"Dave Doe" wrote in message g... snip Has anyone used that "quick start" stuff in a spray can -- the ether you spray right into the in filter? Works fine on cars and outboards, probably would work on a/c engines too. Still, having oil too think to flow would do the engine harm. You wanna spray *ether* into your $40,000 Lycoming/Conti? I'd do some *serious* research on that first. -- Duncan I agree. IMHE, ether works well in older diesel engines (without glow plugs) when used correctly and sparingly WHILE cranking (which usually means a two person job or a remote controlled system plumbed into the manifold). However ether is very drying and will remove the oil film on the cylinder walls of engines using dry fuel like gasoline unless mixed with 2 stroke oil. This drying can cause increased cranking resistance and slower cranking. It can also cause severe detonation especially if used to excess. Be very careful if engine is turbo or supercharged. Good luck, |
| Thread Tools | |
| Display Modes | |
| Lycoming engine operations (Lycoming Flyer) | Ron | Piloting | 0 | February 9th 09 12:36 AM |
| Cold weather starting. | Mike Noel | Owning | 17 | December 21st 05 04:24 AM |
| Hard Starting Cold Continental Engines | M.E. Borner | Owning | 16 | December 6th 05 05:13 AM |
| Cold wx starting quirks | Jim Rosinski | Owning | 25 | December 29th 04 09:35 PM |
| Small airport cold-weather starting - Tanis good enough? | Mitchel Gossman | Piloting | 8 | December 2nd 04 06:07 AM |
