As an instructor,one of my favorite tricks is to set the altimeter
about 800ft low before the student gets in. The student inviably turns the knob 200ft to minus 600ft, 1000ft lower than our field. Then I keep asking how things look. Gets'em every time! The lesson: Believe your eyes over the instruments! On Apr 29, 7:59*pm, Michael wrote: Hi all, My checkride is a long way off, but this evening I read the PTS for Gliders for the first time. *I noticed this section: "Use of Distractions During Practical Tests Numerous studies indicate that many accidents have occurred when the pilot has been distracted during critical phases of flight. To evaluate the applicant’s ability to utilize proper control technique while dividing attention both inside and/or outside the cockpit, the examiner shall cause a realistic distraction during the flight portion of the practical test to evaluate the applicant’s ability to divide attention while maintaining safe flight." Obviously, the Examiner isn't going to do anything dangerous, but what sorts of distractions have people encountered? *It is obvious when the distraction occurs....or is it something subtle? --Michael |
In article
, GARY BOGGS wrote: As an instructor,one of my favorite tricks is to set the altimeter about 800ft low before the student gets in. The student inviably turns the knob 200ft to minus 600ft, 1000ft lower than our field. Then I keep asking how things look. Gets'em every time! The lesson: Believe your eyes over the instruments! That's a good lesson, since the weather can do this to you too. The one time I did it, I managed to do it to *both* altimeters in a two-seater, and only discovered the error after getting off tow. Then I asked my passenger what his read and found out that I did it to both seats. No big deal as long as you're alert, of course, but I learned something that day. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
GARY BOGGS wrote:
As an instructor,one of my favorite tricks is to set the altimeter about 800ft low before the student gets in. The student inviably turns the knob 200ft to minus 600ft, 1000ft lower than our field. Then I keep asking how things look. Gets'em every time! The lesson: Believe your eyes over the instruments! Interesting. If your field elevation is under 1000 ft MSL I would have assumed that the thousand-foot indicator pointing just left of zero would be a tipoff. |
![]() Interesting. If your field elevation is under 1000 ft MSL I would have assumed that the thousand-foot indicator pointing just left of zero would be a tipoff. You'd think - but it ain't so for about half of the folks I pull that trick on. Tony LS6-b "6N' |
TonyV wrote: Interesting. If your field elevation is under 1000 ft MSL I would have assumed that the thousand-foot indicator pointing just left of zero would be a tipoff. You'd think - but it ain't so for about half of the folks I pull that trick on. It's too easy to see that hand where you "know" it is instead of where it really is, when you're paying most of your attention to the 100s hand anyway. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
These are all good tests. In my 7 years as a basic instructor flying first
flights I have had only one real problem flight,that was when a" Lady " started to scream at about 100ft and didn't stop untill we finished the landing roll .Far more distracting because she could not be talked round and would not shut up. We beat the tug back. At 04:44 01 May 2009, Mike Ash wrote: In article , TonyV wrote: Interesting. If your field elevation is under 1000 ft MSL I would have assumed that the thousand-foot indicator pointing just left of zero would be a tipoff. You'd think - but it ain't so for about half of the folks I pull that trick on. It's too easy to see that hand where you "know" it is instead of where it really is, when you're paying most of your attention to the 100s hand anyway. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
GARY BOGGS wrote:
As an instructor,one of my favorite tricks is to set the altimeter about 800ft low before the student gets in. LOL! I do that too. Our field elevation is about 500 MSL and before the student gets in, I'll set it to -500 MSL. Getting back to examiner distractions and/or other things. My students have reported among the following: - miss-setting the altimeter as per above before flight when the applicant is not looking - purposely failing to lock the canopy (easy to do in a 2-33, more difficult in other aircraft). - suggesting chasing distant or downwind thermals. - raising/lowering the gear while the examiners says "look at that airplane over there". - blocking the spoiler handle with his knee. - suggesting a much longer downwind. You get the picture. Tony V |
I don't see how a mis-adjusted altimeter gets by the pre-flight
checklist. Instruments: altimeter set to field elevation? Mike |
On May 1, 6:01*am, Mike125 wrote:
I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? Mike Do I detect a bit of "invulnerability" there. ![]() It is easy to not be able to see how it can happen, until it happens to you. Under the right circumstances it can be very easy to do. To the point even a highly trained, F16 Thunderbird pilot can do it i.e. Mountain Home AFB Crash. Brian CFIIG/ASEL |
In article
, Mike125 wrote: I don't see how a mis-adjusted altimeter gets by the pre-flight checklist. Instruments: altimeter set to field elevation? You check it, see that it's a bit off, and set it so that it's correct. All the while, never noticing that the thousands hand is in the wrong place. The human brain has a powerful capacity for illusion. If you "know" that something is true, it can be difficult to see otherwise. Especially when the object in question is small and you're not concentrating on it. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Checkride Wednesday...followup to: "Tips for Commercial Glider Checkride?" | Don Byrer | Soaring | 4 | July 19th 08 03:57 AM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Piloting | 168 | February 5th 08 05:32 PM |
Phrase "landing runway" vs. "cleared to land" | Robert M. Gary | Instrument Flight Rules | 137 | February 5th 08 05:32 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
