The point here is not the "to turn or not to turn" debate. Assuming
you have the height to be thinking about turning, you probably have enough. Otherwise, landing ahead should be possible. The point is the speed at which the turn is initiated. Even low to the ground manoeuvring is quite safe *with enough speed*. It sounds like this was a typical spin-in scenario that we teach as standard here in the UK. It goes something like: - Coming back to the airfield low - Need to turn but scared about the low height - Use small amount of bank - Let the speed come off in order to stretch the glide - Glider stalls, spins, and if this were the real thing (and not done at height as a demo), then it's unrecoverable On Jun 22, 3:58*pm, bildan wrote: On Jun 22, 4:05*am, Dave Doe wrote: In article , says... At 04:03 19 June 2009, Dave Doe wrote: In article , says... Who knows details about this? http://www.mlive.com/news/annarborne...news-32/124507... There is some more info here... http://www.stuff.co.nz/national/2515...wi-pilot-named United States police today released the name of a New Zealand pilot killed last Sunday when the glider in which he was a passenger crashed. Timothy John Moxham, 29, was a pilot for an air ambulance, Midwest Medflight. Police said a delay in releasing details of his identity was because of the difficulty in reaching his parents in New Zealand. Mr Moxham died in a glider owned by the Sandhill Soaring Club and flown by the club president when it crashed near Ann Arbor, Michigan. Preliminary investigation indicated a winch cable used to help the aircraft take flight may have failed on takeoff, police chief William Cook of the nearby Unadilla Township told the Daily Press and Argus newspaper. The Federal Aviation Administration is investigating. The glider pilot, Orrin Burns Beckham, 63, of Ann Arbor, is in a serious condition in a local hospital. A colleague of the New Zealander, Medflight paramedic Andrew King said Mr Moxham took his job to heart. "Not only did Tim love flying and love being a pilot, but he loved being a part of the (team) and getting people to the appropriate hospitals.." Mr King said Mr Moxham's desire to go gliding was recent. He said prior to the trip, Moxham told him: "This is true flying. It's just you and (nature)." The New Zealander had been flying for more than 15 years, starting at the age of 13 when his father taught him, and had logged more than 3000 hours of flight time, including flying offshore, corporate work and flight instruction. He also held certification to an FAA standards on airframe construction and engine mechanics. "People say we've lost a pilot, but he was so much more than that," said another colleague, Medflight nurse Doug Berry. "He had such compassion for the job and the people we transported. He cared about people. "He touched the lives of hundreds of people," Mr Berry added, choking back tears. "He was amazing." - NZPA -- Duncan NTSB prelim is at * * http://www.ntsb.gov/ntsb/brief.asp?e...15X13631&key=1 Thanks Ron. I see... " Witnesses reported that the glider was launched with a winch and during the procedure the winch cable broke. The pilot executed a 180-degree turn apparently in an attempt to return to the airport. However, near the completion of the turn, the nose of the glider dropped and it impacted the terrain. " How many times!!! - *don't* try to return to the field! *OK, I don't know the altitude (AGL) nor what was ahead of the field, but hey, we all know, this is generally regarded as a no-no. -- Duncan I suggest you take a look at the Private Pilot Glider Practical Test Guide. *180 (really 270) turns to a downwind landing are SOP for gliders after a aerotow rope break. 180 turns to a downwind landing are NOT SOP for a winch launch failure since at 200 feet the glider is still very near the approach end of the runway - a 180 turn will leave you with nowhere to land. *Downwind landings are not necessary or even advisable with winch launch failures. |
AOA INDICATORS
Quotes from earlier in this thread... "However, I think significantly fewer accidents would have happened if angle of attack indicators were universally installed." "As for an AOA indicator, you're damn right I'd be looking at it - and flying a much safer recovery as a result." What additional benefit would an AOA indicator give over deciding on an appropriate approach speed before the launch starts and maintaining it, once attained, after a launch failure by monitoring the airspeed indicator frequently? An AOA indicator might just be a distraction! 180 DEGREE TURNS. As pointed by others a 180 turn does not line one up with the runway so unless its a very large airfield additional manoeuvring is required which makes it more complex than at first sight. It is also more likely to put a glider into conflict with landing traffic. It is also quite difficult to avoid landing long if there is a tail-wind component which may tend to make pilots fly more slowly downwind!! The case for a 180 turn after a winch launch failure is very weak. HAND ON RELEASE "First, we're really only talking about an aero tow ground roll. Once airborne in turbulent air, keeping a death grip on the release isn't a good idea." The hand should be touching the release (not holding it) during the early part of the launch so that one can easily grip it properly and pull it without having to look for it. Holding it firmly is likely to create additional risks due to premature releases. So when is it safe to stop touching it? On aerotow probably above 800' - 1000' when the risk of killing the tug pilot if you inadvertently get too high is reducing. "airborne in turbulent air" is one of those situations when you may get out of position - so keep your hand just touching it. On a winch launch you will need to use the release in little over a minute after the launch commences - why not continue to touch it all the way? Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? |
On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote:
Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
When I had a flapped Nimbus 2, I always set the flaps to zero for the
ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. Derek Copeland At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Fri, 26 Jun 2009 15:30:05 +0000, Del C wrote:
When I had a flapped Nimbus 2, I always set the flaps to zero for the ground run and selected the first stage of positive once I was established in the full climb. That way I could keep my hand on the release knob during the ground run. The rapid acceleration of a winch launch gives you almost instant control. For aerotows I started in full negative and notched the flaps back as I gained speed and control. I should have made it clear that was for aero tow: starting the roll in position 2 (-6 degrees) and going to position 3 (zero) once the ailerons are fully effective is SOP for an ASW-20 on aero tow. I flew winch launches entirely in position 3 - zero flap. Martin At 14:23 26 June 2009, Martin Gregorie wrote: On Fri, 26 Jun 2009 13:15:04 +0000, Big Wings wrote: Flapped gliders where the setting needs to be changed from negative during the ground run are an interesting case. Starting (aerotow) launches in negative reduces the probability of a wing drop, but one's hand is in the wrong place to react if it does. What is the best option for those guys? Good question. When I had an ASW-20 I kept my hand on the release until the ailerons bit, moved the flap lever to position 3 and put my hand back on the release with minimum delay. I always assumed this was close to the optimum, but was that a correct assumption? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
