![]() "Stealth Pilot" wrote well when that prop was shattered in a wheels up landing of the sidlinger hurricane it was on, not one part of the curly grain had let go. no glue breaks in the curly grain. no breaks of any type in the curly grain area. all the breaks were in the adjoining straight grained sections at radiuses either side of the wrong grained wood. If the curly wood is in the middle of the prop blank, or carved section of the blade, it is only taking up the centripetal forces (I know, they don't exist) and not any bending load. It is only serving to hold the outer sections away from each other, like the web in an I beam. -- Jim in NC |
On Thu, 4 Jun 2009 20:32:31 -0400, "Morgans"
wrote: "Stealth Pilot" wrote well when that prop was shattered in a wheels up landing of the sidlinger hurricane it was on, not one part of the curly grain had let go. no glue breaks in the curly grain. no breaks of any type in the curly grain area. all the breaks were in the adjoining straight grained sections at radiuses either side of the wrong grained wood. If the curly wood is in the middle of the prop blank, or carved section of the blade, it is only taking up the centripetal forces (I know, they don't exist) and not any bending load. It is only serving to hold the outer sections away from each other, like the web in an I beam. centripetal forces exist. it is centrifugal forces that dont. Stealth Pilot |
Charles Vincent wrote:
Stealth Pilot wrote: On Mon, 25 May 2009 12:32:15 -0500, Charles Vincent wrote: I know the British preferred mahogany for their propellers, but as I recall, mahogany had some serious knocks as prop material. I can't bring them to mind at the moment though. Charles mahogany was used by the brits, to quote lattimer-needhams engineering text, "mahogany is largely employed in the manufacture of airscrews, and the variety that grows in honduras is favoured for that class of work. The suitability of honduras timber is due chiefly to the fact that its liability to shrink (after efficient seasoning) is only very slight and that it possesses particularly satisfactory glue retaining qualities. it is a strong, hard, straight grained wood and is not difficult to work." I found the reference. It was in Martin Hollman's Modern Propellor and Duct Design book. It just notes that mahogany tends to splinter easily and is therefore not a good choice. In any event, mahogany doesn't grow here in Texas, at least anywhere near me. Bois dArc does though and has ridiculous strength in compression - double mahogany (I have a house built on Bois D Arc stumps, the tree is so ugly, termites won't touch it) I have the compressive strength numbers since it is a common foundation material, but do not have the normal engineering values for the rest. I need to find them. Charles Surely you've seen some native Indian bows (old ones) the wood is split from a tree so that the heart (dark wood) and the lighter (outside,sap wood ) both appear in the bow..The dark is placed on the inside of the curve because it is much higher in compressive strength..The back side is the sap wood which is much higher in tensile strength. Pore old uneducated indians--didn't know much did they G --also Bois= wood d'Arc= of the arc or bow. Jerry--(used to live on Bois d'Arc in ElPaso.) |
On Wed, 27 May 2009 03:54:38 GMT, Jerry Wass
wrote: Surely you've seen some native Indian bows (old ones) the wood is split from a tree so that the heart (dark wood) and the lighter (outside,sap wood ) both appear in the bow..The dark is placed on the inside of the curve because it is much higher in compressive strength..The back side is the sap wood which is much higher in tensile strength. Pore old uneducated indians--didn't know much did they G --also Bois= wood d'Arc= of the arc or bow. Jerry--(used to live on Bois d'Arc in ElPaso.) the actual examples of english longbows that remain were recovered from the holds of the Mary Rose. no other *actual* medieval english longbows existed. the making of them was pretty well lost to hearsay. they are made from Yew wood exactly as you describe for the american indians. most are apparently roughly shaped but I think that that was so that the wood behaved as needed. Stealth Pilot |
Pills & Propellers | [email protected] | Home Built | 15 | December 3rd 08 01:16 PM |
Wooden Propellers | Danny Deger | Piloting | 11 | March 4th 07 10:17 AM |
Propellers | [email protected] | Home Built | 6 | March 30th 06 01:41 PM |
Bamboo bomber lost. | JDupre5762 | Military Aviation | 4 | May 10th 04 07:04 AM |
AT-10 "Bamboo Bomber" Question | [email protected] | Military Aviation | 4 | March 18th 04 09:13 PM |
