Testing On The Cheap
Old July 5th 09, 07:53 PM posted to rec.aviation.homebuilt
rattlesnake
Default Testing On The Cheap / update
if you just scrapped a $1000 item wouldn't you, mon ami?
"jan olieslagers" schrieb im Newsbeitrag
rattlesnake schreef:
You are strong at foreign languages, mein lieber Herr! Bravo!
But then, cursing is always learnt first, isnt'it...?
Old July 6th 09, 03:51 AM posted to rec.aviation.homebuilt
Brian Whatcott
Ouch,
glad THAT didn't happen in the air.
Seeing an engine depart must be on about the same excitement level as
seeing aeroelastic vibration in the wing tips.
Makes me think of a reason why I sometimes see a wire cable tether round
a couple of engine fixings back to a bulkhead. A loose engine has a
better CofG that a missing engine, no doubt!
Brian W
rattlesnake wrote:
performed static testing on Saturday. Went well except engine mount broke
(§&%!?$ one of the few parts I didn't fabricate by myself) So far about
testing.....
www.ph21.de/guest/Pict0035.jpg
"gorgon" schrieb im Newsbeitrag
On Jul 3, 10:49 am, "rattlesnake" wrote:
Destruct static testing done in a non-silly and relevant manner. Kind
of cool to see that they predicted the failure mode and location. The
wing was designed within a couple of percent of the goal. No weight
sacrificed here.
http://www.youtube.com/watch?v=pe9PVaFGl3o
Old July 6th 09, 08:22 AM posted to rec.aviation.homebuilt
rattlesnake
"Brian Whatcott" schrieb im Newsbeitrag
Ouch,
wouldn't happen in the air. Was caused by stupid static load testing.....
Old July 6th 09, 06:06 PM posted to rec.aviation.homebuilt
Brian Whatcott
Ouch,
I'm thinking it would be stupid, or at least careless, if the load
were reacted through just one or two mount fixings.
Is that how the test was rigged?
(I noticed there seemed to be a steel strip
perhaps 3/16 X 1 inch welded into the cluster which seemed to
provide a rather abrupt section change.) Is that the way the plans
were drawn?
Brian W
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Aviation Marketplace 7 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 12:13 AM
CHEAP Los Angeles C-172 Flying Club CHEAP xyzzy Owning 0 April 6th 09 03:31 PM
Testing the Testing of Mogas Jay Honeck Piloting 22 July 24th 06 09:38 PM
