On Jun 24, 10:45*am, Del C wrote:
I knew that agreeing with Bill Daniels was too good to last! Given a vaguely competent pilot, the most likely cause of a wing drop is a gust, especially if there is a cross-wind component. That is what happened in the series of photos that show a K13 standing on it's starboard wingtip. I put a link into this in an earlier posting. Please note that full opposite aileron and rudder is being applied throughout this incident! On the subject of not accidentally pulling the release knob as a result of holding it, you need to arrange the cockpit so you are not holding the release at full stretch. Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Derek Copeland At 15:29 24 June 2009, bildan wrote: On Jun 23, 5:42=A0pm, Andy *wrote: On Jun 23, 4:18=A0pm, ucsdcpc *wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. =A0What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? =A0It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. =A0Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". *Unfortunately, you just have to watch a few takeoffs to see it happen. *One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go *- long enough to get aileron control on either aero tow or winch. *That's good practice with any launch method. What I see in that K-13 sequence is the parachute disappearing off the left side of the frame after it was released. It gives the appearance the glider was staged at least 30 degrees off the line of sight to the winch. I also don't see any aileron or rudder applied in the first frame with the wing on the ground indicating the pilot was WAAY behind the glider. Blaming this 100% on a gust seems a reach. |
Fully agree with Derek, it stands to reason that an inadvertant cable
release at any moment in the launch is less risky that failure to release instantly if things start to go wrong. Its doesn't have to be white nuckle grip, but hlold it you must! Eventualities before launch will cover the recovery scenario for the launch ahead no matter it is a cable break or accidental/deliberate cable release. Even well away from the ground, the relative merit seems to remain. David. At 16:45 24 June 2009, Del C wrote: I knew that agreeing with Bill Daniels was too good to last! Given a vaguely competent pilot, the most likely cause of a wing drop is a gust, especially if there is a cross-wind component. That is what happened in the series of photos that show a K13 standing on it's starboard wingtip. I put a link into this in an earlier posting. Please note that full opposite aileron and rudder is being applied throughout this incident! On the subject of not accidentally pulling the release knob as a result of holding it, you need to arrange the cockpit so you are not holding the release at full stretch. Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Derek Copeland At 15:29 24 June 2009, bildan wrote: On Jun 23, 5:42=A0pm, Andy wrote: On Jun 23, 4:18=A0pm, ucsdcpc wrote: have a look at the simulation videos on the BGA website http://www.gliding.co.uk/bgainfo/saf...nch-safety.htm you don't have a lot of time to find the release knob if a wing drops Maybe not, but it's hard to believe the wing drop simulations are representative. =A0What reasonably trained pilots would stuff the wing into the ground and then continue to hold full aileron into the low wing? =A0It would be interesting to see the same scenario simulated with an external upset causing the wing drop and full recovery aileron being applied at and after wing tip contact. =A0Throw in various amounts of drag on the low wing tip to simulate short grass, long grass, etc and then introduce pilot release before, at, and after wing tip contact, and I'd start to believe it was a useful training aid. Andy It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". Unfortunately, you just have to watch a few takeoffs to see it happen. One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go - long enough to get aileron control on either aero tow or winch. That's good practice with any launch method. |
In message , Del C
writes snip Some glass single seaters are very good at hiding the release knob almost out of reach somewhere below your crutch and behind the stick. On my own glider I have extended the cable so it is easier to reach the knob (with the approval of a BGA Inspector I hasten to add). The last fatal cartwheel accident in the UK involved an ASW20L glider. If you read the aaib report, they concluded that once the stick was hard over to the left, which it would have been as it was the right wing that dropped, it would have been almost impossible to get to the release knob if you weren't holding it already! Snip I might be wrong but I think they also concluded that having the left hand where it could reach the release knob would have made full left aileron impossible. My own glider has similarities with an ASW20 and also has a short extension on the release pull. -- Surfer! Email to: ramwater at uk2 dot net |
