A few points to add to this.
1) The pilot should also be prepared to abandon the launch if a wing drops during the ground run. In the UK it is recommended that the pilot keeps his hand on the release knob during the ground run. 2) I always hold the stick in an appropriate setting for the glider type, generally always forward of centre, and then rest my arm or elbow against either my thigh or the side of the cockpit. That way I will not inadvertantly pull the stick back due to the effects of acceleration and inertia. 3) Always do your straps up as tightly as possible for a winch launch, and if the rudder pedals are easily adjustable, set them a bit closer than normal. If you need back cushions, make sure that they are made of a firm material. Several fatal winch launching accidents in the UK have been caused by pilots slipping back up the seat, or sinking back into soft foam cushions, again due to rapid acceleration and inertia. Possibly another good reason for limiting acceleration rates! Derek Copeland At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K |
On 27 Mrz., 12:00, John Roche-Kelly
wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). Yes, yes, of course. I didn't mean to give the impression I would like to be accelerated to the limits of the weak link - that would be quite frightful. But bildan was throwing wrong figures about and claiming (indirectly) the weak link limits the acceleration to safe levels. Marcel |
Despite the alleged 'bildan tension spikes' from the automatic gearboxes
fittes to many current winches, in my experience weak link breaks during the ground run are extremely rare. If you do get a very overpowered launch, the weak link will normally break towards the end of the rotation or early in the full climb. The best video example I can find on youtube is: http://www.youtube.com/watch?v=jvK1ONl1CqE This launch was on a diesel powered winch (also favoured by bildan) where you typically get a rather slow initial ground run acceleration, followed by a sudden snatch into the air and often a considerable overspeed for lighter gliders. The video also shows what happens if you don't lower the nose quickly enough after a launch failure. The pilot allows the glider to stall, after which it never regains enough airspeed to round out. The glider (ASW15) suffered a collapsed undercarriage and other minor damage, and the pilot a bruised back. Fortunately nothing more serious, as it looks at one point as if the glider might spin. Otherwise weak links normally only break near the top of the launch, where they are doing their job in protecting the airframe. Derek Copeland At 16:07 27 March 2009, MaD wrote: On 27 Mrz., 12:00, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). Yes, yes, of course. I didn't mean to give the impression I would like to be accelerated to the limits of the weak link - that would be quite frightful. But bildan was throwing wrong figures about and claiming (indirectly) the weak link limits the acceleration to safe levels. Marcel |
Also the wing tip runner should hold the wing at the correct height, too
many hold a high wing too low and a low wing too high. At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K |
![]() "Alan Garside" wrote in message ... Also the wing tip runner should hold the wing at the correct height, too many hold a high wing too low and a low wing too high. At 11:00 27 March 2009, John Roche-Kelly wrote: I think you may be missing the point here. The weak link is to protect the glider airframe from exceeding maximum loading ie towards the top of the launch, with the cable almost vertical and the wing loading at its maximum. Using these calculations to determine the best acceleration at the start of the launch is bad math(s). The acceleration on the ground should be safe. Too high and the inertia of the stick and the pilot's hand will cause backward movement, with self-evident results. Too slow and aileron authority is not achieved quickly enough to prevent wing drop and possible cartwheel! Typically aileron authority is present just below the stall speed so the acceleration should be sufficient to get to that speed before a wing can drop, say 2 seconds or so. Now do the math(s) for your glider. Typical stall speeds are below 35 kt (17 metres per second). This gives an acceleration of less than 1g which will comfortably be tolerated by any pilot. If continued the acceleration will have the glider fully flying and high enough to begin the rotation into full climb in another second or two. Broken weak links at the start of the ground run are generally due to a snatched All Out. The launch marshal must ensure that there is no slack in the cable before giving All Out by waiting for a genuine movement of the glider. The wing tip holder must move forward with the glider for as long as possible. The wing tip holder should abort the launch if he or she has to hold the wings level, they should do so naturally or the wing will drop on release. Best wishes JohnR-K To the tune of 'Donald whers yoo trooses' (Scottish folk song) "Let the wing go high let the wing go low"......you get the drift. JRS |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Safety of winch launch vrs. aero tow? | Gary Boggs | Soaring | 172 | November 13th 03 06:59 PM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
