PDA's in flight
Old June 14th 09, 03:17 AM posted to rec.aviation.soaring
Brad[_2_]
Default PDA's in flight
On Jun 13, 5:55*pm, "Paul Remde" wrote:
Hi,
The IR port may very well be the problem. *The PDA may think that the sun is
another PDA trying to talk to it through the IR port. *I show how to disable
the IR port in training video #6 of my Pocket PC training. *You can see it
hehttp://www.cumulus-soaring.com/train...TrainingCD-PPC
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"John Scott" wrote in message
I had a PDA mounted on the dash of my car that exhibited extreme slowness.
I finally discovered it was due to the IR port trying to communicate with
the sun. *I tried to turn it off in the software, but ultimately covered
over the port on the top of the PDA with a small piece of *black electrical
tape. Problem solved. I initially discovered this was the problem when I
threw my hat over the unit in disgust and discovered that the perforance
immediatly recovered.
You can usually see the port flashig if you point it at a webcam and look
at the resulting video on your computer screen. The webcam sensors are
usually sensitive to IR.
John
Hi Paul,
thanks for the video tip, I've turned off the beam function and will
let you all know what I discover next time I fly.
Cheers,
Brad
Old June 14th 09, 06:15 AM posted to rec.aviation.soaring
Andy[_9_]
Hi,
Best Regards,
Paul Remde
John
Hi Paul,
Cheers,
Brad
Please don't issue any stop commands while it's communicating with the
sun.
9B
Old June 14th 09, 11:04 PM posted to rec.aviation.soaring
Adrian Jansen
Andy wrote:
On Jun 13, 7:17 pm, Brad wrote:
On Jun 13, 5:55 pm, "Paul Remde" wrote:
Hi,
The IR port may very well be the problem. The PDA may think that the sun is
another PDA trying to talk to it through the IR port. I show how to disable
the IR port in training video #6 of my Pocket PC training. You can see it
Best Regards,
Paul Remde
the sun. I tried to turn it off in the software, but ultimately covered
over the port on the top of the PDA with a small piece of black electrical
John
Hi Paul,
Cheers,
Brad
sun.
9B
On the other hand, maybe a "Slow down" command would fix the global
warming problem. :-)
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
Old June 15th 09, 02:29 PM posted to rec.aviation.soaring
Sarah[_2_]
Funny! On the other hand, if it does succeed in communicating with
the sun please post the resulting conversation. It would be ...
fascinating.
sun.
9B
PDA's Interface Ray Lovinggood Soaring 11 August 31st 05 03:20 PM
FS-PDA's Ed Hollestelle Soaring 0 September 21st 04 05:26 PM
FS PDA's Ed Hollestelle Soaring 0 July 21st 04 03:31 PM
PDA's Tony Owning 15 February 6th 04 10:20 PM
Overstocked on PDA's Ed Hollestelle Soaring 16 December 4th 03 01:40 PM
