motorgliders as towplanes
Old March 19th 09, 08:22 AM posted to rec.aviation.soaring
The Real Doctor
Default Aerodynamics of Towing
On 19 Mar, 00:03, KevinFinke wrote:
Ian, "The Real Doctor" *Out of curiosity, what exactly do you have a
doctorate in?
Numerical solution of non-linear diffusion problems.Which is actually
a lot more interesting than it sounds.
I can even rearrange the equations in set 1 and get the same
relationships. So, what in the world am I missing when I say Lift =
Weight * cos (glide angle)?
*Smacks head*
Sorry, it was late. I misread, and thought you'd done the old W = L cos
(theta) mistake (W, of course, = L cos(theta) + D sin(theta).
My apologies.
Ian
Old March 19th 09, 05:20 PM posted to rec.aviation.soaring
Jim Logajan
doctorate in?
I didn't know doctorates were awarded quite that way. I always thought they
were awarded in broad fields like math or physics or computer science.
Did you develop some new numerical techniques for such problems? Was your
work done in a math or computer science department?
Old March 19th 09, 06:35 PM posted to rec.aviation.soaring
The Real Doctor
doctorate in?
Well, technically it's just a doctorate over here. It's the thesis
title and contents which matter.
Yup.
Was your
Engineering!
Ian
Old March 19th 09, 12:00 PM posted to rec.aviation.soaring
Bob Cook[_2_]
You can change the reference or axis system all you want, But then you
also change the direction of "down".
Gravity acts downward and no other diredtion.
Lift plus grivity act together and form a resultant force parallel to the
direction of flight. Drag acts in the opposite direction at equal
magnitude.
Gravity (alone) is not the force that provides forward motion to a
glider.
A simple three vector diagram will show this.
Cook
At 00:03 19 March 2009, KevinFinke wrote:
Ian, "The Real Doctor" Out of curiosity, what exactly do you have a
doctorate in?
Aside from that.... In order to seek clarity in all of these
discussions I suspect that we have a mis-understanding because we are
trying to discuss these using two different reference frames. If
that's the case, then that would explain a lot.
I hope that we are all in agreement about the three forces acting on a
glider. For simplicity they are lift(L), drag(D) and weight(W=mg). As
has been corrected by Darryl, I agree that it is correct that lift, by
definition, is perpendicular to the airflow. However, for a glider in
steady state gliding flight, airflow and direction of motion are
parallel. Any body have any problems so far? I'm hoping this will get
me out of the hen house...
If we align the axis system such that weight is vertical and the
descent angle is theta. The equilibrium equations a
Vert. Axis 0 = L*cos(theta) + D*sin(theta) - W
Horz. Axis 0 = L*sin(theta) - D*cos(theta)
I'm guessing this is the source of the Lift providing the horizontal
motion argument. Clearly there is no gravity term in that component.
But the motion isn't strictly horizontal or vertical with these
equations. It is both, and therefore I would advocate a simplified set
where the direction of motion is the basis for the axis system.
Therefore....
If the axis system is aligned along the lift vector the equations
simplify to: (For the sliding block this tends to be the convention
that most books I own present) Replace L with N for Normal.
Lift Axis 0 = L - W*cos(theta)
Drag Axis 0 = D - W*sin(theta)
Any objections so far? I sure hope not. I can't imagine how....
The nice thing about convention 2 is that the lift and drag vectors
are isolated variables in the equation, and the weight is already
known so it's easy to solve the other values.
L = W*cos(theta) and D=W*sin(theta)
Weight * cos (glide angle)? Ian, you are the real doctor. I'll confess
my ignorance. I don't want to guess, cause I just don't know what
answer you're looking for, but what did I forget?
