Drive Small VGA screen from PDA
Old May 17th 09, 03:06 PM posted to rec.aviation.soaring
Default Drive Small VGA screen from PDA
On May 17, 9:42*am, wrote:
On May 16, 12:18*pm, wrote:
On May 16, 2:00*pm, wrote:
On May 15, 8:13*pm, wrote:
On May 15, 8:02*pm, ContestID67 wrote:
Interesting idea which I had thought about for automotive use. *Of
course there is increased power draw but it would be a poor man's
ClearNav. *Does only the Dell's provide you VGA out? *How about
IPAQs. *Thanks.
A number of PDAs have VGA displays. I just happened to see the VGA
cable advertisement and realized the Dell did not need any other
components to drive a VGA display. I would think the other PDS could
also do this, although I am not sure. I have found a document for the
DELL pin outs, which would allow you to construct a cable with
interfaces to the VGA, GPS and a power source. Yes, sticking together
a bunch of off-the-shelf components does look like a poor-man
solution, but more like the Craggy Aero design approach. I understand
the ClearNav design focused on ergonomics and NK designed all new
hardware and software components to achieve this goal The price of
both systems is very close, however, and much higher then this poor-
man approach would cost - if it worked. It's hard to believe someone
has not experimented with this already.
Here is the Dell pin out map. Look at the bottom of the page.http://www.handhelds.org/moin/moin.c...ximX50Hardware
Actuall the Craggy Aero Design focused on performance and value to the
customer. *It has 1" larger on the diagonal screen, 3 to 4 times the
processor speed, 4 times more resolution 640X480 , State of the art
Software SeeYou Mobile or WinPilot and a very erogonomic hand held
ball track mouse. No messy boards on the back and $300 less than a
Clear Nav.
Richardwww.craggyaero.com
hmmm ... ok, so looking at the mix of off the shelf components, how
come it is only 300 less ... shouldn't it be half the cost of a
ClearNav? Or is the difference reflective of a higher mark-up?- Hide quoted text -
- Show quoted text -
Jim,
If you look at the mix of components: Tthe Craggy Aero Ultimate has 4
times more screen resolution that the ClearNav, *three to 4 times
better faster processor, a larger screen, a brighter screen and state
of the art fully developed software. * So it should cost more that the
ClearNav but as I said before it is $300 less.
and 1000x more self promotion.
Old May 17th 09, 03:43 PM posted to rec.aviation.soaring
bildan
IPAQs. *Thanks.
Clear Nav.
Jim,
If the "amoeba" is the big thing, then GPS_Log has it for free and it
comes with both a WinCE and a 32 bit windows version. I'm thinking
of running the 32bit version on a Via Pico ITC motherboard and a 7"
LED backlit LCD.
Old May 18th 09, 11:46 PM posted to rec.aviation.soaring
Ed Winchester[_2_]
bildan wrote:
On May 17, 8:06 am, wrote:
On May 17, 9:42 am, wrote:
On May 16, 12:18 pm, wrote:
On May 16, 2:00 pm, wrote:
On May 15, 8:13 pm, wrote:
On May 15, 8:02 pm, ContestID67 wrote:
Interesting idea which I had thought about for automotive use. Of
ClearNav. Does only the Dell's provide you VGA out? How about
IPAQs. Thanks.
customer. It has 1" larger on the diagonal screen, 3 to 4 times the
Clear Nav.
Jim,
times more screen resolution that the ClearNav, three to 4 times
of the art fully developed software. So it should cost more that the
LED backlit LCD.
XCSoar has the same thing, as well. And it works, I tested it
yesterday. Oh, and it's free for most any auto nav device or pda. Or
PC for that matter, even your homebrewed Via Pico computer.
Old May 20th 09, 11:46 AM posted to rec.aviation.soaring
Fish[_3_]
If you want quality, in a product specifically designed to run
XCSoar, look at www.triadis.ch for the Altair,
or on my site www.swiftavionics.com.au
Old May 17th 09, 06:39 PM posted to rec.aviation.soaring
Jack[_12_]
Self-referential.
Jack
Screen Luminance [email protected] Soaring 11 October 14th 08 08:04 AM
U.S. Soaring on the Small Screen (sort of...) Bob Whelan[_2_] Soaring 0 June 21st 08 05:49 PM
Screen shots in OS2 Michael Baldwin, Bruce Products 0 November 9th 06 07:18 AM
Screen freezing. W.Lindsay Simulators 3 May 10th 06 09:03 PM
Dual screen in FS9 John Mullen Simulators 2 September 29th 03 12:59 AM
