Looking for B-17 video...
Old December 27th 03, 04:40 PM
Tarver Engineering
"Ralph Nesbitt" wrote in message
"Duster" wrote in message
Holy **** and all I wanted was a video... hehe this is almost better
though..
Duster
Tarver cannot get it through his head that having the air handling units
operating under the CWT when the A/C is stationary is like putting a
pressure cooker with a small amount of fuel in it, on a stove at low heat.
Nesbitt can't get it through his head that a 747 is not a bomb and there is
no design philosophy to make airliners that are bombs at Boeing.
Old December 27th 03, 06:15 PM
Ralph Nesbitt
"Tarver Engineering" wrote in message
though..
Duster
heat.
is
Hopefully your skull is thick enough to deflect the flying "Bits & Pieces"
when an FAE occurs.
Ralph Nesbitt
Professional FD/CFR/ARFF Type
Old December 27th 03, 06:23 PM
Tarver Engineering
y.com...
though..
Duster
units
heat.
is
when an FAE occurs.
You mean aluminium dust?
Sorry, Nesbitt, no aluminium dust bombs, no hydrogen and propane potato gun,
just an empty fuel tank. What you write demonstrates just how deeply Hall's
NTSB implanted their fantasy in your mind.
Old December 28th 03, 04:05 AM
Pooh Bear
though..
Duster
There have been several incidents world wide where Boeing A/C of various
models have exploded sitting at gates, on ramps, taxing out, or shortly
after take off after sitting with the air handling units running under ~
empty CWT's.
There are now "Air Safety Directives" stipulating/requiring certain
operating protocols to minimize this hazard associated with the "Boeing CWT
Design Philosophy".
All very true.
I was nevertheless disappointed as a pyromaniac kid, that placing a closed
paint can 1/4 full of petrol / gasoline over a camp stove *didn't* result in
the conflagration I was hoping for !
Graham ;-)
Old December 28th 03, 05:49 AM
Ralph Nesbitt
"Pooh Bear" wrote in message
though..
Duster
heat.
empty CWT's.
CWT
Design Philosophy".
All very true.
in
Graham ;-)
You left/put to much in the can.
You want a show. Put 1 cap full of gasoline/petrol in a dry standard 2 liter
bottle, put the lid on, put it in the middle of a 55 gallon "Burn Barrel"
filled with loose News paper. Light the News paper, stand way back.
Just the closed bottle itself exploding has been known to scatter burning
paper some distance. Adding a "Cap full of Petrol/Gasoline" to the bottle,
depending on exact direction of explosive failure within the barrel, has
been know to turn the barrel over/roll it around.
Caution have a water hose handy to deal with "Grass Fires" resulting from
the scattered burning paper. Don't try this where burning paper will land on
building roofs, or drift into areas conducive of "Wild Fires". Expect
burning paper to be blown as much as 100' in the air depending on proper
placement of paper in barrel before lighting the fire.
Ralph Nesbitt
Old December 28th 03, 06:02 AM
Scott M. Kozel
though..
Duster
empty CWT's.
Design Philosophy".
All very true.
Graham ;-)
Splaps Boy can fire a shotgun blast into a gallon can full of gasoline,
at point-blank range.
Old December 28th 03, 04:40 PM
Tarver Engineering
though..
Duster
heat.
empty CWT's.
CWT
Design Philosophy".
All very true.
All very false, Ralph is lying and has not a clue.
Old December 28th 03, 05:24 PM
Ralph Nesbitt
though..
Duster
units
heat.
various
shortly
empty CWT's.
"Boeing
CWT
Design Philosophy".
All very true.
Ok in "Detail & Specifics" explain;
What is "Very False?
Why am I allegedly "Lying About"?
What is it I do not have a "Clue About" regarding the "Inherent Dangers"
associated with "The Boeing CWT Design Philosophy"?
In the above context I am using the Term "Inherent Dangers" as defined/used
by the Liability Insurance Industry.
Ralph Nesbitt
Old December 28th 03, 04:01 AM
Pooh Bear
though..
Duster
Glad to be of service ;-)
About time a.d.a talked about real a/c probs instead of crank dip****
conspiracy theories.
Graham
Old December 28th 03, 04:39 PM
Tarver Engineering
though..
Duster
You mean that crank dip**** Hall?
turbo video Peter Holm Aerobatics 13 September 29th 04 11:31 PM
Aviation Video: Another F-16 bites the dust Iwan Bogels Instrument Flight Rules 0 September 21st 04 07:02 AM
In-Flight Video Ron Wanttaja Home Built 11 May 16th 04 06:11 AM
B-36 Video Dave Jones Military Aviation 0 November 15th 03 04:05 PM
"Support Our Troops" Video (Link) dave911 Military Aviation 0 July 29th 03 06:59 AM
Copyright Đ2004-2025 AviationBanter.
