ENGINE BASICS
Old June 10th 09, 06:39 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
Default ENGINE BASICS
(deleted)
Old June 16th 09, 07:54 PM
Jan Carlsson Jan Carlsson is offline
Junior Member
First recorded activity by AviationBanter: Dec 2008
[quote='Veeduber[_2_];695919']To All:
For example ALL engines have some degree of overlap
in their cam timing. If you have a text book that says otherwise, it
is in error.
No Not all engines have overlap, not early rotary radials with one pull/push rod operating the single rocker between the valves, opening one valve at the time, the valve clearence make it impossible to open both at the same time.
Jan
Old June 17th 09, 03:58 AM posted to rec.aviation.homebuilt
On Tue, 16 Jun 2009 19:54:20 +0100, Jan Carlsson
'Veeduber[_2_ Wrote:
;695919']To All:
is in error.
Jan
And then there is the "atmospheric" intake valve.
Old June 29th 09, 07:49 AM posted to rec.aviation.homebuilt
coffelt2
Jan
AKA "Wheeze valve" really worked great in 200 rpm
Vaughn Garden Tractors.
Knight sleeve valve engines suffered from carbon
build-up in the sleeve's ports. Oil and fire took their
toll.
60 years back, Ford flatheads didn't need headers.
just dispense with exhaust manifolds. (neighbors
withstanding)
Old Chief Lynn
Back to basics? Ol Shy & Bashful Piloting 3 September 2nd 08 09:45 PM
airframe basics Mike Piloting 6 June 7th 06 04:37 PM
Scratch Building Basics for Metal Aircraft DVD jon Home Built 1 March 28th 06 11:51 PM
Learning piston engine basics [email protected] Owning 9 December 24th 05 09:19 PM
Tent basics // Oshkosh prep Mike Z. Piloting 35 December 31st 03 10:54 PM
