At 20:39 27 July 2009, Bruce wrote:
Look at what MEL does - http://www.machinefabriek-el.nl/content_16.asp This is the manufacturer to the reasonably conventional "Leopard" winch and of the "van Gelder" - probably the most sophisticated winch actually working. I wonder what proportion they are made in. But anyway - as examples. Note the engines are Volvo Penta diesel... And they measure lots of things, and still get manually driven - albeit with exquisite control. Interestingly there are reports of clubs reverting from van Gelder to Skylaunch (or equivalent) with retrieve setups with better launch rates. Something to do with complexity and maintainability and cost. Any one with actual experience? Bruce I flew off a Munster Van Gelder winch for 10 years and when it was working it gave the smoothest launches I have ever had. It was fitted with automatic drum engagement which was permanently switched off as the drivers could do the selection much more efficiently. The control systems were very very complex and it required many hours of maintenance during the week to make sure it would run for the weekend. If it had been a private club it would never have worked but the Royal Air Force had the manpower to keep it maintained. Despite this many of the advanced systems did not work. The winch drivers however were well trained and in the main skillful so they worked round many of the minor problems. The winch was a perfect example of a complex and technically advanced machine which did not stand up to the rigors of being operated in the real world, it was just too complex. Following that I flew for 7 years at a club using a Skylaunch. The ability to accelerate the glider was not much less than the MVG but it was nowhere near as smooth. The engineering was simple, one could say agricultural, but that was it's main saving, there was nothing complex to go wrong. The winch was made up of well tried and test indusrty standard units which worked even with minimal servicing and I do mean minimal. The only critisism I would make is that some of the engineering was not agricultural enough to stand up to the abuse of club member winch drivers. Bits fell off from time to time but the the winch engine, transmission and drums continued to work and work well. The MVG winch and the Skylaunch winch do the same job but the MVG does it with much less effort. The MVG has 6 drums and it was a minor miracle if they were all available for use. It drank deisel like there was no tomorrow. The Skylaunch has two drums and you could purchase 2 Skylaunch winches = 4 drums for the same amount the RAF paid for the MVG 15-20 years ago. My current club operates a Supercat winch modified by Skylaunch to take their engine, transmission and control. It is certainly as good as a standard Skylaunch and has almost no downtime. They all run on LPG. (It's what passes for cheap fuel in the UK) With winches I believe that the KISS principle is essential |
I understand that the Van Gelder (MVG) winch at Dunstable (UK) is taken out
of service for half a day each week for routine maintenance and for one week a year for a major overhaul. This done during their competition week when they only aerotow. In comparison, the Skylaunch is much like a modern automobile in that you just check the levels and give it a daily inspection (DI) every day, and change the oil, filters and the cables every so many thousand launches. One of the reasons Lasham decided to change from Tost to Skylaunch (apart from better launches) was that our long serving maintenance engineer reached retirement age and the Tosts required quite a lot of servicing and maintenance, and an annual rebuild which took about a month each. We did these in the winter, but we still operate then, so if anything went wrong with the winch in service we had no backup. When we first started winch launching we tested a 6-drum MVG winch, which as a driver I found really impressive with lots of flashing lights and hydraulic and pneumatic systems. However it was very expensive and it was felt that it was rather putting all our eggs in one basket. Particularly when we (not me BTW) had a foul up which wrapped a cable many times around the common drive shaft and put the whole thing out of operation for nearly two hours. In the end we decided to buy two much more basic two drum Tosts on the grounds that if you had a major foul up or a problem on one, you could continue to launch with the other. Incidentally I believe that the World Record height for a glider winch launch (over 1500m) is currently held by the relatively simple MEL Leopard winch, and was previously held by a slightly modified Tost fitted with higher capacity drums. See: