Can anyone answer the original question? Has anyone tried
this feature and how did it work? I was actually curious... And how does it actually work, as in how does it communicate from one device to the other. People have alluded to it transmitting over the radio, do both gliders also need to be on the same radio freq.? etc. etc. thanks, Jim At 20:56 01 September 2009, brianDG303 wrote: Flying this weekend in a new area it was difficult to keep track of where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() |
On Sep 4, 6:15*am, J A wrote:
Can anyone answer the original question? *Has anyone tried this feature and how did it work? *I was actually curious... And how does it actually work, as in how does it communicate from one device to the other. *People have alluded to it transmitting over the radio, do both gliders also need to be on the same radio freq.? etc. etc. thanks, Jim At 20:56 01 September 2009, brianDG303 wrote: Flying this weekend in a new area it was difficult to keep track of where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 * *Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes * * . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() I started this thread and don't entirely understand the feature yet, I'll try it this weekend. But one thing I do understand is that this is not a dynamic feature (it does not update the position) and it is not device to device. It just gives you a 4 or 5 letter code, which you transmit by radio to other pilots. They enter the code into SeeYou, (or winpilot or xcsoar, I understand they all have this feature) and your location is displayed, I think as a waypoint. After entering the code you have an option to press a GOTO button which in my setup would display distance and bearing to a glider pilot who had just sent me his/her code. It would continue to display that information long after the other glider had moved on. So,if the other pilot sent you their code while in a strong thermal you would have a waypoint set to that thermal and know where they were at that moment. I understand that you both need to be on the same software, it seems that they use different ways to generate the code. But I am still figuring this out. Brian |
At 13:50 04 September 2009, brianDG303 wrote:
On Sep 4, 6:15=A0am, J A wrote: Can anyone answer the original question? =A0Has anyone tried this feature and how did it work? =A0I was actually curious... And how does it actually work, as in how does it communicate from one device to the other. =A0People have alluded to it transmitting over the radio, do both gliders also need to be on the same radio freq.? etc. etc. thanks, Jim At 20:56 01 September 2009, brianDG303 wrote: Flying this weekend in a new area it was difficult to keep track of where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 =A0 =A0Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes =A0 =A0 . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() I started this thread and don't entirely understand the feature yet, I'll try it this weekend. But one thing I do understand is that this is not a dynamic feature (it does not update the position) and it is not device to device. It just gives you a 4 or 5 letter code, which you transmit by radio to other pilots. They enter the code into SeeYou, (or winpilot or xcsoar, I understand they all have this feature) and your location is displayed, I think as a waypoint. After entering the code you have an option to press a GOTO button which in my setup would display distance and bearing to a glider pilot who had just sent me his/her code. It would continue to display that information long after the other glider had moved on. So,if the other pilot sent you their code while in a strong thermal you would have a waypoint set to that thermal and know where they were at that moment. I understand that you both need to be on the same software, it seems that they use different ways to generate the code. But I am still figuring this out. Brian With SeeYou Mobile, each of the team set [the same] turnpoint (or random lat/long) (Menu Next Team Setup ) . Use 'NavBoxes' to display an extra box on the screen containing a coded pseudo tp reference. Give this code (your current location, referenced from the tp you used) to the person trying to find you and they can then navigate to the position of the pseudo tp, if they have also setup their Team tp identically. You can confuse the opposition some more by adding a codeword (when setting up the tp in each of your SYMs). |
On Sep 4, 11:45*am, Peter Wyld wrote:
At 13:50 04 September 2009, brianDG303 wrote: On Sep 4, 6:15=A0am, J A *wrote: Can anyone answer the original question? =A0Has anyone tried this feature and how did it work? =A0I was actually curious... And how does it actually work, as in how does it communicate from one device to the other. =A0People have alluded to it transmitting over the radio, do both gliders also need to be on the same radio freq.? etc. etc. thanks, Jim At 20:56 01 September 2009, brianDG303 wrote: Flying this weekend in a new area it was difficult to keep track of where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 =A0 =A0Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes =A0 =A0 . