headset feedback loop during xmit
Old April 25th 09, 02:54 AM posted to rec.aviation.owning
Mike Noel
Default headset feedback loop during xmit
My Telex 30 headset and SL30 nav/com have developed a loud and annoying
oscillation during xmit. The tone is both obvious in the headset side-tone
and also is heard by other's listening on the frequency.
I've tried two other headsets (a DRE ENR and a non-ANR headset) and both
work fine with the SL30. My com2 is a King 97a and it works fine with all
of my headsets, including the Telex.
The problem seems to have developed in stages over the past several months.
First I was noticing the Telex and SL30 would occasionally give my voice a
hollow sound for the first few transmissions of the day, then sound fine.
Finally last week the tower controller mentioned the squeal which I was also
noticing. It tends to go away after a bit but it sounded odd for the entire
flight.
Has anyone experienced a similar problem? I'm hoping to try a few other
brands of headsets this weekend to see if the headset is the likely culprit.
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
Old April 25th 09, 12:25 PM posted to rec.aviation.owning
Mike,
I am also having some issues with a Telex Stratus 30 ANR headset. I
have three theories I'm working on.
Making sure the cabin speaker is turned off at the audio
panel.
We've had issues with all tranmissions based on how close we
were to the receiver (we're based real close to the tower).
Trying non-rechargable batteries.
It's pretty frustrating to lay out 4 bills and not being able to use
the headset.
HTH
Chris
On Fri, 24 Apr 2009 17:54:12 -0700, "Mike Noel"
flight.
Best Regards,
Mike.
Old April 25th 09, 02:55 PM posted to rec.aviation.owning
Mike Noel
Hi Chris...I'm getting the feedback while sitting in my hangar xmitting on
123.45, I've tried several sets of regular alkaline batteries, and I have
the cabin speaker turned off.
Best Regards,
Mike.
Mike,
panel.
the headset.
HTH
Chris
side-tone
months.
also
entire
flight.
culprit.
Best Regards,
Mike.
Old April 26th 09, 07:47 PM posted to rec.aviation.owning
123.45, I've tried several sets of *regular alkaline batteries, and I have
Best Regards,
Mike.
Mike,
I am also having some issues with a Telex Stratus 30 ANR headset. *I
panel.
the headset.
HTH
Chris
oscillation during xmit. *The tone is both obvious in the headset
side-tone
work fine with the SL30. *My com2 is a King 97a and it works fine with all
months.
also
noticing. *It tends to go away after a bit but it sounded odd for the
entire
flight.
Has anyone experienced a similar problem? * I'm hoping to try a few other
culprit.
Best Regards,
Mike.
I would wonder about a bad ground within the headset. The ground for
the mike and headphone circuits are the same, and if one ground wasn't
connected properly inside one of the plugs or at the cable within the
set, it might cause the feedback via "ground-looping" through the
other.
Dan
Old April 26th 09, 09:11 PM posted to rec.aviation.owning
klp
You might also try placing a ferrite ring on the mike lead near the
headset. Presently the mic or mic leads are picking up the strong RF
signal from your transmitter & some of the active elements in the mike
are demodulating it. You can get ferrite chokes from misc computer
hardware, misc cables, or maybe even Radio Shack. You will have to
fiddle with the placement etc until you can get rid of the squeal.
Jim Weir (RST Electronics) would have the best answers though, and I'm
sure can fixed this problem.
Jim - are you out there?
Old April 27th 09, 04:52 PM posted to rec.aviation.owning
Mike Noel
Thanks for the suggestions. I also contacted Telex support and they suggest
to first try reducing the microphone gain (CCW) before sending the unit back
to them. I'll follow up later with the results.
Best Regards,
Mike.
"Mike Noel" wrote in message
side-tone
months.
also
entire
flight.
culprit.
Best Regards,
Mike.
Old April 30th 09, 12:23 AM posted to rec.aviation.owning
Mike Noel
Adjusting the mic gain made no difference and so the headset went back to
Telex for warranty repair (36 month warranty on the Stratus 30 and 60 months
for the Stratus 30XT). I'll report back later on my warranty repair
experience with them.
It's a nice headset at a moderate price so I hope I can report back
favorably.
Best Regards,
Mike.
side-tone
months.
also
entire
flight.
culprit.
Best Regards,
Mike.
Old May 3rd 09, 07:03 PM posted to rec.aviation.owning
Bill
Mike,
This problem is likely caused by Radio Frequency feedback into the
headset from
your transmitter. The transmitted RF field is fairly strong in the
cockpit;
something in the headset demodulates the RF and the resulting audio
feeds back around into the comm radio making the squeals.
It will be worse on some frequencies than others. Sometimes a radio
connected to an antenna on the top or top front of the cabin will be
worse. More power in the transmitter will be worse. The SL-30 has
more RF power than the '97 so could easily be more susceptible.
In Bonanzas, with the batwing antenna right over the cabin, and all
that glass, RF feedback is particularly troublesome.
I once had a Plantronics mic with a small wart on the cable that had
the problem. I wrapped the wart (which had all the semiconductors
that rectify in it) with sticky copper tape and that fixed the
problem.
I've seen the problem a lot with Telex headsets. For awhile they
were the worst. I thought they had solved this problem long ago. It
is a design problem. A headset should be designed with margin
and be bullet proof enough to work in any cockpit without feedback.
The Bose I (and to a smaller extent the X models) have sensitivity to
the frequencies used by ATC radar. When you are sitting on the
ground near one of those rotating antennas, you can hear it zip by
every time it points in your direction. But these headsets are OK at
the usual
VHF frequencies we transmit on, so there is no feedback with them.
It is true that if your cabin speaker is on while you transmit (very
unlikely)
that you could get acoustic feedback and lowering the mic gain might
fix it. But changing the gain will have little effect on RF feedback.
Bill Hale BPPP instructor bppp.org K0QA
Zillions of headset types flown in BPPP clinics
for the Stratus 30XT). *I'll report back later on my warranty repair
favorably.
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/"Mike Noel" wrote in message
side-tone
months.
also
entire
flight.
culprit.
Best Regards,
Mike.
Old May 4th 09, 11:32 AM posted to rec.aviation.owning
Stealth Pilot[_2_]
flight.
Best Regards,
Mike.
sure have and Jim Weir gave me the answer twice, about 8 years apart.
corrosion between the antenna wire and the antenna mount causes the rf
to fail to make it into the antenna so it gets radiated inside the
aircraft, gets picked up in the mike boom and feeds back through the
radio as an unholy squeal.
in my case the antenna mount and the base to the wire are both brass
so a good going over with brasso and a toothbrush has cleaned away the
crud and restored the radio to perfect service each time.
the second time while beavering away I though 'I've had to do this
before????' ages later the memory of the first time returned.
thanks Jim
Stealth Pilot
Old May 4th 09, 06:57 PM posted to rec.aviation.owning
Ross
Bill wrote:
Mike,
headset from
cockpit;
problem.
the usual
unlikely)
favorably.
Best Regards,
Mike.
side-tone
months.
also
entire
flight.
culprit.
Best Regards,
Mike.
I would get the same ASR sweep beep in my lightspeeds at an airport that
that the radar on the field.
Regards, Ross
C-172F 180HP
Sold
KSWI
Alternator noise on Xmit only Vaughn Simon Owning 7 July 2nd 08 09:22 PM
outside loop niceguy Aviation Photos 13 August 9th 07 07:57 AM
My Ground Loop Reid & Julie Baldwin Piloting 53 December 6th 05 12:29 AM
More likely to ground loop? [email protected] Piloting 16 February 25th 05 04:21 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 09:18 PM
