![]() wrote in message ... I was getting ready to install a replacement manifold on the old Mercury and it occurred to me I ought to be pretty sure my torque wrench didn't strip the aluminum threads. The Snap On dial wrench hasn't been recalibrated for 30 years and the Craftsman torsion bar wrench is too clumsy to get to some of the bolts. I was kicking it around and I came up with using the torsion bar wrench on a bicycle axle nut and then putting the dial wrench on it to see if the reading matched. It did. Then, I went ahead and checked the Craftsman clicker wrench of the same vintage and recalibrating, and it came up with a match also. Then I did the torquing with the dial wrench and cross checked it with the torsion bar wrench, with all good readings. So, I'm just going to call them calibrated. Andy Phoenix You might check around for a lab. A phone call to these guys indicate rates of $35 to $55. http://www.teamtorque.com/index.html |
![]() wrote in message ... I was getting ready to install a replacement manifold on the old Mercury and it occurred to me I ought to be pretty sure my torque wrench didn't strip the aluminum threads. The Snap On dial wrench hasn't been recalibrated for 30 years and the Craftsman torsion bar wrench is too clumsy to get to some of the bolts. I was kicking it around and I came up with using the torsion bar wrench on a bicycle axle nut and then putting the dial wrench on it to see if the reading matched. It did. Then, I went ahead and checked the Craftsman clicker wrench of the same vintage and recalibrating, and it came up with a match also. Then I did the torquing with the dial wrench and cross checked it with the torsion bar wrench, with all good readings. So, I'm just going to call them calibrated. Andy Phoenix Calibration can be like measuring with a micrometer and cutting with an axe. Unbrako says that torque wrench accuracy for generating the clamping force is +/- 25%. For a 100 in-# set click you could be providing 75 or 125in-# instead. How close a calibration to "truth" is needed? Stu |
On Jun 29, 10:20*am, "Stu Fields" wrote:
Calibration can be like measuring with a micrometer and cutting with an axe. Unbrako says that torque wrench accuracy for generating the clamping force is +/- 25%. Stu True, clamping force and "torque" are not always a direct relationship. Thus the use of Torque-n-Turn specs (and other methods of overcoming thread friction). I've never seen any specs for AN hardware other than simple torque values. Do Torque-n-Turn specs exist for AN hardware? Yes, I know that AN hardware isn't "torque to yield" but the method is still of value for reusable fasteners. ================= Leon McAtee |
Thin 3/8" wrench | RST Engineering | Home Built | 10 | November 17th 06 12:52 PM |
Flight wrench question | R.H. | Piloting | 14 | June 25th 06 03:48 PM |
Ignition lead nut-wrench | jerry wass | Aviation Marketplace | 0 | April 8th 06 03:55 AM |
Wrench size for KI214 & KI201 OBS knob | Roy Page | Owning | 7 | March 11th 05 10:07 PM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
