We're making propellers over on the Chugger's Group. Right now guys
are mostly gluing-up the blanks that will become propellers. One of the things that needs doing is creating the TEMPLATES that will be needed in the final stages. The templates are in the Files archive, full scale, so all we need to print-out the templates then GLUE them to whatever we're using to make our templates from. Beer can stock will work. Ditto for shim brass, card stock and so forth. Glue the pattern to the paper, cut it out with a scalpel. Or glue it to the metal, SCORE the metal and flex the metal back & forth until it breaks along the line of the score mark. "Doesn't work," sez the Big Fella on the phone. He's been flexing his templates for TWO DAYS and hasn't had one break yet. In doing so he's convinced himself that the PROCESS is in error; that it's impossible to cause beer-can stock to break along the score mark. And along about there he pops the top on a cool one... which of course proves he's wrong. Soup cans. Sardines Bully beef... are all examples of having metal FRACTURE along a SCORE MARK. Clearly then, the process DOES work. Which means, when it DOESN'T the fault must lay somewhere OTHER THAN in the basic principle. (So... where? Probably in the flexing. I recall having some problems with it when I first did it (using shim brass... beer came in STEEL cans back then). The alloy used for shim stock is fairly soft and takes longer to fatigue..) -R.S.Hoover |
wrote in message ... We're making propellers over on the Chugger's Group. Right now guys are mostly gluing-up the blanks that will become propellers. One of the things that needs doing is creating the TEMPLATES that will be needed in the final stages. The templates are in the Files archive, full scale, so all we need to print-out the templates then GLUE them to whatever we're using to make our templates from. Beer can stock will work. Ditto for shim brass, card stock and so forth. Glue the pattern to the paper, cut it out with a scalpel. Or glue it to the metal, SCORE the metal and flex the metal back & forth until it breaks along the line of the score mark. "Doesn't work," sez the Big Fella on the phone. He's been flexing his templates for TWO DAYS and hasn't had one break yet. In doing so he's convinced himself that the PROCESS is in error; that it's impossible to cause beer-can stock to break along the score mark. And along about there he pops the top on a cool one... which of course proves he's wrong. Soup cans. Sardines Bully beef... are all examples of having metal FRACTURE along a SCORE MARK. Clearly then, the process DOES work. Which means, when it DOESN'T the fault must lay somewhere OTHER THAN in the basic principle. (So... where? Probably in the flexing. I recall having some problems with it when I first did it (using shim brass... beer came in STEEL cans back then). The alloy used for shim stock is fairly soft and takes longer to fatigue..) -R.S.Hoover RS, drawn aluminum has a type of grain pattern, like wood. Mebbee you're plastering the cans down in the wrong orientation? Try cutting 90-degrees different? Flash |
Flash wrote:
wrote in message ... We're making propellers over on the Chugger's Group. Right now guys are mostly gluing-up the blanks that will become propellers. One of the things that needs doing is creating the TEMPLATES that will be needed in the final stages. ... Glue the pattern to the paper, cut it out with a scalpel. Or glue it to the metal, SCORE the metal and flex the metal back & forth until it breaks along the line of the score mark. "Doesn't work," sez the Big Fella on the phone. ... -R.S.Hoover RS, drawn aluminum has a type of grain pattern, like wood. Mebbee you're plastering the cans down in the wrong orientation? Try cutting 90-degrees different? Flash If you don't want to use scissors on thin aluminum shimstock, perhaps a hardboard, oil-tempered even, would do the trick. That needs a jigsaw, no doubt. Brian W |
On Mar 14, 8:01*pm, Brian Whatcott wrote:
