A word of warning - before you start tying trailer lights into your
car's brake/running/turn signal circuit, make sure your vehicle doesn't have a computer connected to the lighting circuit. A clue of the use of a computer is that you get a message on the dash when a brake/running/turn signal light is out. If such a computer is being used, you can blow it out if you draw too many amps. Here's a link to a previous RAS discussion on trailer light wiring that relates to the current topic: http://tinyurl.com/6kf9ab -John |
When my dad and I picked up my new Cobra trailer in March we were
prepared for everything, and that's what we got. The trailer's wiring did not even match the factory's diagram. My dad (who is a retired electrical engineer) could not figure out how it ever worked in Germany. Take a complete set of tools and spare widgets. ~ted/2NO |
Back in 2002 I sent the kind folks at Cobra a note explaining that for
something like $30 in parts they could make any trailer headed for the US plug and play. Simply plug in an adapter to convert "euro" to the typical "flat four" connector and flip a single switch at the back of the trailer. It only would take 60 seconds at the port for the new owner to be driving away and the lights would work. I suggested they just add $200 to each trailer as "standard" and no one would ever bring up this subject again. |
You can generally buy a what-ever-you-have-on-your-car to a what-ever-
you-have-on-your -trailer adapter at trailer stores. At least from the car to a four-flat system. A few suggestions if you rewire. 1) Go to a 4-flat system as that seems to be the most (least?) common denominator, at least here in the US. 2) Go to LED lighting as they don't have nearly the corrosion issues that incadescent lighting does. 3) Slather Dow Corning #4 dielectric grease on external connectors and light bulb sockets to prevent corrosion and keep out water. 4) Use crimp connections instead of wire nuts or solder. My $0.02. Good luck, John |
The glider isn't always plug-and-play, so we shouldn't expect the
trailer to be either! Starting with a tow vehicle that has tail lighting of the modern international standard, not the 1950s 4-wire system illegal in most of the world, makes the job easier. US auto manufacturers only stay with the ancient way because it involves less wire. Intentionally having only one working brake light while turning is a strange concept. Then decide which "large connector" you'd like on both. The US 7-pin is quite common, but ones installed at the dealer seem to get wired as a 4-wire system and most are plastic. I use the 6-pin round "redondo de 6 polos", which has a metal chassis but unfortunately comes without the 6 chickens. With the extra pin(s) you can hook up reversing lights or interior lights. Build adapters to and from everything you can imagine, then perhaps add adapters to bare ends, spade connectors or alligator clips, and a roll of electrical tape to your kit. Keep the appropriate set in the tow vehicle and the other set in the trailer. If you make the adapter from your vehicle to European round, electrically it'll be plug and play at the docks. As mentioned before, LED lights are the way to go. Couldn't find them in the US due to the abundance of stone age trailer lighting. The most convenient place I found red/amber LED lights was ebay in Australia. The same LED lights are available at many parts suppliers there, but they may not ship overseas. The square ones I have are a couple of mm smaller than the round hole in a Cobra trailer, so some home made parts are needed to cover the edge of the holes up. An example of the lights and cost: http://cgi.ebay.com.au/2-x-LED-STOP-...7 C240%3A1318 Of course you can find "buy now" ones too. Jim |
On Dec 3, 8:15*am, JS wrote:
The glider isn't always plug-and-play, so we shouldn't expect the trailer to be either! * Starting with a tow vehicle that has tail lighting of the modern international standard, not the 1950s 4-wire system illegal in most of the world, makes the job easier. US auto manufacturers only stay with the ancient way because it involves less wire. Intentionally having only one working brake light while turning is a strange concept. * Then decide which "large connector" you'd like on both. The US 7-pin is quite common, but ones installed at the dealer seem to get wired as a 4-wire system and most are plastic. I use the 6-pin round "redondo de 6 polos", which has a metal chassis but unfortunately comes without the 6 chickens. It's "POLOS", nor "POLLOS" ... viva la diferencia! Uri |
PLEASE, PLEASE, PLEASE..........
TELL US IT WAS REAL plug and play.................... It would be nice to learn it functioned properly.... after all this is the year 2008 ano domini man was on moon, long ago. else; try plug and pray, before touching anything At 21:57 01 December 2008, Gary Emerson wrote: Back in 2002 I sent the kind folks at Cobra a note explaining that for something like $30 in parts they could make any trailer headed for the US plug and play. Simply plug in an adapter to convert "euro" to the typical "flat four" connector and flip a single switch at the back of the trailer. It only would take 60 seconds at the port for the new owner to be driving away and the lights would work. I suggested they just add $200 to each trailer as "standard" and no one would ever bring up this subject again. |
there are diagrams showing how to convert the European wiring to suite US
vehicles on my website "useful info page" and on my links to cobra trailers. (From memory.....double check this) actually converting the wiring is quite simple....the US 4 pin (flat plug) wires are White, Brown Yellow and Green, the European trailer plug has all these colors plus extra's for the separate amber and red lights.....connect all of these 4 colors to the US connector, add the black wire from the trailer to the brown wire, disregard the rest.....remove the tail light lenses and disconnect the top bulb wire and connect it to the bottom bulb (dual function bulb) leaving the top bulb disconnected and the original wire from the bottom stop/turn bulb disconnected and you should have running lights,side markers lights and stop and turn signal lights from the lower bulbs. again....double check this but I think this is going to work on almost any European trailer with these separate amber and red tail lights.. also....even if you have a US vehicle that has separate amber and red tail lights (most newer ones do today) the trailer wiring is set up for 99.999% of the trailers in the USA that have only combination stop/turn signals! And though some might want to put European trailer connectors on their tow vehicles this is a really bad idea and something that we tried back in the 1970's to discourage since sometime you may need to have someone pull your trailer to come get you out of a field and unless we all use a standard 4 pin plug there is little chance that you and you pal have the same connector set ups. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "John Bojack" wrote in message ... Picking up a new Cobra trailer at the port on Tuesday......wondering if I can expect just to plug it into my SUV motorhome and have the lights working correctly? Anyone with a success story ? Trailer and SUV are both fitted witht the new large plug and receptacle. Thanks! J4 |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
A great plug for the "pinch-hitter" course | Jay Honeck | Piloting | 0 | November 24th 06 12:32 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
