Fuses in general
Old December 9th 08, 09:38 PM posted to rec.aviation.soaring
Steve Koerner
Default Fuses in general
My opinion is that low current fuses on the panel (or behind it) are
more likely to cause problems than prevent them. I use just one fuse
per battery circuit. I prefer a 10 amp automotive blade fuse mounted
at the battery. If it might be of interest, I've prepared a short
treatise on glider battery wiring and fusing including a picture which
is accessed at this page:
http://www.wingrigger.com/wingrigger5_005.htm
Steve Koerner
GW
Old December 9th 08, 09:56 PM posted to rec.aviation.soaring
Brian:
Sounds like a good plan. I like the Anderson powerpole connectors
mainly because they have enough friction during connection to wipe the
surface clean of any oxidation, so give a good connection. I don't
use the roll pin to hold the two terminals together -- just squirt a
little hot melt into the matching indents. And yes, the automotive
blade fuses are an excellent installation on one of the battery
terminals. As for holding batteries down, I agree a metal hose clamp
is an accident waiting to happen. What's wrong with a short piece of
bungee cord?
Fred LaSor
SoaringNV
Minden, NV
resettable fuses - US source? Gary Emerson Soaring 12 November 9th 07 10:09 PM
fuses vs. circuit breakers raulb Soaring 0 November 8th 07 02:48 PM
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
Fuses versus Breakers ContestID67 Soaring 14 March 14th 05 01:47 PM
