Winch Launch Safety Study
Old March 24th 09, 05:30 PM posted to rec.aviation.soaring
Derek Copeland[_2_]
Default Winch Launch Safety Study
At 16:35 24 March 2009, bildan wrote:
Derek, I have more experience with ground launch than you are likely
to achieve in your lifetime.
No, Derek, Only YOU disagree. All you are doing is "Bible Pounding"
hoping that by repeating the same thing over and over ever more loudly
people will accept it on faith. I think people are smart enough to
demand proof. I accept nothing on faith. I want engineering
measurements to support each and every detail.
Furthermore you are the sales representative for a particularly bad
winch design seeking to discredit all other approaches any way you
can. If you aren't being paid for this, you should demand to be.
Bill,
1) So how many winch launches HAVE you done? I have made over 5000 autotow
and winch launches at a number of sites over a 28 year period, both solo
and as an instructor (combined that is).
2) What engineering measurements can you provide? To the best of my
knowledge, nobody has yet found a 100% successful way of measuring winch
cable tension. The cable speeds are too high for Rolling Line
Tensiometers, so this generally has to be derived from torque or throttle
settings.
3) Other than being a satisfied user of Tost and Skylaunch winches, I have
no financial connections to any manufacturer.
Derek Copeland
Old March 29th 09, 04:28 AM posted to rec.aviation.soaring
Gerhard Wesp[_9_]
On 22 Mrz., 03:24, bildan wrote:
And just as often I've challenged you to produce ANY engineering data
to support your mere opinion. *You have not and I believe you cannot.
That seems like elementary rigid body mechanics to me. In this case
calculations trump measurements due to the well-understood nature of
physics and the inherent errors of any measurement.
A simple longitudinal simulation model should be well sufficient to
gain
good insight into these types of accidents. Would be an interesting
subject
for a followup article.
Best regards
--Gerhard Wesp
Old March 24th 09, 04:48 PM posted to rec.aviation.soaring
bildan
On Mar 20, 7:00*am, Derek Copeland wrote:
As I have tried to explain to Bill on numerous occasions, and on various
forums, the uncontrollable over-rotation you get from an over-powered
winch launch is caused by the pull line to the belly hook being below the
glider's centre of gravity and centre of pressure. This causes a rotation
for mechanical rather than aerodynamic control reasons. This is why high
winged gliders, such as the K6 and K8 are most at risk.
I understand this exactly and have wrote about it for many years.
Almost all gliders currently in use have no risk at all of
"mechanical" over-rotation. Does a G103 have "Uncontrollable Over-
rotation"?
The "Over powered" launches you speak of are strictly limited by the
weak link to slightly over one G which is a trivial value. Nothing
violent happens at one G unless the pilot initiates it.
Old March 25th 09, 07:45 AM posted to rec.aviation.soaring
Derek Copeland[_2_]
No a Grob G103 is not prone to 'uncontrollable over-rotation' after
lifting off on a winch launch, because it has low set wings, hence a low
centre of gravity, a slightly forward set belly hook, and it's quite
heavy. Depending on the model, it either launches on a relatively weak red
or brown link, so it is prone to weak link failures, as is identified in
the Aerokourier report. So you need to be careful about overpowering it
for a different reason.
However there are many types that are prone to over-rotation, particularly
K6, K7, K8, K13, Standard Cirrus, and many other types of single seater.
In that it is very rare to break a weak link during the ground run,
however violent, it is likely that you can get much faster acceleration
than 1.2g. I think this is because of the fact that the glider is on
wheels and unloads the weak link as it rolls and accelerates forward. If
you where pulling against a concrete block set into the ground, you would
break the weak link every time at the same force. If the weak link does
break as a result of an overpowered launch, it usually does so sometime
during or just after the rotation, which is at the worst possible time! If
you drive a winch (which I do) you can feel the load on the cable increase
as the glider rotates, even if the throttle or tension setting remains
constant.
Have a look at the following video showing a K13 being winch launched:
http://www.youtube.com/watch?v=KUsqw0OwMZA
Note that after a slightly protracted 'take up slack' the tailwheel goes
down onto the ground when the winch driver opens the throttle and stays
there until the glider lifts off, if anything slightly mainwheel first.
This is despite the elevator being held slightly lower than neutral (stick
forward of centre), as it should be. If you have a K13 available, try
sitting two 180lb men plus parachutes in it and then push down down on the
tail until the tailwheel touches the ground. You will find that this
requires quite a lot of force, which illustrates just how powerful the
rotational couple must be.
Derek Copeland
At 16:48 24 March 2009, bildan wrote:
various
rotation
high
rotation"?
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 07:06 AM
Winch Launch Videos Mike Schumann Soaring 2 January 19th 06 11:27 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Safety of winch launch vrs. aero tow? Gary Boggs Soaring 172 November 13th 03 06:59 PM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