http://www.youtube.com/watch?v=zFKsjDIjmDg http://www.youtube.com/watch?v=-VlRd9-wxQI Derek Copeland At 22:45 27 July 2009, Don Johnstone wrote: At 20:39 27 July 2009, Bruce wrote: Look at what MEL does - http://www.machinefabriek-el.nl/content_16.asp This is the manufacturer to the reasonably conventional "Leopard" winch and of the "van Gelder" - probably the most sophisticated winch actually working. I wonder what proportion they are made in. But anyway - as examples. Note the engines are Volvo Penta diesel... And they measure lots of things, and still get manually driven - albeit with exquisite control. Interestingly there are reports of clubs reverting from van Gelder to Skylaunch (or equivalent) with retrieve setups with better launch rates. Something to do with complexity and maintainability and cost. Any one with actual experience? Bruce I flew off a Munster Van Gelder winch for 10 years and when it was working it gave the smoothest launches I have ever had. It was fitted with automatic drum engagement which was permanently switched off as the drivers could do the selection much more efficiently. The control systems were very very complex and it required many hours of maintenance during the week to make sure it would run for the weekend. If it had been a private club it would never have worked but the Royal Air Force had the manpower to keep it maintained. Despite this many of the advanced systems did not work. The winch drivers however were well trained and in the main skillful so they worked round many of the minor problems. The winch was a perfect example of a complex and technically advanced machine which did not stand up to the rigors of being operated in the real world, it was just too complex. Following that I flew for 7 years at a club using a Skylaunch. The ability to accelerate the glider was not much less than the MVG but it was nowhere near as smooth. The engineering was simple, one could say agricultural, but that was it's main saving, there was nothing complex to go wrong. The winch was made up of well tried and test indusrty standard units which worked even with minimal servicing and I do mean minimal. The only critisism I would make is that some of the engineering was not agricultural enough to stand up to the abuse of club member winch drivers. Bits fell off from time to time but the the winch engine, transmission and drums continued to work and work well. The MVG winch and the Skylaunch winch do the same job but the MVG does it with much less effort. The MVG has 6 drums and it was a minor miracle if they were all available for use. It drank deisel like there was no tomorrow. The Skylaunch has two drums and you could purchase 2 Skylaunch winches = 4 drums for the same amount the RAF paid for the MVG 15-20 years ago. My current club operates a Supercat winch modified by Skylaunch to take their engine, transmission and control. It is certainly as good as a standard Skylaunch and has almost no downtime. They all run on LPG. (It's what passes for cheap fuel in the UK) With winches I believe that the KISS principle is essential |
Yesterday, launching into a moderate headwind at Lasham on a Skylaunch
winch, we were getting better than 2000ft launches from a 1200 metre run in K13 and K21 training gliders. The best launch in a K21 was 2500ft. This was using 4.5mm stranded steel cable, so we might have got a couple of hundred feet higher using lightweight synthetic cables. There were no cable or weak link breaks, frightening incidents, or launch failures of any sort, despite rather gusty conditions. Derek Copeland |
At 13:15 31 July 2009, Del C wrote:
Yesterday, launching into a moderate headwind at Lasham on a Skylaunch winch, we were getting better than 2000ft launches from a 1200 metre run in K13 and K21 training gliders. The best launch in a K21 was 2500ft. This was using 4.5mm stranded steel cable, so we might have got a couple of hundred feet higher using lightweight synthetic cables. There were no cable or weak link breaks, frightening incidents, or launch failures of any sort, despite rather gusty conditions. Derek Copeland Good grief Del, give it up. I am sure the yanks are as bored of this thread as we are. |
SAFE Winch Launching | Derek Copeland[_2_] | Soaring | 185 | August 2nd 17 07:12 PM |
SAFE Winch Launching and automatic gearboxes | bildan | Soaring | 2 | July 20th 09 07:17 PM |
SAFE Winch Launching and automatic gearboxes | bildan | Soaring | 0 | July 20th 09 05:25 PM |
FA: WWII Navy / Career Airline Pilot's Book of Memoirs | [email protected] | Aviation Marketplace | 0 | July 31st 05 02:19 AM |
FA: WWII Navy / Career Airline Pilot's Book of Memoirs | [email protected] | Aviation Marketplace | 0 | July 25th 05 02:55 PM |
