On Tue, 25 Nov 2008 09:19:01 -0800 (PST), Oliver Arend
wrote: This may sound like a stupid question; I realize the prop can only turn at a certain speed to avoid transonic effects at the tips and has to be turned with a certain torque to transmit the power needed/ produce enough thrust. So far so good. But why does the torque have to be produced by the engine in direct drive? Couldn't weight and space be saved by using a high-revving, small displacement engine (such as a car or even motorcycle engine) with a reduction gearbox? I'm aware that a reduction gearbox will add weight (but not that much?), complexity and failure modes, and that transmitting the forces created by the prop to the airframe could be an issue. Does it boil down to the price? Is a Lycosaur engine cheaper than, say, a motorcycle engine of equivalent power plus the gearbox? Thanks in advance for enlightening me, Oliver It is done often in the ultralite world - but gear drives add complexity. If a plane doesn't have a particular part it can't fail - so the large displacement, slow turning torque machines still win. Lycoming has made several geared engines over the years and none has been particularly successfull. I believe the Merlin (or one of the big "V" engines) was also geared. The most common geared aircraft engine today is the Rotax 912 series. |
On Nov 25, 7:47 pm, wrote:
Lycoming has made several geared engines over the years and none has been particularly successfull. I believe the Merlin (or one of the big "V" engines) was also geared. Both the Merlin and Allison V-12s were geared. And most of the big radials were geared. It was one of the few ways to get more horsepower out of a given displacement. R-1830 radial cutaway, with gears in the front of the case: http://aviatechno.free.fr/vilgenis/i...830_02_730.jpg Merlin cutaway: http://www.thunderboats.org/history/...tory0324_1.jpg Common geared Lycs: GO-435 and GO-480. Continental had the GO-300 and GTSIO-520. Daimler Benz DB601a: http://www.aviation-history.com/engines/db601a-1.jpg Geared engines are nothing new at all. Dan |
On Nov 25, 8:29*pm, wrote:
On Nov 25, 7:47 pm, wrote: Lycoming has made several geared engines over the years and none has been particularly successfull. I believe the Merlin *(or one of the big "V" engines) was also geared. * * * *Both the Merlin and Allison V-12s were geared. And most of the big radials were geared. It was one of the few ways to get more horsepower out of a given displacement. R-1830 radial cutaway, with gears in the front of the case:http://aviatechno.free.fr/vilgenis/i...830_02_730.jpg Merlin cutaway:http://www.thunderboats.org/history/...tory0324_1.jpg Common geared Lycs: GO-435 and GO-480. Continental had the GO-300 and GTSIO-520. Daimler Benz DB601a:http://www.aviation-history.com/engines/db601a-1.jpg * * * * Geared engines are nothing new at all. * * * *Dan One of the reasons that converting an auto engine by adding a PRSU is complicated is that auto engine bearings are not designed for thrust or side loads. The rear bearing of an auto engine in a car just sees torque loads. The PRSU has to be coupled to the crank in the same way as an auto transmission which means that the small gear or pulley has to 'float' on its own bearing and couple to the engine's flywheel through something like a flex coupling. Geared radial and a few in-line engines used a planetary gearsets. This is easier since the "sun gear" sees no thrust or side loads. The "ring gear" sees all those loads. |
On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm"
wrote: IIRC, snowmobiles are/were derived from chain saws--which required an engine light enough for a man to carry and use as a hand held tool. That made them an obvious choice for another application were light weight was the most critical factor--even at the cost of reliability and maintenance intervals... I've never heard that, seems unlikely... they are really very different, except for both (along with outboard motors) being 2-strokes. All for the same reason of light weight. -Dana -- If you glue a piece of toast, butter side up, to your cat's back, and drop it from a high place, which way will it land? |