The other advantage of using convention 2 is in describing the motion
of the system. The object is constrained to the plane, and therefore
you can get rid of the "vertical" axis in this example and look at the
equation with one dimension. Because the lift force or normal force
constrains the object to the plane, you'll have no accelerations or
displacements in this direction, for a steady state example. In this
case that would be it's glide path. The only equation left is D = W*sin
(theta) So again I argue, Lift, because it is perpendicular to the
direction of motion, can not provide the motive force! The motive
force is governed by a balance between gravity, drag, and the glide
angle. Don't get me wrong, I'm not saying lift isn't important. It is
very important to making the glider stay on a glide path. Maybe this
is just a chicken before the egg argument. I can see the circularity
of the discussion. Why do those chickens keep coming up....
This would be a whole lot easier to explain with pictures. So I'll
cite a reference...If anybody has a copy of the BGA Manual: "Gliding:
Theory of Flight", please reference the discussion of forces on flight
in Chapter 4. The book goes through a very good explanation of how
gravity provides the motive force for gliding. It's an excellent book
and I highly recommend it. If only it had a discussion of forces on
tow....
-Kevin
PS I think we need some good flying weather so that we all get out of
the house and away from the computer....
Old March 19th 09, 12:53 PM posted to rec.aviation.soaring
Doug Hoffman
magnitude.
glider.
Maybe we are wordsmithing/semanticizing a bit. Take away gravity and
air movement and place a glider somewhere up in the still air (I know,
suspend disbelief for a moment) and let go of the glider. No initial
motion is given to the glider, it is just "suspended in air". How much
lift and/or forward motion do we then get? None. Add gravity to the
same scenario and the glider will then move forward (after an initial
drop). So perhaps gravity *is* the sole force required for forward
motion. Of course we need air as well. But still air is a gaseous
mass, not a force or even a source of force. The reaction force caused
by the combination of gravity (sole source of force) and the presence of
air (air is not a force) leads to the forward motion of the glider.
Regards,
-Doug
Old March 19th 09, 01:45 PM posted to rec.aviation.soaring
Bob Cook[_2_]
Dude!
You can pretend there is no gravity. You can pretend there is no air.
But there IS gravity, and there IS air.
Gravity is a downward force. Things move downward due to gravity,
including gliders.
But the question was not "what gives a glider motion?", it was "what
gives a glider FORWARD motion?"
Sorry, can't do it without LIFT. (don't forget drag either)
Three forces act on a glider. Not one, not two, THREE.
Answer to question again: The resultant force of lift added to gravity,
balanced by drag.
Cookie
At 12:53 19 March 2009, Doug Hoffman wrote:
you
magnitude.
glider.
Regards,
-Doug
Old March 19th 09, 05:39 PM posted to rec.aviation.soaring
Jim Logajan
including gliders.
Aren't there some things that move upward due to gravity? Even upward and
sideways too?
But isn't there only one potential energy field operative? Not two, or
three, just one? Didn't Aharonov and Bohm show that potentials are more
"fundamental" than forces, so that we should really be considering the
system using potentials?
Is somebody keeping score on the pedantry? I hope I got at least a couple
points!
Old March 19th 09, 01:00 PM posted to rec.aviation.soaring
Bob Cook[_2_]
I just gotta laugh. When Internet "arguements" get heated or go nowhere,
people resort to a comparison of "qualifications".
As if the guy with the longer resume is somehow always correct.
BTW, my qualificatons: Airport Bum.
Cookie
doctorate in?
Derek Copeland[_2_]
I think you would find that a glider flying though air would stop moving
pretty quickly if you could turn off gravity! There would still be lift
and drag until it stopped, but nothing to drive it forward.
Derek Copeland
At 12:00 19 March 2009, Bob Cook wrote:
Gravity acts downward and no other direction.
magnitude.
glider.
Cook
Old March 20th 09, 12:13 AM posted to rec.aviation.soaring
Mike Schumann
Weight is a force????? Did I miss something in HS Physics? Weight = Mass.
Mike Schumann
"KevinFinke" wrote in message
doctorate in?
Therefore....
tow....
-Kevin
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
