motorgliders as towplanes
Old March 20th 09, 12:15 PM posted to rec.aviation.soaring
Bob Cook[_2_]
Default aerodynamics of gliding
That would not be possible......only "momentary". You can't "keep"
"everything else" constant.
Yes, there would be a "momentary" increase in lift......but......
Glider would experience "acceleration", change in velocity, and or
direction. (Most likely glider would "nose up" (change in direction)
then "slow down" (change in velocity) finally resume steady flight with
greater drag giving steeper glide angle.
Once "stabilized" flight is resumed, vector analysis shows flaps do not
increase lift. Yes, the coefficient of lift has changed but not the
actual lift (other than a really, really tiny reduction due to new flgith
path)
Similar for spoilers
Cookie
At 09:40 20 March 2009, The Real Doctor wrote:
On 20 Mar, 01:15, Bob Cook wrote:
If we draw vector force diagrams of two identical gliders, one with
flaps
extended, and the other with flaps retracted, we can easily see that
"lift" is essentially the same in both cases.
What happens if you extend the flaps on a glider while keeping
everything else (AoA, airspeed) constant?
Ian
Old March 20th 09, 01:29 PM posted to rec.aviation.soaring
You guys have proven 2 fundamental truths.
1) In any engineering discussion. If you don't define terms at the
start, you just chase yourself around in a circle.
2) Pilots don't need to know much about aerodyanmics to fly well.
Oh yeah,
3) Flight instructors explain these things more to make a point than
to be accurate :-)
Todd Smith
3S
Old March 20th 09, 02:58 PM posted to rec.aviation.soaring
"The Real Doctor" wrote in message
If we draw vector force diagrams of two identical gliders, one with flaps
Ian
I have really been trying to avoid getting involved in this thread. It seem
too much like "I'm smart and you're not". However, I just want to point out
that to maintain the same AoA while lowering the flaps will require the
pilot to lower the nose of the aircraft. This is due to the change to the
wing's effective angle of incidence.
I really question if it is posible to lower to flaps while keeping the AoA
and airspeed constant. I know that maintaining a constant airspeed of 50
kts while lowering the flaps to 90 degrees on my HP-14 results in a 45+
degree nose down attitude. I am positive the wing's AoA changes while doing
so.
Respectfully,
HP-14 "6F"
http://www.soaridaho.com/Schreder
Seeking towplanes for Region 9 [email protected] Soaring 0 May 17th 06 12:03 AM
US:Restricted Towplanes Judy Ruprecht Soaring 8 November 5th 04 11:27 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Take-upReels on Towplanes Nyal Williams Soaring 9 April 21st 04 12:39 AM
Helicopters and Towplanes Burt Compton Soaring 6 September 11th 03 05:21 PM
