On Fri, 31 Oct 2008 12:09:27 -0700, Alan Baker
wrote: The one thing not quite right is that there is no important difference between tractor vs. pusher configurations with respect to directional stability. Like some of the early rocket designers (e.g. Goddard), you are falling into the fallacy that somehow pulling is more stable than pushing. This is not so. Pusher or tractor makes virtually no difference, but the vast majority of pilon mounted engines ARE pushers - and the pilon mounted engine does have that nasty quirk. |
"Gregory Hall" wrote: France? I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the win[g] with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Sort of like a Taylorcraft or Cessna 140 or similar small aircraft. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement .... Placed the thrust line enough above the center of drag that adding power caused a downward pitch moment, and reducing power resulted in a upward pitch. and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. Which is what the horizontal stab/stabilator is for. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. Except for the Legacy not incorporating those design elements that result in the pitch/power response of the Rotec Rally. The Rally needs a lot of upward pitch dialed in for level cruise (which ought to be contributing a lot of drag as an added bonus), giving you some nasty response to losing power. In particular, both thrust and drag components in the Legacy are much closer in alignment, resulting in much less pitch change when power changes. The two aircraft behave very differently in many aspects, and the Legacy not much at all as you've asserted. |
![]() "Steve Hix" wrote in message ... In article , "Gregory Hall" wrote: France? I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the win[g] with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Sort of like a Taylorcraft or Cessna 140 or similar small aircraft. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement ... Placed the thrust line enough above the center of drag that adding power caused a downward pitch moment, and reducing power resulted in a upward pitch. and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. Which is what the horizontal stab/stabilator is for. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. Except for the Legacy not incorporating those design elements that result in the pitch/power response of the Rotec Rally. The Rally needs a lot of upward pitch dialed in for level cruise (which ought to be contributing a lot of drag as an added bonus), giving you some nasty response to losing power. In particular, both thrust and drag components in the Legacy are much closer in alignment, resulting in much less pitch change when power changes. The two aircraft behave very differently in many aspects, and the Legacy not much at all as you've asserted. Thanks guys. I think I understand the differences now. The part about the forces being in better alignment makes sense to me and pusher vs. puller. I'll have to retract my ill-conceived statements about the Legacy. By bad! -- Gregory Hall |
"Gregory Hall" wrote: "Vaughn Simon" wrote in message ... "Gregory Hall" wrote in message ... It looks too much like an irresponsible, hot rod, stunt plane to me. Well, you sucked me in at first, so on a troll scale of zero-to-10 you rate at least a five. How are things in France? Vaughn France? I don't live in France. I built and used to fly a Rotec Rally 2B many years ago. It was a tail dragger with a high wing and the motor was mounted atop the wind with a pusher prop. When I got it trimmed out correctly at cruise speeds I could lean forward in the seat to nose it down and lean back in the seat to nose it up. Even as well-balanced as it was at about half throttle, when the engine quit it would pitch up immediately and drastically because the high engine placement and pusher prop had enough leverage so that the proper trim at the tail counteracted the nose down force of the engine and prop. If you didn't immediately push the stick way forward when the engine quit it was a matter of seconds before it would nose up fast and stall and then you would have no control at all from the stick until it fell for a while and the nose dropped (thank god for that) so you could gain speed provided you had enough altitude to get control of it again. But it didn't glide too well being a single surface wing with wire bracing. Perhaps 2:1 glide ratio. But it was easy to land with no power but you had to come in hot and steep and at the last second pull back on the stick and flare it. It looks to me like the Legacy would act pretty much the same if the engine quit. Greg, What was happening to you was not caused by the *weight* of the engine, but the change from higher than CoM thrust creating a pitch down torque, to higher than CoM drag creating a pitch up torque. Congratulations: you've just rediscovered one disadvantage of having a thrust line that doesn't go through the centre of mass. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Shaw Flaw | The Old Guy | Aviation Photos | 0 | September 16th 08 05:18 AM |
Lancair Legacy | Joaquin | Home Built | 22 | November 13th 06 09:06 AM |
BWB has finished his Lancair Legacy... | John Ammeter | Home Built | 1 | June 6th 06 04:11 AM |
Lancair Legacy 2000 | Randy L. | Simulators | 6 | October 9th 03 09:56 PM |
