Can anyone recommend a good forum for home machine work? Not the news
group, that's a madhouse... Tony |
Anthony W wrote:
Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony If you want a place with good customer support try: http://littlemachineshop.com/ The people there always answer my questions about how to do things and the make suggestions for trouble I get myself into. Dan, U.S. Air Force, retired |
Anthony W wrote:
Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony The Home Machinist http://www.chaski.org/homemachinist/ The Home Shop Machinist & Machinist's Workshop BBS http://bbs.homeshopmachinist.net/ If you have some metalworking or machining experience this group has the most expertise. They do not tolerate well inane questions from wannabes. A wealth of knowledge can be gained by, even, lurking here. Practical Machinist http://www.practicalmachinist.com/vb/ |
Thanx guys I have book marked those pages.
Tony |
"R" wrote in message ... Anthony W wrote: Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony The Home Machinist http://www.chaski.org/homemachinist/ The Home Shop Machinist & Machinist's Workshop BBS http://bbs.homeshopmachinist.net/ If you have some metalworking or machining experience this group has the most expertise. They do not tolerate well inane questions from wannabes. A wealth of knowledge can be gained by, even, lurking here. Practical Machinist http://www.practicalmachinist.com/vb/ Thank you a bunch. The Practical Machinist is just what I've been looking for... Stu Fields Safari helicopter and now a Helicycle |
... Anthony W wrote: Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony The Home Machinist http://www.chaski.org/homemachinist/ The Home Shop Machinist & Machinist's Workshop BBS http://bbs.homeshopmachinist.net/ If you have some metalworking or machining experience this group has the most expertise. They do not tolerate well inane questions from wannabes. A wealth of knowledge can be gained by, even, lurking here. Practical Machinist http://www.practicalmachinist.com/vb/ Looking at this thread makes me just a little curious whether the relationship of cost and capability may have brought the CNC routing/milling process to make precision foam cores--such as used in the Vari-Eze and its derivatives--within reasonable reach of the home builder. The hot wire method worked reasonably well in its day; but was limited to certain types of foam and also resulted in a slight sag in the shape of the resulting parts. Of course, I have kept a list of the above forum locations; and I am curious if anyone happens to know the present cost of setting up that sort of CNC system for the cores in something like a Vari-Eze. Peter |
Peter Dohm wrote:
"R" wrote in message ... Anthony W wrote: Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony The Home Machinist http://www.chaski.org/homemachinist/ The Home Shop Machinist & Machinist's Workshop BBS http://bbs.homeshopmachinist.net/ If you have some metalworking or machining experience this group has the most expertise. They do not tolerate well inane questions from wannabes. A wealth of knowledge can be gained by, even, lurking here. Practical Machinist http://www.practicalmachinist.com/vb/ Looking at this thread makes me just a little curious whether the relationship of cost and capability may have brought the CNC routing/milling process to make precision foam cores--such as used in the Vari-Eze and its derivatives--within reasonable reach of the home builder. The hot wire method worked reasonably well in its day; but was limited to certain types of foam and also resulted in a slight sag in the shape of the resulting parts. Of course, I have kept a list of the above forum locations; and I am curious if anyone happens to know the present cost of setting up that sort of CNC system for the cores in something like a Vari-Eze. Peter I would imagine it's a matter of scale. In theory it would be possible, I have seen kits for 2 dimensional systems for using oxy-acetylene torches to cut sheet metal and a home PC. I wonder if such a sytem could be modified to 3 dimensions. Rigidity of the machinery would require a rather massive frame. One additional consideration would be dust collection. I wonder if the system could also be used to finish the part after layup. A creative mind would be able make some amazing shapes. Dan, U.S. Air Force, retired |
"Dan" wrote in message
... Peter Dohm wrote: "R" wrote in message ... Anthony W wrote: Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony The Home Machinist http://www.chaski.org/homemachinist/ The Home Shop Machinist & Machinist's Workshop BBS http://bbs.homeshopmachinist.net/ If you have some metalworking or machining experience this group has the most expertise. They do not tolerate well inane questions from wannabes. A wealth of knowledge can be gained by, even, lurking here. Practical Machinist http://www.practicalmachinist.com/vb/ Looking at this thread makes me just a little curious whether the relationship of cost and capability may have brought the CNC routing/milling process to make precision foam cores--such as used in the Vari-Eze and its derivatives--within reasonable reach of the home builder. The hot wire method worked reasonably well in its day; but was limited to certain types of foam and also resulted in a slight sag in the shape of the resulting parts. Of course, I have kept a list of the above forum locations; and I am curious if anyone happens to know the present cost of setting up that sort of CNC system for the cores in something like a Vari-Eze. Peter I would imagine it's a matter of scale. In theory it would be possible, I have seen kits for 2 dimensional systems for using oxy-acetylene torches to cut sheet metal and a home PC. I wonder if such a sytem could be modified to 3 dimensions. Rigidity of the machinery would require a rather massive frame. One additional consideration would be dust collection. I wonder if the system could also be used to finish the part after layup. A creative mind would be able make some amazing shapes. Dan, U.S. Air Force, retired Here is a starting point :-) http://www.instructables.com/id/How-...-Cheaply-and-/ -- [This comment is no longer available due to a copyright claim by Church of Scientology International] "I like your Christ. I do not like your Christians. They are so unlike your Christ." Gandhi |
"Anthony W" wrote in message ... Can anyone recommend a good forum for home machine work? Not the news group, that's a madhouse... Tony Lately the signal to noise ratio has gone sour, but rec,crafts.metalworking has been pretty fair, too. Lots of knowledgeable people still there, but an increasing number of cross-posters dump on it, too. Just have to look and ignore some threads, posters. Flash |
Flash wrote:
Lately the signal to noise ratio has gone sour, but rec,crafts.metalworking has been pretty fair, too. Lots of knowledgeable people still there, but an increasing number of cross-posters dump on it, too. Just have to look and ignore some threads, posters. Flash I tried that group for a few day and I found it not worth the insanity... Tony |
| Thread Tools | |
| Display Modes | |
| The Home-made Home-builders Engine | Veeduber[_2_] | Home Built | 37 | June 12th 09 05:22 AM |
| F-111 comes home | Don Pyeatt | Aviation Photos | 1 | May 6th 08 12:26 AM |
| Foamy's Home Away From Home | Michael Baldwin, Bruce | Products | 0 | December 22nd 06 12:14 PM |
| Exclusive Custom Home Plans, and Essential information about building your New Home | orange tree | Home Built | 4 | November 20th 05 05:37 PM |
| Welcome Home | Meade Spotts | Naval Aviation | 0 | March 11th 04 02:17 AM |
