Sad day for Mxsmanic
Old March 4th 09, 08:35 AM posted to rec.aviation.piloting
Mxsmanic
Default *********A DEFENCE FOR MXMORAN***********
Just go look it up! writes:
Which instantly and reinforces the fact that you know *nothing*
because even the PMDG and LDS simulations all include the automatic
disconnect which happens when enough force is excerted on the control
column, a-la what would happen when the pilots keel over on it, or
grab it to execute a TCAS commanded evasive manuver (obviously in
addition to the AP disco button).
What makes you believe that an incapacitated pilot would hit the yoke with
enough force to disengage the autopilot? "Airplane" is a Hollywood work of
fiction, not real life.
Old March 4th 09, 08:11 PM posted to rec.aviation.piloting
Just go look it up!
On Wed, 04 Mar 2009 09:35:37 +0100, Mxsmanic
Because unlike you I've been there and know it only takes 15-20lb of
pressure to disconnect the autopilot? The postulated scenario is well
within reason that the system would have disconnected, "Airplane" or
not.
Hell, the theroy is that Eastern Airlines flight 401 crashed because
the Captain bumped the yoke while just turning to talk to the copilot
and didn't know he had changed modes. It happened.
You don't even understand the basics of the systems that you
supposedly simulate "just like real life" and come here and try and
tell real pilots who use this stuff day in and day out that you know
more than them, because playing MSFS is a suitable substitute for real
world experience and knoweldge? I knew it was a mistake to put an
expiration date on your entry in my killfile.
Old March 4th 09, 09:25 PM posted to rec.aviation.piloting
Mxsmanic
Why would incapacitated pilots be exerting pressure on the yoke?
tell real pilots who use this stuff day in and day out ...
Virtually nobody here uses this stuff day in and day out. Most of the pilots
here are low-time private pilots, although they might fancy themselves
captains of the sky.
... that you know more than them, because playing MSFS is a suitable
substitute for real world experience and knoweldge?
When it comes to airliner systems, it's a lot more informative than the
baseless speculation I'm seeing from tin-toy pilots here. And I add research
to that, which apparently is also a very rare practice among many posters
here.
You don't learn these systems by trial and error in the aircraft.
Old March 5th 09, 12:07 AM posted to rec.aviation.piloting
Ibby
and didn't know he had changed modes. *It happened.
I cannot see how you wouldn't know the autopilot has been disconnected
as there is a very loud audible warning when this occurs as well as a
warning master switch above the PFD that the pilot cannot miss on
737/747 aircraft and I'm sure Airbus have it too
Ibby
Old March 3rd 09, 11:15 AM posted to rec.aviation.piloting
Ibby
Sounds like you do have a reasonable head on your shoulders so
hopefully you will get the gist of my post..
Thanks ;-)
You really think you are going to have enough time to figure out how
to get the headset on, find the button to contact ATC, MOVE the bodies
out of your way to climb into the left or right seat, and then ATC is
going to have time to find someone to walk you through the complicated
FMC procedures before you buy the farm? *There is no reset button, and
autoland is something that wouldn't be set on a descent profile for an
approach I don't think?????
First priority is NOT talking to ATC but retaining control of the
aircraft. If it is decending rapidly the FIRST button I would engage
is Altitude Hold which will start the aircraft to level out. This can
be easily reached without moving the Pilot or FO. The pilots can be
moved in a moment and ATC can be contacted once you have 'control'.
The radios are more than likely already tuned to the nearest
controller. The major part of the FMC will now be 'unimportant' as
you will no longer be required to continue on your planned route. The
Mode Control Panel (the buttons and dials on the glareshield) take
precedence over the FMC. For the FMC to control the flight director
two buttons require engaging - LNAV (Lateral Navigation) which
controls the roll mode and VNAV which control the Vertical Navigation
and Thrust. Changing the Heading on the MCP and pressing Heading
Select WILL disengage LNAV and the aircraft will no longer be
following the 'magenta' line as set out in the FMC's LEGS pages.
Changing the target altitude on the MCP will cause the aircraft to
level off at that altitude (if still in VNAV) i.e. say you were
currently descending from FL180 and planned altitude of your next
waypoint was FL60ft setting the MCP altitude to FL100 WILL cause the
aircraft to level off at 10000ft. If Vertical Speed is also selected
VNAV will disengage and the IAS/MACH window will open showing the
current speed (it blanks when the FMC is controlling the airspeed as
per parameters set in the FMC) this can then be manually reduced by
using the control knob. The only area of the FMC I can see which
requires input would be the NAV/RAD page which allows manual input of
VOR's NDB's and ILS's which would be essential for a controlled
landing.
Please think of the human adrenalin factor. *Iceman we are not.....
The reality is that even as a private pilot, I seriously doubt that I
would be able to find the right knobs to twist in the vast array of
the digitalized world that would sit in front of me.
