What was the timetable for British development for their 20 mm cannon
ammuniation during WW2? They also used ball ammo early on (just an empty steel shell - we'd call it Target Practice now) in lieu of AP - it would punch through about a half-inch of plate, and sometimes proved more destructive initially than the fast-fuze HE. They continued to use ball mixed with HE/HEI in the belts until 1942, when the SAPI came along. This was just an HE shell filled with incendiary material and with a hard steel piercing cap instead of a fuze; it could penetrate around 20mm plate. From then on, the standard belt mix was two HEI followed by two SAPI. Thanks Tony! So RAF stopped using ball ammo during 1942. And there was no true AP ammo in use before SAPI? Interesting. I wonder, they had Hurricane II with 4x20 mm. I presume this plane was used in ground attack missions with the bombload. Those cannons were still loaded with HE/HEI/BALL ammo for strafing missions? I presume they weren't much effective against German armour? I have Tony/Emmanuel's book and it mentions how RAF tested the cannon ammo against Japanese tanks. Knowing how Japanese tanks had rather thin armour I'd guess the results were better against them than against German armour, excepting Panzer IIs and other light tanks/vehicles? So RAF *never* had a true AP shot? During whole war? Fascinating. This development on cannon ammo is a fascinating subject. I was quite astounded when I interviewed the Finnish ace Antti Tani, who was one of the best Finnish Morane-Saulnier 406 pilots. They had only HE ammo available and it is quite wide opinion in Finland, that the Morane cannon was very problematic. The ammo was so sensitive, that it sometimes exploded in the cannon barrel - or in the surface of the target, just like Brits found out. One squadron made tests and mr. Hugo Estama referred, that the cannon shot exploded even when hitting a cardboard, before penetrating. Mr. Tani on the other hand was a quick learner and he actually made AP ammo by himself. He defused the HE rounds, took out the HE and voila - self made AP. Similar to British ball? He loaded his cannon himself, 2 HE for 1 "AP". This practise was discontinued by commander's order when somebody else in the squadron tried making "AP" rounds too and the shot exploded, wounding him severely. Mr. Tani was a mechanic, watchmaker by profession, so he knew what he was doing. He claimed total of 7 Soviet planes with Morane, including two of the most valuable prey out there - Pe-2 bombers (which almost had higher cruising speed than the Morane's top level speed). If your'e interested you can read mr. Tani's interview he http://www.virtualpilots.fi/hist/WW2...riEnglish.html jok |
"Jukka O. Kauppinen" wrote in message ...
So RAF stopped using ball ammo during 1942. And there was no true AP ammo in use before SAPI? Interesting. I wonder, they had Hurricane II with 4x20 mm. I presume this plane was used in ground attack missions with the bombload. Those cannons were still loaded with HE/HEI/BALL ammo for strafing missions? I presume they weren't much effective against German armour? Several different AP rounds were developed and tested in the UK, but as far as I can tell they were all unsatisfactory. The Mk 1 and Mk 2 were traditional solid shot and proved ineffective when tested against tanks, so weren't generally issued. The Mk 3 was the APCR. There was a more traditional Mk 4, which came out in 1944, but I don't know if that saw any use; I have no record that it did. The RAF seemed to find that the ball and SAPI rounds were more than adequate against aircraft, and the 20mm was too small to do much damage to tanks. So they concentrated on the 40mm for anti-tank use until they decided that wasn't good enough either, and went to RPs instead. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
50% of NAZI oil was supplied from US | Grantland | Military Aviation | 106 | January 18th 14 07:58 PM |
russia vs. japan in 1941 [WAS: 50% of NAZI oil..] | Military Aviation | 136 | December 6th 03 10:40 PM | |
French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 06:48 PM |
AF unveils force development plan | Otis Willie | Military Aviation | 0 | October 11th 03 04:55 AM |
