On Aug 11, 1:18*pm, john89 wrote:
Apparently there are just now "absolute" true rules such as: Airplanes always land in the same direction as they took off. Not so (although the norm in most cases, especially when wind is a factor). I fly towplanes and gliders on weekends, and on days when the wind is light, it's common to takeoff in one direction and land in the opposite direction, as this saves taxy time and makes for a more efficient (and actually safer, believe it or not, as it avoids power vs glider conflicts on final) operation. Granted, this is on a huge grass airstrip, so there is no head-on conflict - but I've even seen cases of simultaneous takeoffs and landings in opposite directions, with the planes/gliders passing on the ground in the middle of their respective takeoff and landing rolls. Definitely requires a good lookout! Kirk 66 |
On Aug 10, 12:41*pm, john89 wrote:
I got a question regarding the so-called "elevation", i.e. the highest point of a runway. I have been told that the elevation is usually at the threshold, right before the touchdown zone, in order to ensure an easier take-off. This information is available to pilots and updated periodically in the Airport/Facilities Directory and the US Terminal Procedures, etc. The A/FD defines it's "elevation" figure as "the highest point of an airport's usable runways measured in feet from mean sea level." In addition, the A/FD lists runway slope when it is .3 or greater for airports that have instrument approaches and elaborates based on other runway criteria ( or than 8000', etc) For IFR purposes, the A/FD and approach plates include a Touchdown Zone Elevation (TDZE) for specific runways. Pilots, particular under IFR, are expected to be familiar with runways of intended use and, if required, alternate airports. We're strongly encouraged to study other airports along the route in case we need to divert. Cheers! -Chris CFI, KTTD |
On Aug 11, 3:49*pm, C Gattman wrote:
On Aug 10, 12:41*pm, john89 wrote: I got a question regarding the so-called "elevation", i.e. the highest point of a runway. I have been told that the elevation is usually at the threshold, right before the touchdown zone, in order to ensure an easier take-off. This information is available to pilots and updated periodically in the Airport/Facilities Directory and the US Terminal Procedures, etc. The A/FD defines it's "elevation" figure as "the highest point of an airport's usable runways measured in feet from mean sea level." *In addition, the A/FD lists runway slope when it is .3 or greater for airports that have instrument approaches and elaborates based on other runway criteria ( or than 8000', etc) For IFR purposes, the A/FD and approach plates include a Touchdown Zone Elevation (TDZE) for specific runways. Pilots, particular under IFR, are expected to be familiar with runways of intended use and, if required, alternate airports. We're strongly encouraged to study other airports along the route in case we need to divert. Cheers! -Chris CFI, KTTD I must qualify for 'least sensitive' pilot here. I've made a number of landings with Wx close to minimums, nasty weather, cross winds, night time, and all that stuff. When I look up at minimums and see VASI and runway locater lights and all that good stuff, I'm real happy to go down the last couple of hundred feet, flare, and become earthbound again. From the moment I go visual I really don't care what the actual altitude of the runway I'm approaching is, I can see it, and know what I have to do to fly the miss if needed. Does it really matter if it's at 469 feet, or 500, at that point to those of us messing around in SELs like Mooneys? What am I missing here? Even if a CAT 3 landing (not in MY airplane!) the radar altimeter controls yoke back pressure at flare, doesn't it? It's looking at actual wheels to ground distances, not some indirect measure like "corrected altimeter subtract field elevation equals air between wheels and ground. The other minor blimp in all of this is I set the kollsman window, then verify the altitude indication is within specification of published altitude. The difference in altitude between the reference datum and my static tube could be pretty significant -- something I had not thought about before. 20 feet eats up a lot of a 50 foot error budget. |
"a" wrote in message
... On Aug 11, 3:49 pm, C Gattman wrote: On Aug 10, 12:41 pm, john89 wrote: I got a question regarding the so-called "elevation", i.e. the highest point of a runway. I have been told that the elevation is usually at the threshold, right before the touchdown zone, in order to ensure an easier take-off. This information is available to pilots and updated periodically in the Airport/Facilities Directory and the US Terminal Procedures, etc. The A/FD defines it's "elevation" figure as "the highest point of an airport's usable runways measured in feet from mean sea level." In addition, the A/FD lists runway slope when it is .3 or greater for airports that have instrument approaches and elaborates based on other runway criteria ( or than 8000', etc) For IFR purposes, the A/FD and approach plates include a Touchdown Zone Elevation (TDZE) for specific runways. Pilots, particular under IFR, are expected to be familiar with runways of intended use and, if required, alternate airports. We're strongly encouraged to study other airports along the route in case we need to divert. Cheers! -Chris CFI, KTTD I must qualify for 'least sensitive' pilot here. I've made a number of landings with Wx close to minimums, nasty weather, cross winds, night time, and all that stuff. When I look up at minimums and see VASI and runway locater lights and all that good stuff, I'm real happy to go down the last couple of hundred feet, flare, and become earthbound again. From the moment I go visual I really don't care what the actual altitude of the runway I'm approaching is, I can see it, and know what I have to do to fly the miss if needed. Does it really matter if it's at 469 feet, or 500, at that point to those of us messing around in SELs like Mooneys? What am I missing here? Funny you should ask... :-) Speaking as a former avionics technician and also student pilot, who also rode "shotgun" on a few single pilot IFR flights back in the day, you are exactly correct. It just happens that, in addition to the dedicated "simmers" who stop by from time to time, this forum also serves as a source of information for a lot of beginning students--and also for future pilots and other interested citizens who have never been inside the airport fence. Therefore, they are not necessary aware of which portions of the information which is required to be surveyed, and entered into databases and onto charts, arereally trivial in normal operations. Even if a CAT 3 landing (not in MY airplane!) the radar altimeter controls yoke back pressure at flare, doesn't it? It's looking at actual wheels to ground distances, not some indirect measure like "corrected altimeter subtract field elevation equals air between wheels and ground. I have no personal experience with Cat 3, so I can not address the interconnection between the radio altimeter and the autopilot; but... Back in the day, I was a "fill in" for the regular radio altimeter technician--so here foes: The radio altimeter, which provides the information regarding the flare in precision approaches, measures the distance between the ground and the radio altimeter antenna--corrected for the height of the antenna above the ground in the typical landing attitude. On large transport category aircraft, that is typically several feet lower than the antenna position when the aircraft is at rest. So, in practice, you are exactly right about the reading of the radio altimeter in the process of landing with the expected attitude and flap deployment. BTW, on very large aircraft such as the Boeing 747, where the pilots eye level at the time of touchdown is too high to give a reliable height indication relative to the runway, it is common to also use the radio altimeter as an information source in initiating the flare. Peter The other minor blimp in all of this is I set the kollsman window, then verify the altitude indication is within specification of published altitude. The difference in altitude between the reference datum and my static tube could be pretty significant -- something I had not thought about before. 20 feet eats up a lot of a 50 foot error budget. |
ASTER Global Digital Elevation Map | AGL | Soaring | 1 | June 30th 09 03:11 PM |
Elevation info for Garmin Glide Ratio functionality | Jack Glendening | Soaring | 1 | July 30th 07 04:49 PM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
How do I get MSL out of National Elevation Dataset? | Kyler Laird | General Aviation | 0 | January 12th 04 08:12 PM |
