Ventus 2cx brake
Old November 26th 08, 05:42 PM posted to rec.aviation.soaring
Andy[_1_]
Default Ventus 2cx brake
On Nov 26, 10:27*am, Greg Arnold wrote:
No, still using the bicycle cable with the Beringer system. *See the
installation instructions he
http://schempp-hirth.com/fileadmin/t...9-33-2444.pdf- Hide quoted text -
Not only cable but clamp screw type cable nipples. Makes me
appreciate even more the direct actuated Cleveland system used by
Schleicher.
Andy
Old November 26th 08, 06:05 PM posted to rec.aviation.soaring
Bob Kuykendall
On Nov 26, 8:32*am, Andy wrote:
Why would anyone ruin a great hydraulic disc brake by actuating the
master cylinder with a bicycle cable?
When I was building a brake system for the center stick controls of my
HP-18, I decided I wanted the stick to have as little inertia, and as
little mass aft of the ptich pivot, as practical. Hence my decision to
use a mountain bike brake lever on the stick driving a fixed master
cylinder through a low-friction sheathed cable. That's why this
sailplane developer developed such a system.
My caution was driven by an earlier accident involving a late
acquaintenance whose sailplane unzipped in turbulence and distributed
parts pretty widely. That ship's control stick had been modified in a
way that some thought contributed to undamped PIO.
Thanks, Bob K.
Old November 26th 08, 06:09 PM posted to rec.aviation.soaring
DRN
Thanks, Bob K.
Even better is to use a direct linkage from the spoiler
and keep this buggery off the stick completely !
See ya, Dave "YO electric"
PS: I know, doesn't work on the HP-18, no spoilers;
my whale has it on the stick...
Old November 26th 08, 11:00 PM posted to rec.aviation.soaring
Andy[_1_]
Did you consider using a mountain bike hydraulic brake lever? Perhaps
they were not available then. Is the mass of the lever even
significant compared to the mass of the pilot's hand and arm that are
also usually, and certainly during a PIO, attached to the stick?
Andy
Old November 26th 08, 11:39 PM posted to rec.aviation.soaring
Bob Kuykendall
On Nov 26, 3:00*pm, Andy wrote:
Did you consider using a mountain bike hydraulic brake lever? *Perhaps
Yes, I tested a promising one at the time. As little displacement as
my Cleveland caliper requires under typical conditions, it still took
a couple pumps of the lever before it pressured up.
Is the mass of the lever even significant compared to the mass of the
pilot's hand and arm that are also usually, and certainly during a
PIO, *attached to the stick?
Not known. I do know that the available hydraulic master cylinders
with attached reservoir are around a pound or so. I also know that the
human hand and arm has a lot of inherent damping, and also that only
about half the mass of the forearm counts as sprung weight. In this
case at least I decided to develop conservatively and move on.
Thanks, Bob K.
Old November 26th 08, 06:39 PM posted to rec.aviation.soaring
Bob Kuykendall
On Nov 26, 7:54*am, BravoCharlie
I have also heard the suggestion to replace the plastic
brake fluid line with braided stainless. *Any thoughts about that?-
I found that the plastic brake line works perfectly well with very
little stretch. I'm using Nylo-Seal NSR 1/8" OD, .026" wall stuff so
the internal volume is as low as possible and the hoop and
longitudinal stresses are reasonable. I originally expected that the
small internal cross-section would make the flow rate low enough that
the brakes would be slow to apply and slow to release, but that has
not been the case. It seems that disk brakes operate with such little
displacement that even .004in^2 of cross-section on a 4-foot tube
provides adequate flow.
Thanks, Bob K.
brake fittings [email protected] Home Built 6 April 30th 07 01:33 AM
K21 brake parts Stuart Kinnear Soaring 10 June 26th 06 09:54 PM
looking for a 75 to 100 ton press brake about 8/10 ft Adrian eyre Home Built 1 January 6th 05 05:28 AM
BRAKE FLUID Ventus B Soaring 9 October 17th 04 07:25 PM
My squishy brake JFLEISC Owning 0 June 30th 04 01:44 AM
