On 19 Mar, 19:48, Martin Gregorie
wrote: There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. Oh no. Not that one. At the surface of the wing, it exerts a force on the air mass. A long distance away (typically 2 chord lengths) it's a momentum change. In between the effect of the wing is a pressure change /and/ a momentum change. Overall, the integrated pressure across the top surface is about 70% of the total lift force, and the intergrated pressure across the bottom surface is about 30% of the total lift. Significance? Irregularities on the top surface will reduce lift by more than the same irregularities on the bottom surface. Hence top- surface-only airbrakes: they are more effective there than underneath, because they destroy more lift, necessitating a bigger and draggier change of AoA to compensate. Ian |
On Fri, 20 Mar 2009 02:39:17 -0700, The Real Doctor wrote:
On 19 Mar, 19:48, Martin Gregorie wrote: There is a question in the UK Bronze badge written paper about the proportion of lift provided by the top and bottom surfaces of a wing that's just as wrong. The so-called "correct" answer is 70/30, but as a wing is a device for imparting momentum to an air mass its a meaningless question. Oh no. Not that one. At the surface of the wing, it exerts a force on the air mass. A long distance away (typically 2 chord lengths) it's a momentum change. In between the effect of the wing is a pressure change /and/ a momentum change. Overall, the integrated pressure across the top surface is about 70% of the total lift force, and the intergrated pressure across the bottom surface is about 30% of the total lift. Significance? Irregularities on the top surface will reduce lift by more than the same irregularities on the bottom surface. Hence top- surface-only airbrakes: they are more effective there than underneath, because they destroy more lift, necessitating a bigger and draggier change of AoA to compensate. True enough, but the point I was trying (badly) to make is that the lift is due to the whole wing section and shouldn't be apportioned to the two surfaces as a number taught to neophytes. Apart from anything else this breaks down when you consider the pressure distribution across the top surface. Why not also teach an arbitrary percentage of lift generated by the LE suction spike at high Cl? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
At 19:48 19 March 2009, Martin Gregorie wrote:
On Thu, 19 Mar 2009 13:09:30 -0500, Jim Logajan wrote: You're claim conflicts with that in the FAA "Pilot's Handbook of Aeronautical Knowledge": "Found on many gliders and some aircraft, high drag devices called spoilers are deployed from the wings to spoil the smooth airflow, reducing lift and increasing drag." Printing it in some official or semi-official publication doesn't make it right. But it *does* make it the right answer to the written test when that test is given by that same authority. For the test, concentrate not on what is necessarily true, but on what the FAA wants for an answer. After the written is out of the way, just learn to fly the aircraft. Jim Beckman |
On Fri, 20 Mar 2009 14:30:04 +0000, Jim Beckman wrote:
But it *does* make it the right answer to the written test when that test is given by that same authority. For the test, concentrate not on what is necessarily true, but on what the FAA wants for an answer. After the written is out of the way, just learn to fly the aircraft. Yes, and I learnt it as the answer to that Bronze question. It just annoys me that official publications should enshrine myths as some sort of truth. Its no better than introductory texts showing packets of air dividing at the LE of a ring and meeting up again at the TE, when a photo taken in a wind tunnel shows clearly that doesn't happen. Far better to publish the photo than a bogus diagram. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 21 Mar, 16:48, Martin Gregorie
wrote Its no better than introductory texts showing packets of air dividing at the LE of a ring and meeting up again at the TE, when a photo taken in a wind tunnel shows clearly that doesn't happen. Far better to publish the photo than a bogus diagram. Oh, that one drives me mad. Not only does it not happen ... there is no conceivable reason why it should happen. And yet many many websites and books cite it as fact. Grrrrrrrrrrrrrrrrrr. Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Ian |
On Sat, 21 Mar 2009 12:28:59 -0700, The Real Doctor wrote:
Incidentally, if you don't have a copy of "An Album of Fluid Motion" by Milton Van Dyke, get it. You'll love it. Every gliding club should have one. Another recommendation: http://www.av8n.com/how/ gives a good description of how an aeroplane works. A lot of it is similar to "Stick and Rudder", so its written for pilots rather than aircraft designers. However, section 3 has excellent descriptions and diagrams showing how a wing works. It was recommended to me by a professional aerodynamicist who is a model designer and has flown gliders. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 19 Mar, 12:15, Bob Cook wrote:
Spoilers redistribute lift, but not reduce lift. They reduce the lift over part of the wing. Whether the overall lift increases, decreases or stays the same depends on what the pilot does. Flaps change the coeffecient of lift, but not lift. If you keep everything else the same then they do change lift. Every tried dumping your landing flap just before the flare ...? Q) *Two gliders, one is 40:1 racer and glider two is 20:1 trainer. Both weigh 800# Glider one has twice the lift of glider two. *True or flase and why. Depends what they are doing. Ian |
OK. badly worded question.
