#61
Do the benefits of "start anywhere" outweigh the disadvantages?
#62
On Jan 10, 2:04*pm, ZL wrote:
Section 11.2.3.2 has the Regional start anywhere rule for 2008. Thats the scoring rules section. They missed that it was in two places. thanks Andy |
#63
On Jan 11, 6:31*am, PMSC Member wrote:
Do the benefits of "start anywhere" outweigh the disadvantages? My impression is that most pilots who have flown with start anywhere hae liked it. The discussion here has been mostly about the proposed modification that the RC is proposing before the rule goes into effect for Nationals in 2009. The focus of the discussion is whether the change addresses a real problem. I took a look at the first day at Region 9 in 2008 to try to understand at least one example of pilot behavior under the start anywhere rule. In Std, 15M and and 18M (all using the same start cylinder) 29 pilots started through the top of the cylinder, 5 started out the side - mostly close to the courseline. Roughly 2/3 of the pilots started in the front half of the cylinder, but starts were distributed all over the cylinder with the largest "gaggle" of starters comprised of 4 gliders. Climb rates for out the top starters were as follows: 6 at1.8-3.9kts, 9 at 4-4.9 kts, 5 at 5-6 kts, 5 at 6-7 kts and 4 at 7-8 kts. A number of the start climbs were for more than 4,000' gains. There appeared to be pretty good correlation between higher climb rates at the start and pilots at the top of the scoresheet at the end of the contest, so perhaps the difference in climb is more a result of strategy than luck. I'll take a look at some more contest days time permitting. Overall there's nothing of concern and some potential strategic insights that might be useful here. 9B |
#64
On Jan 11, 12:35*pm, wrote:
On Jan 11, 6:31*am, PMSC Member wrote: Do the benefits of "start anywhere" outweigh the disadvantages? My impression is that most pilots who have flown with start anywhere hae liked it. The discussion here has been mostly about the proposed modification that the RC is proposing before the rule goes into effect for Nationals in 2009. The focus of the discussion is whether the change addresses a real problem. I took a look at the first day at Region 9 in 2008 to try to understand at least one example of pilot behavior under the start anywhere rule. In Std, 15M and and 18M (all using the same start cylinder) 29 pilots started through the top of the cylinder, 5 started out the side - mostly close to the courseline. Roughly 2/3 of the pilots started in the front half of the cylinder, but starts were distributed all over the cylinder with the largest "gaggle" of starters comprised of 4 gliders. Climb rates for out the top starters were as follows: 6 at1.8-3.9kts, 9 at 4-4.9 kts, 5 at 5-6 kts, 5 at 6-7 kts and 4 at 7-8 kts. A number of the start climbs were for more than 4,000' gains. There appeared to be pretty good correlation between higher climb rates at the start and pilots at the top of the scoresheet at the end of the contest, so perhaps the difference in climb is more a result of strategy than luck. I'll take a look at some more contest days time permitting. Overall there's nothing of concern and some potential strategic insights that might be useful here. 9B That leads to what might not be a bad idea. I would think it would be fairly easy to have Winscore compile a list of start locations for each day. If the rules committee or even the contest organizers had this information it might be easier to anaylize how people are actually starting. Brian |
#65
On Jan 6, 4:25*pm, Andy wrote:
In a simple graphic analysis of the defined task I estimated a distance of over 8 miles of start cylinder circumference between the intersections of the two extreme case arcs and the start circle. *In other words, the potential front half circumference of approx 31.4 miles is reduced to a no risk arc of approx 23.4 miles. Don't want to re-open this but just in case someone reads it later I need to correct the numbers. I should have said: "The potential front half circumference of 16.7 miles is reduced to a no risk arc of approx 8.7 miles." My error was caused by starting with the full circle circumference instead of the half circle circumference. The numbers were fine tuned by 9B later in the discussion. Andy |
#66
On Jan 12, 3:45*pm, Andy wrote:
"The potential front half circumference of 16.7 miles is reduced to a no risk arc of approx 8.7 miles." I'm digging myself a big hole here, but did say I was math averse! Should be 15.7 and 7.7 of course. |