I agree and stated before the majority of us would literally be
crapping ourselves. The sim DOES help however in understanding the
'digitised' controls and knobs. When I took my first flying lesson in
a Cessna 152 (yes basic in comparision) but it was exactly the same as
the payware aircraft I bought for the sim. I had NO fear what so ever
as I felt I had done it for years. I knew the effects of every
movement of the control column and rudder pedals etc etc.
The stuff is massive to comprehend under a simulated environment
without the danger of buying the farm. *To expect somebody like myself
who does fly a SE plane who never set foot in the cockpit of a
commercial jet to be able to follow programming instructions for the
FMC and set it up for autoladning just is not realistic.
Agree, fear would play a major part not just for your own life but
that of the other souls on board.
As stated before the majority of the FMC is obsolete and the aircraft
can be controlled via the MCP and the autopilot. ATC will quite often
vector a pilot with differing headings, speed restrictions and
altitude constraints to that on the FMC flightplan but in most cases
the PIC will use the MCP to make these temporary changes. ATC will
normally vector the pilot back onto an intercept course at some stage
to resume the planned route. Once the ILS frequency and course is
programmed into the NAV/RAD page of the FMC and the aircraft is on an
intercept course pressing LOC will enable the aircraft to capture the
ILS localiser and APP will allow the the capture of the glideslope.
When APP is pressed all 3 autopilots are engaged and thus the autoland
is armed. ATC can instruct you to reduce your airspeed via the control
knob and extend the flaps, landing gear can be lowered and landing
lights and strobes switched on prior to Flaps 20 with continual
slowing using the autothrottle system and further extension of the
flaps. Speed brakes are armed by moveing the spoiler level beside the
throttle to the armed position and Autobrakes can be set using the
rotary dial. Once all wheels are on the ground the trust reverser
levers can be pulled back until your ground speed is 80knots. I'm not
saying it will be a piece of cake but providing the runway is a CAT111
with autoland facilities it will be a hell of a lot easier than having
to disengage the autopilot and autothrottle system and hand fly and
flare the last 200ft then bringing the aircraft to a manual stop.
Yeah, I am sitting at the comforts of my computer, I study day in and
day out of the procedures of a 767 FMC, the above scenario pans out.
You don't think a person wouldn't have a brain fart due to the
adrenalin factor from the chaos developing behind you from the
passengers and yourself saying WTF do I do next?
You may well freak out some of cope better with pressure. I'm not
going to do an MX and say yeah I'm superman no problem.
Clicking on the knob to tune the radio, moving
my mouse just a little bit without my head turnign ain't the real
deal.
TrackIR is a great piece of hardware which interprets highly
accurately your head movement IRL. This changes your view and
position within the 3D virtual flightdeck on screen. I can look left
and right , up/down at the overhead panels, twist my head, lean
forward and back as I would in a real aircraft. All buttons and
switches are where they should be. I dont pretend to know anything
about your GPS you mention but some software vendors do a better job
at modelling components than others i.e. FSX default aircraft versus
the expensive PMDG aircraft. There is also the confines of the
platform. Microsoft created a 'platform' which other developers use
to the best of their abilities. Some elements just cannot be
intergrated in their models as the application doesn't support them.
Flying in my plane, scanning my instruments IN IMC, doing all I can to
reduce the movement of my head to tune my 430 is not the same as
clicking a mouse on my simulator. *Is it the big knob or little knob,
Is it the knob on the right or is it the knob on the left. *Little
knob, what do you mean little knob, I see bunches of knobs. *
That's how the simulator can help. They have 'big' knobs and 'little'
knobs as per the real aircraft
A simulator cannot help you deal with IMC conditions as you cannot
feel the movement of the aircraft. Unless your attention is 100%
fixed on instrument scanning you wont know your in a bank or descent
in the sim.
what page is the approach plate on
Approach plates are there to facilitate the control and management /
seperation of aircraft into/out busy airfields. In an emergency, now
I'm talking about a non-pilot flying, they would not be required. ATC
would HAVE to clear all other traffic out of your way and vector to
the active runway.
MSFS will NEVER simulate the real deal of push, pulling, turning,
tuning ir twisting any aircraft avionics. *It doesn't simulate
reaching across the panel, holding the plane upright (remember, I have
to scan my instruments to remain upright, can't assume autopilot will
do that for you!!)
This is where TrackIR helps enormously. You DO have to look to your
right along the instrumation panel, you DO have to use your right hand
to control knobs and switches via the mouse albeit and you DO have to
lean over to reach or improve your view of certain dials. In this
scenario autopilot would be essential with manual changes to the MCP.
There is NO way I would even consider trying to manually fly a
commerical airliner as keeping it straight and level without
overspeeding or stalling would be very difficult for a beginner.
As I have posted many, many times, and I have used MSFS X. *
Did you use payware aircraft or the default as there can be a world of
difference depending on the vendor
Flying an
approach on the computer just doesn't simulate the physical sensations
of IMC. *Not sure if you ever been in IMC, not even sure if you are a
pilot, but if you never been in IMC, please talk to a IA rated pilot
and ask him to take you up. *You will never look at a cloud the same
way.
you can purchase weather generating programmes which download current
weather METARS and generate appropriate cloud bases, winds, fogs, rain
etc within the sim. I agree the sim cannot generate the feel. I'm
NOT a qualified pilot and have never flown yet in IMC conditions. I
agree hand flying an aircraft in the simulator in IMC can be difficult
as you have zero sensation of movement.
