Cheap Covering
Old August 8th 09, 04:35 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default Cheap Covering
On Sat, 08 Aug 2009 10:05:28 -0500, brian whatcott
Stealth Pilot wrote:
I'm convinced that finishes like razorback and ceconite over polyester
would not be certified with the hindsight to see their faults.
my aircraft was covered in Stits, or Polyfiber as it is now know, back
in 1983~4. despite thinking that it was good for maybe another 4 years
for all of the past 10 or 12 years the bloody stuff just will not die.
it is painted in polytone which will remain repairable for the life of
the finish. just wipe back with a rag soaked in MEK, do the repair and
rebuild the finish. /snip/
Stealth Pilot
Is polyfiber a proprietary name for polyester 1.8 ounce heat shrinkable
cloth - also found in drapers as polyester lining material?
Brian W
no. and the difference is a very important one.
when polyester fabric is woven the yarn is first stretched slightly at
an elevated temperature. after weaving the cloth is passed through
another heat process to cause the yarn to shrink and better bed in
with the weave. it makes a better fabric for your dresses.
polyfiber grabs the woven cloth before the second heat process.
it is called the greiged state.
after you glue the fabric to the aircraft structure you go over it
with an iron. the ironing causes the fabric to shrink as per the post
weave process for dress fabric. it is that shrink that taughtens up
the fabric, something done by the dope when a natural fiber is used.
so if you buy store dress material you will not in theory have any
method of taughtening it other than to use dope.
if you can buy the drapers polyester lining material in the greiged
state then theoretically it would be usable.
Stealth Pilot
Old August 8th 09, 05:01 PM posted to rec.aviation.homebuilt
jerry wass
Stealth Pilot
Brian W
Yes, probably, but what you find in "cloth stores" has already been heat
shrunk!--Jerry
Old August 8th 09, 10:35 PM posted to rec.aviation.homebuilt
canuck_bob
heat
shrunk!--Jerry
I have found some have had luck with finding shrinkable drapery
linings and sheer fabric. It comes in 108-110 inch widths but would
need to be tested before buying any quantity. One guy took a small
swatch home and cut it to 10" then ironed it. It shrunk in length to
about 9" or 10% shrinkage. It weighed about 2oz. per yard. A good
indication is if the specs call for dry clean only. Seems the
offshore supplied stuff might be more likely to shrink.
Old August 9th 09, 01:03 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
heat
shrunk!--Jerry
Ask for it "in the griege" (pronounced "gray".
http://dictionary.reference.com/browse/griege
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Aviation Marketplace 7 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 12:13 AM
CHEAP Los Angeles C-172 Flying Club CHEAP xyzzy Owning 0 April 6th 09 03:31 PM
Cheap aircraft covering materials [email protected] Home Built 13 January 19th 05 06:59 AM