Here I was trying to point out that DRAG is the major difference between a 40:1 glider and a 20: glider. Not lift, not gravity. Drag determines the direction of flight. More drag= steeper glide (spoilers, flaps) Less drag = flatter glide Cookie At 18:23 19 March 2009, The Real Doctor wrote: On 19 Mar, 12:15, Bob Cook wrote: Spoilers redistribute lift, but not reduce lift. They reduce the lift over part of the wing. Whether the overall lift increases, decreases or stays the same depends on what the pilot does. Flaps change the coeffecient of lift, but not lift. If you keep everything else the same then they do change lift. Every tried dumping your landing flap just before the flare ...? Q) =A0Two gliders, one is 40:1 racer and glider two is 20:1 trainer. Both weigh 800# Glider one has twice the lift of glider two. =A0True or flase and why. Depends what they are doing. Ian |
Ian,
If we draw vector force diagrams of two identical gliders, one with flaps extended, and the other with flaps retracted, we can easily see that "lift" is essentially the same in both cases. The direction of flight will be steeper with flaps extended, and drag will be signifigantly greater. As for spoilers, vector diagrams will also show lift is not reduced (except for a tiny, tiny amount) but drag is greatly increased and the fligth path is steepened. Remember were are talking about stabilized unaccelerated flight here. Sudden application or retraction of flaps might have MOMENTARY changes in lift, but not once stabilized unacellerated flight is resumed. Misconceptions commonly found in publications and professed by many "experts": Gravity powers a glider and provides forward motion. Flaps increase lift Spoilers reduce lift Centrifugal force turns a glider Aircraft climb due to increased lift Aircraft descend due to reduced lift Any more? Cookie At 01:00 20 March 2009, Bob Cook wrote: OK. badly worded question. Here I was trying to point out that DRAG is the major difference between a 40:1 glider and a 20: glider. Not lift, not gravity. Drag determines the direction of flight. More drag= steeper glide (spoilers, flaps) Less drag = flatter glide Cookie At 18:23 19 March 2009, The Real Doctor wrote: On 19 Mar, 12:15, Bob Cook wrote: Spoilers redistribute lift, but not reduce lift. They reduce the lift over part of the wing. Whether the overall lift increases, decreases or stays the same depends on what the pilot does. Flaps change the coeffecient of lift, but not lift. If you keep everything else the same then they do change lift. Every tried dumping your landing flap just before the flare ...? Q) =A0Two gliders, one is 40:1 racer and glider two is 20:1 trainer. Both weigh 800# Glider one has twice the lift of glider two. =A0True or flase and why. Depends what they are doing. Ian |
On 20 Mar, 01:15, Bob Cook wrote:
If we draw vector force diagrams of two identical gliders, one with flaps extended, and the other with flaps retracted, we can easily see that "lift" is essentially the same in both cases. What happens if you extend the flaps on a glider while keeping everything else (AoA, airspeed) constant? Ian |
Seeking towplanes for Region 9 | [email protected] | Soaring | 0 | May 17th 06 12:03 AM |
US:Restricted Towplanes | Judy Ruprecht | Soaring | 8 | November 5th 04 11:27 PM |
Standard Nationals Need Towplanes | C AnthMin | Soaring | 5 | July 14th 04 12:46 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