"Dana M. Hague" wrote in message ... On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm" wrote: IIRC, snowmobiles are/were derived from chain saws--which required an engine light enough for a man to carry and use as a hand held tool. That made them an obvious choice for another application were light weight was the most critical factor--even at the cost of reliability and maintenance intervals... I've never heard that, seems unlikely... they are really very different, except for both (along with outboard motors) being 2-strokes. All for the same reason of light weight. -Dana -- If you glue a piece of toast, butter side up, to your cat's back, and drop it from a high place, which way will it land? Today, thanks to a substantial market with plenty of discretionary money, engines for snowmobiles and ultralights have improved drastically. Gardening equipment also runs far more reliably today--and a portion of that improvement may have come from improvements made first on ultralights and snowmobiles. But it was not always so--and I recommend that you ask a few of the old timers why they used to refer to some ofthe ultralight areas by nicknames such as "the killing fields". Peter |
"Peter Dohm" wrote in message news
|| "Dana M. Hague" wrote in message | ... | On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm" | wrote: | | IIRC, snowmobiles are/were derived from chain saws--which required an | engine | light enough for a man to carry and use as a hand held tool. That made | them | an obvious choice for another application were light weight was the most | critical factor--even at the cost of reliability and maintenance | intervals... | | I've never heard that, seems unlikely... they are really very | different, except for both (along with outboard motors) being | 2-strokes. All for the same reason of light weight. | | -Dana | -- | If you glue a piece of toast, butter side up, to your cat's back, and drop | it from a high place, which way will it land? | | Today, thanks to a substantial market with plenty of discretionary money, | engines for snowmobiles and ultralights have improved drastically. | Gardening equipment also runs far more reliably today--and a portion of that | improvement may have come from improvements made first on ultralights and | snowmobiles. | | But it was not always so--and I recommend that you ask a few of the old | timers why they used to refer to some ofthe ultralight areas by nicknames | such as "the killing fields". | | Peter | | I'm an old timer, with a good bit of experience in ultralights, but I don't recall engine reliability being all the bad in the early days, or having much to do with the early ultralight fatalities. |
On Fri, 28 Nov 2008 14:01:36 -0500, "Peter Dohm"
But it was not always so--and I recommend that you ask a few of the old timers why they used to refer to some ofthe ultralight areas by nicknames such as "the killing fields". Most of the early ultralight fatalities were due to lack of training and the occasional structural failure, not engine failure... not that there weren't frequent engine failures, too. And even at that, many of the engine failures were pilot related... either not knowing anything about engines (again, lack of training) or pilots who thought they could treat a 2-stroke just like a Continental 0-200. How many pilots fried their Cuyuna engines because they didn't have an EGT to keep track of the temperatures? -Dana (who first flew an ultralight in the 1980's, and still flies a Cuyuna powered ultralight today(yes, with EGT and CHT)) -- People in cars cause accidents. Accidents in cars cause people. |
On Fri, 28 Nov 2008 08:30:06 -0500, Dana M. Hague
wrote: On Thu, 27 Nov 2008 09:37:54 -0500, "Peter Dohm" wrote: IIRC, snowmobiles are/were derived from chain saws--which required an engine light enough for a man to carry and use as a hand held tool. That made them an obvious choice for another application were light weight was the most critical factor--even at the cost of reliability and maintenance intervals... I've never heard that, seems unlikely... they are really very different, except for both (along with outboard motors) being 2-strokes. All for the same reason of light weight. -Dana Some of the first ultralights DID run chainsaw motors - just like the go-cart crowd. Some of the small aircooled outboard engines were also used - and some early snowmobiles also used a converted aircooled outboard. (horizontal twin Johnson Snow Cruiser and OMC) |
| Thread Tools | |
| Display Modes | |
| Preheating engines: Airplane engines versus auto engines | Peter R. | Owning | 86 | January 2nd 08 08:48 PM |
| Torque wrenches... | .Blueskies. | Home Built | 3 | January 11th 06 03:20 PM |
| Autogas and high end engines | John Skorczewski | Home Built | 10 | August 17th 04 06:19 PM |
| High-Strength Aluminum Helps 2-Stroke Engines | sanman | Home Built | 4 | April 29th 04 01:32 AM |
| High-Strength Aluminum Helps 2-Stroke Engines | sanman | Rotorcraft | 4 | April 29th 04 01:32 AM |
