Building an electronic Angle of Attack indicator
Old May 11th 09, 02:12 PM posted to rec.aviation.homebuilt
rich[_2_]
Default Building an electronic Angle of Attack indicator
Well of course, the best is to use an AOA vane, like the jets use. The
biggest problem is where the jets conveniently mount it on the side of
the fuselage, on most singles, that's right in the prop blast,
rendering it useless. If you could find someplace to mount it outside
of the prop blast, then it would work great. But finding that
place......
On Sat, 9 May 2009 05:30:37 -0700 (PDT), Mike
Has anyone built an electronic angle of attack meter kit. It seems to
be something that would be easy to design but beyond my feeble
electronics background.
I have seen the products that are out there and they are simple
differential pressure gauges and are expensive. I don't like the
round differential pressure gauges that many of the companies offer
for this kind of system. I was wondering if there would be a way to
put something together that would light up different color LED's for
the different levels of lift that we could build at home without
having to pay out hundreds of dollars for a prebuilt one.
Old May 11th 09, 03:02 PM posted to rec.aviation.homebuilt
Dan[_12_]
place......
Kitplanes once did an article on a boom mounted vane called "bacon
saver." No reason a similar set up couldn't be used.
Dan, U.S. Air Force, retired
Old May 11th 09, 05:22 PM posted to rec.aviation.homebuilt
who cares?
place......
I would like to see a vain mounted on each wingtip with two indicators on the
glareshield.
I'd like to see how much difference there is in AA from one side to the other
during steep turns, slow turns, and less than perfect rudder work.
Old May 11th 09, 07:22 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Great idea, yes. Any preference of vains in the glossy magazines?
For myself I'd much like Madonna and Prince - if they are more or less
balanced.
(or could it be you meant a couple of vanes? That's a whole another
story...)
Old May 11th 09, 08:15 PM posted to rec.aviation.homebuilt
Frank Stutzman[_3_]
balanced.
story...)
Could be worse. He could have said 'veins' ;-)
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
Old May 11th 09, 08:38 PM posted to rec.aviation.homebuilt
Dan[_12_]
balanced.
story...)
Vain vanes, something in that vein?
Old May 12th 09, 06:06 PM posted to rec.aviation.homebuilt
Stuart Fields
"who cares?" wrote in message
In article , rich
place......
glareshield.
other
Sounds like an interesting idea. Encoding the position of the vane would be
needed. One way might be to use minature shaft angle optical encoders ( I
tend to think digitally as opposed to analog) . I've seen prices as low as
$20 each. Put one on each wing tip mounted vane and as Jim says the rest is
easy. (If you know some good electronic tech). If you know the AoA for
stall, the output of the encoder could be compared to a preset number and an
alarm into the head set could easily be produced digitally. I've used a
combination of a modification of one of Jim's circuits produced for
Kitplanes along with some additional digital circuitry for a High/Low
helicopter rotor speed alarm and it works great.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4068 (20090512) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Old May 12th 09, 06:20 PM posted to rec.aviation.homebuilt
Dan[_12_]
In article , rich
place......
glareshield.
other
Good idea, you can use a DIP switch (do they still call them that?)
to set your alarm point.
Old May 11th 09, 09:59 PM posted to rec.aviation.homebuilt
Morgans[_2_]
place......
On a mast like a pitot tube, out on the wing.
I propose 4 or 5 microswitches with a mechanical linkage to go from the vane
to the switches in the wing. Send the signal to some led's, and you are
done. Cheap and easy.
Jim in NC
Old May 11th 09, 10:08 PM posted to rec.aviation.homebuilt
Dan[_12_]
place......
That should be fun to calibrate, but once everything is secured it
should be reliable.
Prop angle of attack vs age sid Piloting 47 July 13th 08 04:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 12:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 06:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 02:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