Ibby
Old March 3rd 09, 12:17 PM posted to rec.aviation.piloting
Morgans[_2_]
"BeechSundowner" wrote
As I have posted many, many times, and I have used MSFS X. Flying an
of IMC. Not sure if you ever been in IMC, not even sure if you are a
and ask him to take you up. You will never look at a cloud the same
way.
You might as well give it up with this person, too. It is more likely that
you will have a real 747 qualified pilot on board, than you would likely
find a simmer with the kind of "practiced" on the 747. This one will never
concede, either.
Jim in NC
Old March 3rd 09, 02:42 PM posted to rec.aviation.piloting
Ibby
You might as well give it up with this person, too. *It is more likely that
find a simmer with the kind of "practiced" on the 747. *This one will never
concede, either.
Jim in NC
Believe me I'm nowhere near as bad as MX!!!
Are you saying that all that I have learnt and 'practiced' bears no
correlation to the systems and controls of a real 747-400 because it
does. I have watched a lot of real tutorial dvds (not talking about
little flyby clips on Youtube, but official licensed products on the
747 and 767 flightdecks). The position and behavior of EVERY switch
whether it on the overhead panel, radio panel, Mode Control Panel, the
glass cockpit, the FMC do EXACTLY as the real thing does. I know if I
press 'this' the aircraft will do 'that'. A full procedural checklist
MUST be followed (as per the real thing) for engine start including
APU, ground power, setting pumps to Aux and Auto, turning off packs
etc I know for FACT that if I was to sit down in a 747-400 flightdeck
(forgetting all this emergency landing issue) I could name a huge
majority of the switches, tell you where they are located and the
effect they have on the flight thus giving me some form of advantage
to that of a person who has never been on a flight deck OR used a
simulator/game.
I have openly stated it's a training aid and can successfully
compliment flight training for procedures and navigation flight
planning etc. I know it's not the be-all-and-end all tool that will
give you a PPL after a weeks use which is were MX falls short off. I
know there is a LOT more to learn about the dynamics of flight,
weather systems, regulations etc etc. I know alot of real life pilots
who use it and some are actually prominant members on this forum (but
keep quite), there are those with PPL's, instructors, a retired A320
captain and a retired Gulf War veteran who flew rotaries in the Gulf.
When I took my first flying lesson I felt I could have solo'd, laugh
as you may, but the controls, throttle, pitching, descending, straight
and level flight, torque effects of the prop had ALL been experienced
by me in the sim so I already knew how to compensate for them. I was
turning to certain bearings, climbing/descending to set altitudes,
trimming the aircraft, maintaining set speeds - ALL on my first lesson
and ALL picked up entirely from the sim. As I've already said we all
need real lessons too but the sim CAN help as it has already done for
me.
Ibby
Old March 3rd 09, 10:30 PM posted to rec.aviation.piloting
Maxwell[_2_]
"Ibby" wrote in message
concede, either.
Jim in NC
simulator/game.
me.
Ibby
Really, and how was your landing?
Old March 4th 09, 11:05 AM posted to rec.aviation.piloting
Ibby
I wasn't allowed to land on my first lesson and I would doubt anyone
is but I'm sure your hoping to compare my first lesson to how I, or a
complete novice with zero aircraft experience, would land a commercial
airliner. Landing a small Cessna 152 (with NO AUTOPILOT) requires
manual control of pitch and throttle to retain the required descent
rate and localiser following. Landing an airliner can all be done via
the Autoland system with the press of a few buttons. It doesn't have
to be done manually, you do NOT have to control the yoke or touch the
thrust levers until on the ground. MOST real life landings are done
with this method with the pilot perhaps only disconnecting the
autopilot and autothrottle systems a few hundred feet above ground
level when the aircraft is already established and configured for the
descent path i.e. descent rate, airspeed and lateral position. His
hands will of course remain on the control column and thrust levels in
case he needs to press the TOGA button on the thrust lever in case of
a Go-Around etc.
If a novice or even a PPL pilot had to hand fly an airliner and land
it yes it would more than likely result in disaster but less likely
with the highly technical automation systems available today in the
Next Generation Boeings.
Ibby
Old March 5th 09, 02:53 AM posted to rec.aviation.piloting
Maxwell[_2_]
a Go-Around etc.
Ibby
Oh brother, Mx Jr.
Apology re mxsmanic terry Piloting 96 February 16th 08 05:17 PM
Mxsmanic : Your results are in Mayo Clinic Piloting 13 May 24th 07 02:01 PM
I saw Mxsmanic on TV Clear Prop Piloting 8 February 14th 07 01:18 AM
Mxsmanic gwengler Piloting 30 January 11th 07 03:42 AM
Getting rid of MXSMANIC [email protected] Piloting 33 December 8th 06 11:26 PM
