On Jul 14, 7:51Â*pm, "Tom" wrote:
I figured I better let some time pass before I chimed in since I was on the short end of the ruling at Parowan. 1 - I have no problem with the protest since the rule allowed it. 2 - I have no problem with the decision of the committee and felt they upheld the rule. 3 - I have no problem with Charlie opening the gate when he did so per the rules. Everyone was correct. Â*The rub is the rule itself. Â*This rule punished competitors that flew well (in this case a vast majority of the field) and benefited those that landed out / back or choose not to fly. Â*It is frustrating to have 4 hours negated to zero. To make matters worse, the Sports Class was moved to the end of the grid the next day since the 15 and 18 meter guys did not have a contest day. Â*Hello!? Neither did Sports. Â*Separate topic, but if you fly Sports at R9 you will not receive the same attention to detail as the FAI guys. Â*Our starts are historically called poorly and until this year we always launched last. All week long in the pilot's meeting we were reminded that competition pilots represent a very small percentage of soaring people. Â*Reading RAS and going through this last Region 9, it is clear that crappy rules and scoring that requires a degree in mathematics will probably keep this number in the same range in the future. Can't bitch without making suggestions right? Â*Two rule suggestions - 1 - Change the rule so that if a majority of the field scores, adjust the competitor's score that was not able to start. Â*Instead of bringing 20 some scores down to zero, adjust 1 or two scores up. 2 - As suggested in other posts, change the call when the gate opens. Opening the gate 15 minutes after the last competitor starts the t/o roll is not viable. Tom Dukerich Â*OD2 Not to put too fine a point on it, but the rule states: 10.1.5 Task Opens - at a time designated by the CD, about 15 minutes after the last competitor who accepts his designated launch starts his takeoff roll. I.e. the CD has the discretion to delay the opening of the task for whatever reason. The suggested 15 mins is the nominal time for the last launch to have a reasonable opportunity to get as good a start as the first launch. The premise of the race is that everyone gets the same opportunity to start at the same earliest time from the same location if they desire (eliminating the luck of the grid draw as a significant factor). An alternative would be to allow a start immediately off tow and virtually never cancel the day once the launch starts, in which case the luck of the grid draw would be a big factor - so are we measuring skill or luck? Should Charlie have held the gate opening? It's easy to say yes with 20/20 hindsight but it was not necessarily easy to tell at the time. The nullification of a day after it has been run is an exceptional action justified only by "force majure" circumstances. In this case we all judged in retrospect that we had not set a mostly level playing field and if those most affected had performed near their average for the prior two days it would have materially affected the leadership positions. .. Second, there is currently in the rules a (to date unused) provision for "worst day score adjustment" in regionals. 11.4.4 â€* Worst Day Score Adjustment If this is declared to be in effect, an adjustment is calculated and added to the cumulative score of each entrant.. If you think the scoring formulas are complicated now, read the rest of the rule. QT |
Not fair. | Maxwell[_2_] | Piloting | 34 | June 30th 08 03:53 PM |
What percentage of USA glider pilots compete? | Jeremy Zawodny | Soaring | 30 | April 4th 07 05:30 AM |
Fair Share | Mike Granby | Owning | 17 | July 19th 05 06:23 AM |
OT-Fair reporting? | Joel Corwith | Soaring | 4 | November 28th 04 05:54 PM |
OT-Fair reporting? | Joel Corwith | Home Built | 3 | November 28th 04 04:12 AM |
