Building an electronic Angle of Attack indicator
Old May 12th 09, 04:44 AM posted to rec.aviation.homebuilt
Brian Whatcott
Default Building an electronic Angle of Attack indicator
There is one central location that is not subject to prop blast,
exactly: - that's the nose cone of the prop.
Visualize a small hole set about an inch back from the front.
Use a local pressure sensor chip and a wireless transmitter.
The flow from off axis would module the air pressure slightly
one cycle per revolution, with amplitude in proportion to
AofA (maybe :-)
Brian W
rich wrote:
Well of course, the best is to use an AOA vane, like the jets use. The
biggest problem is where the jets conveniently mount it on the side of
the fuselage, on most singles, that's right in the prop blast,
rendering it useless. If you could find someplace to mount it outside
of the prop blast, then it would work great. But finding that
place......
Old May 12th 09, 07:14 AM posted to rec.aviation.homebuilt
Ed
On Mon, 11 May 2009 22:44:23 -0500, Brian Whatcott
AofA (maybe :-)
Brian W
The wiring might be a little tricky
Old May 12th 09, 12:57 PM posted to rec.aviation.homebuilt
Brian Whatcott
AofA (maybe :-)
Brian W
A wireless chip to a fixed receiver chip is not a biggie. But getting
that sensor chip and transmitter chip inside the nose cone in dynamic
balance would be an issue, I reckon....
Brian W
Old May 12th 09, 03:06 PM posted to rec.aviation.homebuilt
RST Engineering - JIm
It is not a biggie if price is no concern. However, if you are trying to
bring it to market it is cost prohibitive.
"Brian Whatcott" wrote in message
A wireless chip to a fixed receiver chip is not a biggie. But getting that
sensor chip and transmitter chip inside the nose cone in dynamic balance
Brian W
Old May 12th 09, 04:28 PM posted to rec.aviation.homebuilt
Dan[_12_]
Brian W
Beyond cost I wonder if such a system could be made rugged enough to
survive the sustained g forces.
I would assume the airflow over the spinner would cause near constant
pressure on all sides of the spinner due to centrifugal force. I have
nothing to back this up, but it just seems probable.
There's a lot to be said for simplicity. On F-4E there was a "yaw
string" to indicate yaw. All it consisted of was a length of 550 cord
(parachute cord) with one end attached just behind the radome. The pilot
could see the other end in flight. When it was centered in his view the
aircraft was not yawing. I suppose an enterprising person could install
a similar string mount on a boom mounted scale extending from the front
of the wing within view of the pilot and out of propeller blast. 550
cord is available in several colours if that's what one wishes to use.
Dan, U.S. Air Force, retired
Old May 12th 09, 11:10 AM posted to rec.aviation.homebuilt
Morgans[_2_]
news
AofA (maybe :-)
Yeah, that sounds eaaaaasssy, and cheeeep, too!
NoT ! ! ! ;-)
Jim in NC
Old May 12th 09, 01:00 PM posted to rec.aviation.homebuilt
Brian Whatcott
news
AofA (maybe :-)
NoT ! ! ! ;-)
I'm the one who likes the mouth organ reed, tube and wing slot approach
- but Experimental class is dedicated to folks who don't take the cheap,
easy approach!
Brian W
Prop angle of attack vs age sid Piloting 47 July 13th 08 04:46 PM
Glider angle of attack indicator by SafeFlight Bill Daniels Soaring 53 December 20th 07 12:29 PM
Angle of attack Bill Daniels Soaring 27 December 19th 07 06:17 AM
preferrred bank angle indicator? Matt Herron Jr. Soaring 34 July 10th 06 02:22 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