On Wed, 24 Jun 2009 08:29:22 -0700 (PDT), bildan
wrote: It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". Unfortunately, you just have to watch a few takeoffs to see it happen. One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go - long enough to get aileron control on either aero tow or winch. That's good practice with any launch method. Hi Bill, I'm not sure if your observation is correct. During aerotows you often see the wing runner working hard to keep the wing perfectly balanced, the pilot keeps ailerons centered, wing runner lets go - and the wing tip hits the ground immediately before the pilot has time to apply aileron. A typical crosswind situation. The problem is that the pilot cannot sense the wing-drop tendency (and apply opposite aileron) as long as the wing runner keeps the wing level. The better technique is if the wing runner follows the wing-drop tendency, not trying to keep the wings level - the pilot is going to feel one wing going down (although still held by the wing runner, hence no danger of the wing tip touching the ground) and will apply aileron immediately. This usually works like a charm. And then there were those open class ships in crosswind situations where you have to apply full aileron to the lee side from the beginning of the aerotow (even if this wing drops)... because despite full aileron this side it's going to come up again..... |
On Jun 24, 4:38*pm, Andreas Maurer wrote:
On Wed, 24 Jun 2009 08:29:22 -0700 (PDT), bildan wrote: It's realistic in the sense that the most likely way a wing would go down is if the pilot does, in fact, "stuff it down". *Unfortunately, you just have to watch a few takeoffs to see it happen. *One of my frustrations is pilots who seem to have no idea where their ailerons are until a wingtip hits the ground. If the pilot consciously centers the ailerons as part of the pre- takeoff checks and lets the wing runner balance the glider, the glider will just stay balanced on its own for several seconds after the wing runner lets go *- long enough to get aileron control on either aero tow or winch. *That's good practice with any launch method. Hi Bill, I'm not sure if your observation is correct. During aerotows you often see the wing runner working hard to keep the wing perfectly balanced, the pilot keeps ailerons centered, wing runner lets go - and the wing tip hits the ground immediately before the pilot has time to apply aileron. A typical crosswind situation. The problem is that the pilot cannot sense the wing-drop tendency (and apply opposite aileron) as long as the wing runner keeps the wing level. The better technique is if the wing runner follows the wing-drop tendency, not trying to keep the wings level - the pilot is going to feel one wing going down (although still held by the wing runner, hence no danger of the wing tip touching the ground) and will apply aileron immediately. This usually works like a charm. And then there were those open class ships in crosswind situations where you have to apply full aileron to the lee side from the beginning of the aerotow (even if this wing drops)... because despite full aileron this side it's going to come up again..... If the wing runner balances the glider into the crosswind while the pilot holds neutral aileron it will work just fine, but the two have to work together. The wing runner should feel for the tilt into the wind that balances the glider so it's a tossup which wing would fall if he let go but he can only do this if the ailerons are neutral. Another instructor and I worked this out long ago. Since we often ran wings for each other it was easy to teach the technique to our students. (Ailerons neutral until the wing runner lets go - then fly the glider with the same bank into the wind as the wing runner gave you.) If the wing runner just "holds the wing level" it may well drop to the ground when he lets go. If the pilot is wagging the ailerons around, the wing runner can't do anything to help. BTW, there's another 'gotcha' you often see with aero tow takeoffs in crosswinds. A crosswind will blow the tugs propeller blast downwind so it hits the gliders downwind wing. The glider encounters the prop blast after rolling about half the towrope length. Usually by then the pilot is holding into-the-wind aileron which together with the prop blast will slam the upwind wing into the ground before the pilot reacts. If you are ready for it, you can handle it OK but it catches many pilots unaware. |
Pay out winch launch to 2500ft agl.. | WAVEGURU | Soaring | 8 | June 5th 07 07:06 AM |
Winch Launch Videos | Mike Schumann | Soaring | 2 | January 19th 06 11:27 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
Electric winch fatality story in August Soaring | Bill Daniels | Soaring | 0 | August 14th 04 02:37 AM |
Winch launch | M B | Soaring | 0 | October 30th 03 07:33 PM |
