with axle grease, maintenance it seldom sees when the vehicle is maintained by the typical owner. (I believe the service interval was every 12,000 miles or annually but I'd have to check the Factory Service Manual. I do it about once a year and have never had a mechanical failure due to lack of lubrication. I have had the pivot and the fastener break.) In my opinion, each builder is responsible for answering such questions for themselves. I can offer an opinion and may provide an example to support it but ultimately, that's the limit of my interest and responsibility; I can always refuse to ride in the thing. (And have, on several occasions.) Personally, I don't care for pumps and would eliminate them if possible, especially if they are engine- driven. The next best choice would be an electrically driven pump (or any number of them) located where a failure would not douse the engine with gasoline. Even so, at best all this would do is reduce the risk of an IN-FLIGHT fire. Following a crash or bad landing, there is usually some amount of fuel at the scene regardless of where the fuel tank is located and no matter how the fuel is delivered to the engine. -Bob Hoover |
AeroStar Fuel system? | Al G[_1_] | Owning | 12 | November 27th 07 04:36 PM |
AeroStar Fuel system? | Al G[_1_] | Piloting | 0 | November 12th 07 04:53 PM |
Troubleshooting the Comanche fuel system | Thomas | Owning | 9 | March 28th 06 11:07 AM |
Shadin's Fuel Flow Management System | Tom Alton | Products | 0 | September 1st 04 06:07 PM |
Pawnee fuel system leak | Rod Pool | Soaring | 0 | August 12th 04 04:29 AM |
