brian whatcott a écrit:
I also use the magnets for CDI electronic ignition. no more magnetos, no more cable for tach, no more copper tube for oil pressure... By Not sure if this is what you mean, but a few high energy magnets spinning on a plate do a great job producing pulses in a few coils spaced close to the spinning magnets. I have two simple magnets one north face and the other south face glue at 0° and 180°. The sensor is one AH287 and I use two automotive CDI boxes as power stage for ignition #2. I use one distributorless box from M&W ignition for #1. For the electric wiring, I copy the following schematic: http://www.jodel.com/index.asp?p=potezwiring&engines My electronics devices are in the the point and distributor ignition place. In fact, I built 2 distributorless ignittions like today cars but still have fix timing. The wish list is one microcontroler for variable timing. No way to built a small generator with my magnets. A batteryless ignition like Jabiru require more start energy than my ignition. By -- « Si tous les poètes voulaient se donner la main, ils toucheraient enfin des doigts d'auteur! » Philippe Vessaire Ò¿Ó¬ |
On Tue, 11 Aug 2009 09:26:15 +0200, Philippe
wrote: brian whatcott a écrit: I also use the magnets for CDI electronic ignition. no more magnetos, no more cable for tach, no more copper tube for oil pressure... By Not sure if this is what you mean, but a few high energy magnets spinning on a plate do a great job producing pulses in a few coils spaced close to the spinning magnets. I have two simple magnets one north face and the other south face glue at 0° and 180°. The sensor is one AH287 and I use two automotive CDI boxes as power stage for ignition #2. I use one distributorless box from M&W ignition for #1. For the electric wiring, I copy the following schematic: http://www.jodel.com/index.asp?p=potezwiring&engines My electronics devices are in the the point and distributor ignition place. In fact, I built 2 distributorless ignittions like today cars but still have fix timing. The wish list is one microcontroler for variable timing. No way to built a small generator with my magnets. A batteryless ignition like Jabiru require more start energy than my ignition. the trick with the magnets is to understand that it is the collapsing magnetic field that produces the pulse to the spark plug. if you look at a jabiru magnet there are 3 poles. as the magnet goes whizzing past the coil the coil sees North-South then suddenly South-North. the second magnet orientation is designed to accelerate the collapse of the field through the coil core. The two outer poles are , say, South and the centre one, say, North or vice versa. it is not just magnets on a plate but magnetic pole orientation as well that makes it work. Stealth Pilot |
canuck_bob wrote:
Gee Ron, Your on a slippery slope. Digital displays and already planning your next electrical upgrade! Could be evidence of that dreaded psychological disorder known as Airventure Syndrome. We'll keep an eye out for the major symptoms, obsessive urges to install IFR glass panels, researching the installation of autopilot systems and weather radar, and the most serious sympton requiring medication a small I probably shouldn't confess this, but ever since the Dynon folks gave a presentation at the EAA Chapter, I've really had the urge to install one of their EFIS boxes on my Fly Baby. Just for the jaw-dropping incongruity of it, if nothing else.... Ron Wanttaja |
Install the EFIS and double the value of your Flybaby.... grin...
John Ron Wanttaja wrote: canuck_bob wrote: Gee Ron, Your on a slippery slope. Digital displays and already planning your next electrical upgrade! Could be evidence of that dreaded psychological disorder known as Airventure Syndrome. We'll keep an eye out for the major symptoms, obsessive urges to install IFR glass panels, researching the installation of autopilot systems and weather radar, and the most serious sympton requiring medication a small I probably shouldn't confess this, but ever since the Dynon folks gave a presentation at the EAA Chapter, I've really had the urge to install one of their EFIS boxes on my Fly Baby. Just for the jaw-dropping incongruity of it, if nothing else.... Ron Wanttaja |
secondary tach | dave | Owning | 1 | March 14th 07 07:34 PM |
EGT / Tach Fluctuation | [email protected] | Owning | 3 | August 29th 05 04:58 PM |
Archer Tach Red Arc | Greg Esres | Owning | 15 | February 9th 05 08:28 AM |
Wayward Tach | O. Sami Saydjari | Owning | 7 | February 6th 04 01:27 AM |
Need new PA28 tach | Michael Isaksen | Owning | 2 | October 2nd 03 03:27 PM |