#67
On Jan 11, 11:35*am, wrote:
On Jan 11, 6:31*am, PMSC Member wrote: Do the benefits of "start anywhere" outweigh the disadvantages? My impression is that most pilots who have flown with start anywhere hae liked it. The discussion here has been mostly about the proposed modification that the RC is proposing before the rule goes into effect for Nationals in 2009. The focus of the discussion is whether the change addresses a real problem. I took a look at the first day at Region 9 in 2008 to try to understand at least one example of pilot behavior under the start anywhere rule. In Std, 15M and and 18M (all using the same start cylinder) 29 pilots started through the top of the cylinder, 5 started out the side - mostly close to the courseline. Roughly 2/3 of the pilots started in the front half of the cylinder, but starts were distributed all over the cylinder with the largest "gaggle" of starters comprised of 4 gliders. Climb rates for out the top starters were as follows: 6 at1.8-3.9kts, 9 at 4-4.9 kts, 5 at 5-6 kts, 5 at 6-7 kts and 4 at 7-8 kts. A number of the start climbs were for more than 4,000' gains. There appeared to be pretty good correlation between higher climb rates at the start and pilots at the top of the scoresheet at the end of the contest, so perhaps the difference in climb is more a result of strategy than luck. I'll take a look at some more contest days time permitting. I took a look at a second day at R9 in 2008 and a day from 2007. Disclaimer: three contest days is a small sample and all three days were flown at Parowan under conditions that allowed starts through the top of the cylinder. Some interesting (to me) observations: Under the start anywhere rule the percent of pilots starting through the top increased to 85% from 60%. Under the old rule most out the top starts were within a mile or two of where the edge of the cylinder meets the first leg courseline. Under the new rule starts were broadly distributed, with a slight bias toward the front half of the cylinder. As you'd expect, spreading out starts makes for smaller gaggles - under the old rule it appeard there were at any given time 2-3 big gaggles with 5-10 gliders in them - the biggest gaggle being at the edge of the cylinder on courseline. Now the really interesting part (repeat disclaimer here). Under the old rules starters out the top had a slightly faster average climb that starters out the side - less than half a knot. Also, there was less scatter in out the top climb rates than initial climbs after starting out the side - this stands to reason - under the old rules climbing out the top was normally crammed together into a couple of gaggles. Under the new rules the opposite is true. Starters out the top had nearly a knot slower initial climb on average than the admittedly small number of edge of cylinder starts. The scatter (as measured by standard deviation as a percent of average climb rate) was about 50 percent higher for starts out the top. All of this stands to reason in my rationalizing mind. If you have more room inside the cylinder to look there is some likelihood that a few pilots will hit boomers and get an advantage, but the lower average climb rate for starts out the top also indicates that perhaps pilots got a bit fixated on starting this way - climbing out the top at 3 knots when there are 10-knotters about is not a great decision. All of the above is very rough and can be rightly criticized for a host of reasons. On thing that is clear is that the first climb out of the start is not the whole story - pilots with weaker thermals tend to leave them sooner, so you really need to get an aggregate view of average climb rate to the top of the lift band - even if it's spread over 2-3 thermals. That's too complex an exercise to do with SeeYou and a spreadsheet. 9B |
#68
On Jan 13, 6:41*pm, wrote:
On Jan 11, 11:35*am, wrote: On Jan 11, 6:31*am, PMSC Member wrote: Do the benefits of "start anywhere" outweigh the disadvantages? My impression is that most pilots who have flown with start anywhere hae liked it. The discussion here has been mostly about the proposed modification that the RC is proposing before the rule goes into effect for Nationals in 2009. The focus of the discussion is whether the change addresses a real problem. I took a look at the first day at Region 9 in 2008 to try to understand at least one example of pilot behavior under the start anywhere rule. In Std, 15M and and 18M (all using the same start cylinder) 29 pilots started through the top of the cylinder, 5 started out the side - mostly close to the courseline. Roughly 2/3 of the pilots started in the front half of the cylinder, but starts were distributed all over the cylinder with the largest "gaggle" of starters comprised of 4 gliders. Climb rates for out the top starters were as follows: 6 at1.8-3.9kts, 9 at 4-4.9 kts, 5 at 5-6 kts, 5 at 6-7 kts and 4 at 7-8 kts. A number of the start climbs were for more than 4,000' gains. There appeared to be pretty good correlation between higher climb rates at the start and pilots at the top of the scoresheet at the end of the contest, so perhaps the difference in climb is more a result of strategy than luck. I'll take a look at some more contest days time permitting. I took a look at a second day at R9 in 2008 and a day from 2007. Disclaimer: three contest days is a small sample and all three days were flown at Parowan under conditions that allowed starts through the top of the cylinder. Some interesting (to me) observations: Under the start anywhere rule the percent of pilots starting through the top increased to 85% from 60%. Under the old rule most out the top starts were within a mile or two of where the edge of the cylinder meets the first leg courseline. Under the new rule starts were broadly distributed, with a slight bias toward the front half of the cylinder. As you'd expect, spreading out starts makes for smaller gaggles - under the old rule it appeard there were at any given time 2-3 big gaggles with 5-10 gliders in them - the biggest gaggle being at the edge of the cylinder on courseline. Now the really interesting part (repeat disclaimer here). Under the old rules starters out the top had a slightly faster average climb that starters out the side - less than half a knot. Also, there was less scatter in out the top climb rates than initial climbs after starting out the side - this stands to reason - under the old rules climbing out the top was normally crammed together into a couple of gaggles. Under the new rules the opposite is true. Starters out the top had nearly a knot slower initial climb on average than the admittedly small number of edge of cylinder starts. The scatter (as measured by standard deviation as a percent of average climb rate) was about 50 percent higher for starts out the top. All of this stands to reason in my rationalizing mind. If you have more room inside the cylinder to look there is some likelihood that a few pilots will hit boomers and get an advantage, but the lower average climb rate for starts out the top also indicates that perhaps pilots got a bit fixated on starting this way - climbing out the top at 3 knots when there are 10-knotters about is not a great decision. All of the above is very rough and can be rightly criticized for a host of reasons. On thing that is clear is that the first climb out of the start is not the whole story - pilots with weaker thermals tend to leave them sooner, so you really need to get an aggregate view of average climb rate to the top of the lift band - even if it's spread over 2-3 thermals. *That's too complex an exercise to do with SeeYou and a spreadsheet. 9B Andy, Great analysis, thanks for taking the time. One thing you may need to watch for if you do additional analysis, some of us had the boards out in the bottom of the thermals to core the center and ensure we were under the top for two minutes before starting the climb out the top. This may lower the average climb value displayed in SeeYou. TT |
#69
Will somebody close to 9B please throw a Rubik's Cube over his
transom. Thanks! 2NO |
#70
On Jan 14, 5:41*am, Tuno wrote:
Will somebody close to 9B please throw a Rubik's Cube over his transom. Thanks! 2NO Is that a new shape for the start cylinder? Anything worth doing is worth over-doing, I always say. |
| Thread Tools | |
| Display Modes | |
| FAA publishes proposed changes to amateur-built rules. | Jim Logajan | Home Built | 19 | July 28th 08 09:30 AM |
| 2009 U.S. Contest Locations/Dates | Tim[_2_] | Soaring | 2 | February 28th 08 06:48 PM |
| 2008 Proposed US Competition Rules Changes | [email protected] | Soaring | 18 | December 31st 07 08:21 PM |
| US Contest Rules Proposed Changes for 2006 | Ken Sorenson | Soaring | 18 | January 12th 06 05:30 PM |
| Proposed 2005 Rules On SRA Site | Ken Kochanski (KK) | Soaring | 79 | January 27th 05 07:51 PM |