Flash wrote: wrote in message .... We're making propellers over on the Chugger's Group. *Right now guys are mostly gluing-up the blanks that will become propellers. *One of the things that needs doing is creating the TEMPLATES that will be needed in the final stages. *... Glue the pattern to the paper, cut it out with a scalpel. *Or glue it to the metal, SCORE the metal and flex the metal back & forth until it breaks along the line of the score mark. "Doesn't work," sez the Big Fella on the phone. ... -R.S.Hoover RS, * drawn aluminum has a type of grain pattern, like wood. *Mebbee you're plastering the cans down in the wrong orientation? *Try cutting 90-degrees different? Flash If you don't want to use scissors on thin aluminum shimstock, perhaps a hardboard, oil-tempered even, would do the trick. * *That needs a jigsaw, no doubt. Brian W The thinner, the better, for this purpose. I made my templates way too thick. They worked, but I'd never do it that way again. http://users.lmi.net/~ryoung/Sonerai/Carve_Prop.html And scissors on Coors brand shim stock is fine for straight lines, but it's not accurate enough on curves, IMHO, for this sort of work, plus it tends to crimp the edge. If you can't manage this on aluminum can, try it on card stock with a brand new X-Acto, then varnish the results. Anymore, I scribe and snap ALL my aluminum cuts. The knives used to scribe plexiglass are handy for this, and the ELFA brand truly is superior to any other I've found. But again, as Veeduber pointed out, on beer can stock, a sharp machinist's scribe is all you need. |
" wrote:
We're making propellers over on the Chugger's Group. I've been meaning to ask - what's a chugger (online urban dictionary gives a meaning I'm not sure is the one perhaps intended,) and out of curiosity where is this group? Beer can stock will work. Ditto for shim brass, card stock and so forth. Glue the pattern to the paper, cut it out with a scalpel. Or glue it to the metal, SCORE the metal and flex the metal back & forth until it breaks along the line of the score mark. "Doesn't work," sez the Big Fella on the phone. He's been flexing his templates for TWO DAYS and hasn't had one break yet. Perhaps it's the scoring knife he's using? You probably already know about this, so forgive me if this is redundant, but I've read good things about the Olfa P-800 scoring knife ("Plastic/Laminate Heavy-Duty Ratchet-Lock Cutter (P-800)"): http://www.ch601.org/tools/olfa.htm http://mthobby.pcperfect.com/ch601/chtools.htm This is the online product page: http://www.olfa.com/UtilityKnivesDetail.aspx?C=8&Id=58 |
flybynightkarmarepair wrote:
The knives used to scribe plexiglass are handy for this, and the ELFA brand truly is superior to any other I've found. Spelling of the brand name is Olfa. Their P-800 is specifically designed for scoring. About US$12. |
Dear Flash & Brian,
Scribing & flexing works perfectly well on any thin metal. The harder the alloy, the better. Orientation is of little importance. On thick airfoils such as NACA 0024 ( used for struts, etc ), the curvature exceeds 90 degrees, making the matter of grain moot. The scriber appears to make more difference than the grain in that a #11 scalpel works better than a machinist's scriber. Or perhaps it is the surface on which you lay the metal for scribing. While it works okay using a book or piece of wood, as a general rulle, it works best if the scribing is done atop a metal surface. -R.S.Hoover |
And scissors on Coors brand shim stock is fine for straight lines, but it's not accurate enough on curves, IMHO, for this sort of work, plus it tends to crimp the edge. If you can't manage this on aluminum can, try it on card stock with a brand new X-Acto, then varnish the results. ------------------------------------------------------------------------------------------------- A big Roger on this. Even when using tiny scissors such as for cuticle or those nifty scissors on a Swiss Army knife, it is simply impossible to make a cut having as small a radius as you can get when using a scalpel or X-acto knife. But don''t take our word for this (or anything else :-) Go ahead and try it WHILE WE'RE STILL HERE (ie following the thread). Perhaps we can offer advice you can use. In fact, I'll go ahead and make a separate post covering how to make precision KNIVES suitable for this kind of work. -R.S.Hoover |
| Thread Tools | |
| Display Modes | |
| aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 09:06 AM |
| Alclad Aluminum | mhorowit | Home Built | 11 | December 9th 06 12:16 AM |
| Lye as an aluminum cleaner? | Michael Horowitz | Home Built | 16 | October 29th 06 02:35 AM |
| Glass, or Aluminum? | Jim Kellett | Soaring | 4 | October 26th 04 10:55 PM |
| composites vs. aluminum | John C | Home Built | 23 | May 7th 04 05:31 AM |
