On Jan 24, 2:38*pm, Gezellig wrote:
On Sat, 24 Jan 2009 08:17:26 -0800, BT wrote: This was discussed some years ago with the beginning of the glass panel, but also with the beginning of DA20s and DA40s used for primary training. Transition from glass to steam gauges is a minor transition. OK. What about steam to glass transitions? I teach G1000 transition using the Cessna FITs syllabus. The short answer is that it really depends on the pilot. Some pilots take to the glass as if were nothing; others never really get it. Sadly, there appears to be a strong correlation between the ability to learn this stuff and age. In almost 1/4 of the cases we find ourselves having to sign pilots off as "VFR only" in the G1000 even though they are highly experienced instrument pilots. It isn't too big of a deal for a VFR pilot to stumble around with the buttonology but it could be very dangerous for a pilot to do the same in IMC trying to set up an approach. -Robert |
On 01/26/09 11:15, Robert M. Gary wrote:
On Jan 24, 2:38�pm, Gezellig wrote: On Sat, 24 Jan 2009 08:17:26 -0800, BT wrote: This was discussed some years ago with the beginning of the glass panel, but also with the beginning of DA20s and DA40s used for primary training. Transition from glass to steam gauges is a minor transition. OK. What about steam to glass transitions? I teach G1000 transition using the Cessna FITs syllabus. The short answer is that it really depends on the pilot. Some pilots take to the glass as if were nothing; others never really get it. Sadly, there appears to be a strong correlation between the ability to learn this stuff and age. In almost 1/4 of the cases we find ourselves having to sign pilots off as "VFR only" in the G1000 even though they are highly experienced instrument pilots. It isn't too big of a deal for a VFR pilot to stumble around with the buttonology but it could be very dangerous for a pilot to do the same in IMC trying to set up an approach. -Robert Really a sad state, considering the glass was supposed to reduce cockpit workload and increase situational awareness :-( -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
On Jan 26, 11:22*am, Mark Hansen wrote:
Really a sad state, considering the glass was supposed to reduce cockpit workload and increase situational awareness :-( Its a lot like using a PC vs a typewriter. If you've never used a PC or aren't comfortable using a PC its much faster to type your letter using the typewriter. You don't have to search for the "Print" icon, figure out the printer drivers, etc. However, once you know how to set up a coupled approach in the G1000 its pretty cool to watch it intercept the loc, then capture the GS and fly itself right down to the runway. -Robert |
On Mon, 26 Jan 2009 11:15:42 -0800 (PST), Robert M. Gary wrote:
On Jan 24, 2:38*pm, Gezellig wrote: On Sat, 24 Jan 2009 08:17:26 -0800, BT wrote: This was discussed some years ago with the beginning of the glass panel, but also with the beginning of DA20s and DA40s used for primary training. Transition from glass to steam gauges is a minor transition. OK. What about steam to glass transitions? I teach G1000 transition using the Cessna FITs syllabus. The short answer is that it really depends on the pilot. Some pilots take to the glass as if were nothing; others never really get it. Sadly, there appears to be a strong correlation between the ability to learn this stuff and age. In almost 1/4 of the cases we find ourselves having to sign pilots off as "VFR only" in the G1000 even though they are highly experienced instrument pilots. It isn't too big of a deal for a VFR pilot to stumble around with the buttonology but it could be very dangerous for a pilot to do the same in IMC trying to set up an approach. -Robert The age issue is what slants me to what I perceive as a bigger issue in the steam-glass transition since I am older. I also have a technology background and find this helps in (planning) the transition. |
On Mon, 26 Jan 2009 14:18:43 -0800, VOR-DME wrote:
In article , says... Transition from glass to steam gauges is a minor transition. How do you justify this statement? I'm not being argumentative, but I wonder if you have specific instructing experience or published results from those who do to support this statement. Also, are you referring to IFR or to ab initio VFR training? The thread is about PPL training glass v.s. steam, I believe he means that transition for the newbie pilot. |
On Jan 26, 10:18*am, Gezellig wrote:
On Mon, 26 Jan 2009 14:18:43 -0800, VOR-DME wrote: In article , says... Transition from glass to steam gauges is a minor transition. How do you justify this statement? I'm not being argumentative, but I wonder if you have specific instructing experience or published results from those who do to support this statement. Also, are you referring to IFR or to ab initio VFR training? The thread is about PPL training glass v.s. steam, I believe he means that transition for the newbie pilot. That doesn't make any sense. Why would a newbie pilot needs to transition from anything? I've never transitioned a pilot from glass to steam (doesn't happen very often) but I would imagine that it woudl be difficult. The glass takes a lot of the "scan and interpret" away from the flying duties. Going back to steam means that you need to look at several instruments and develop a mental picture of what is happening. -Robert, CFII |
On Mon, 26 Jan 2009 23:27:19 -0800, VOR-DME wrote:
In article , says... That doesn't make any sense. Why would a newbie pilot need to transition from anything? I've never transitioned a pilot from glass to steam (doesn't happen very often) but I would imagine that it would be difficult. The glass takes a lot of the "scan and interpret" away from the flying duties. Going back to steam means that you need to look at several instruments and develop a mental picture of what is happening. -Robert, CFII My thoughts exactly. Without supporting documentation from the original author, we have to take this as a flippant affirmation. . . I'm the OP, here's the opening post. ================================================== ============ In the past few years, one (supposedly) successful flight training school dumped their Cessna fleet for Diamonds. http://www.eaa-fly.com/Training/Training.html I believe they do not have any aircraft that with standard, "steam" instrumentation. Regardless, the conversation turns quickly to "Is this a good way to go about training for your PPL?" Since most rentals, especially lower priced ones, are Cessna 15x/17x, the transition (backwards so to speak to glass) would appear to be an issue. My expectation is that the majority of newbies to flying look forward to curbing not inflating costs and that they will need to be Cessna (std gauging) prepared not glass panel prepared. Comments appreciated. |
![]() "Gezellig" wrote in message ... In the past few years, one (supposedly) successful flight training school dumped their Cessna fleet for Diamonds. http://www.eaa-fly.com/Training/Training.html I believe they do not have any aircraft that with standard, "steam" instrumentation. Regardless, the conversation turns quickly to "Is this a good way to go about training for your PPL?" Since most rentals, especially lower priced ones, are Cessna 15x/17x, the transition (backwards so to speak to glass) would appear to be an issue. My expectation is that the majority of newbies to flying look forward to curbing not inflating costs and that they will need to be Cessna (std gauging) prepared not glass panel prepared. Comments appreciated. My best guess is that the new designs will haul about the same payload as a Cessna 152 at about the same speed as a Cessna 172 for a lower cost per mile than either of the other two. That will probably work out for both hobbs time and tach time in the very near future--assuming that it is not already the case. That does not mean that I am in the least bit pleased. Based upon my belief that the LSA standard will form the basis of the next new training fleet, and I remain disgusted by those standards! I believe that the weight limit should have been at least 750Kg instead of 600Kg, the maximum cruising speed should have been at least 130Kts instead of 120Kts, and that the standards should have amended as needed to include the maximum number of type certificates already owned by US manufacturers for w seat aircraft. Peter Comment as requested |
Glass Panel Longevity | john smith | Piloting | 47 | October 24th 06 04:52 AM |
Glass Panel construction DVD | [email protected] | Home Built | 0 | July 20th 06 05:41 AM |
A Glass Panel for my old airplane? | Brenor Brophy | Owning | 8 | July 25th 05 07:36 AM |
Glass Panel Scan? | G Farris | Instrument Flight Rules | 6 | October 13th 04 04:14 AM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