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() I started this thread and don't entirely understand the feature yet, I'll try it this weekend. But one thing I do understand is that this is not a dynamic feature (it does not update the position) and it is not device to device. It just gives you a 4 or 5 letter code, which you transmit by radio to other pilots. They enter the code into SeeYou, (or winpilot or xcsoar, I understand they all have this feature) and your location is displayed, I think as a waypoint. After entering the code you have an option to press a GOTO button which in my setup would display distance and bearing to a glider pilot who had just sent me his/her code. It would continue to display that information long after the other glider had moved on. So,if *the other pilot sent you their code while in a strong thermal you would have a waypoint set to that thermal and know where they were at that moment. I understand that you both need to be on the same software, it seems that they use different ways to generate the code. But I am still figuring this out. Brian With SeeYou Mobile, each of the team set [the same] turnpoint (or random lat/long) (Menu Next * Team Setup ) . *Use 'NavBoxes' to display an extra box on the screen containing a coded pseudo tp reference. Give this code (your current location, referenced from the tp you used) to the person trying to find you and they can then navigate to the position of the pseudo tp, if they have also setup their Team tp identically. You can confuse the opposition some more by adding a codeword (when setting up the tp in each of your SYMs).- Hide quoted text - - Show quoted text - I believe this feature displays positions from a feed from a FLARM collision avoidance device not available in North America. No FLARM, no data, no picture of your team-mates. DD |
At 20:16 04 September 2009, Dan wrote:
On Sep 4, 11:45=A0am, Peter Wyld wrote: At 13:50 04 September 2009, brianDG303 wrote: On Sep 4, 6:15=3DA0am, J A =A0wrote: Can anyone answer the original question? =3DA0Has anyone tried this feature and how did it work? =3DA0I was actually curious... And how does it actually work, as in how does it communicate from one device to the other. =3DA0People have alluded to it transmitting over the radio, do both gliders also need to be on the same radio freq.? etc. etc. thanks, Jim At 20:56 01 September 2009, brianDG303 wrote: Flying this weekend in a new area it was difficult to keep track of where each other was, thought about using the team location feature in SYM. I've copied the details on how it works below. Has anyone tried this feature and how did it work? Brian 6.17 =3DA0 =3DA0Team The Team feature in SeeYou Mobile will help you find or hide your teammate. It lets you share your position with other pilots and even encrypt this information so that your competitors won't be able to decode it. To use it: .. Enable the "Team Position Code (Team)" Navbox in Menu Next Navboxes =3DA0 =3DA0 . Or use Menu Next Team from the main menu. .. Go to the map view and tap on the Team navbox. .. Team dialog opens. You need to press Setup before first use. .. Press Select to select a source waypoint for the calculation. It is imperative that your teammate does the same. .. If you would like to hide the information from others, enter the Encryption key. Again, both or all pilots have to share the same key. Go fly. When asked about your position, answer "One-Kilo-Bravo- Yankee". Your teammate will tap the Team navbox, enter the code and say "Thanks" while others won't have a clue unless they have the key ![]() I started this thread and don't entirely understand the feature yet, I'll try it this weekend. But one thing I do understand is that this is not a dynamic feature (it does not update the position) and it is not device to device. It just gives you a 4 or 5 letter code, which you transmit by radio to other pilots. They enter the code into SeeYou, (or winpilot or xcsoar, I understand they all have this feature) and your location is displayed, I think as a waypoint. After entering the code you have an option to press a GOTO button which in my setup would display distance and bearing to a glider pilot who had just sent me his/her code. It would continue to display that information long after the other glider had moved on. So,if =A0the other pilot sent you their code while in a strong thermal you would have a waypoint set to that thermal and know where they were at that moment. I understand that you both need to be on the same software, it seems that they use different ways to generate the code. But I am still figuring this out. Brian With SeeYou Mobile, each of the team set [the same] turnpoint (or random lat/long) (Menu Next =A0 Team Setup ) . =A0Use 'NavBoxes' to display= an extra box on the screen containing a coded pseudo tp reference. Give this code (your current location, referenced from the tp you used) t= o the person trying to find you and they can then navigate to the position = of the pseudo tp, if they have also setup their Team tp identically. You can confuse the opposition some more by adding a codeword (when setting up the tp in each of your SYMs).- Hide quoted text - - Show quoted text - I believe this feature displays positions from a feed from a FLARM collision avoidance device not available in North America. No FLARM, no data, no picture of your team-mates. DD The 'Team' feature does not need Flarm. It is purely a manual system (to enter the pseudo tp). Flarm however does identify each unit within the (Flarm) NMEA Datastream and this can be used by See You Mobile to show friends and others, (see page 25/26 of the SYM manual). Since you chaps on the west side of the pond don't have Flarm, it won't be of help to you, but the 'Team' feature doesn't need Flarm so will work for you. It doesn't show other gliders, but allows you to navigate to where your team mate is (or rather was!) when they pass their encoded location to you. |
code | adelsonsl | Aviation Photos | 1 | March 22nd 08 07:33 PM |
SeeYou Mobile 3 FLARM Feature and Team Flying? | [email protected] | Soaring | 10 | February 5th 08 08:28 AM |
Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 11:38 AM |
morse code | Sandra Oevering | Naval Aviation | 8 | December 30th 03 11:45 PM |
F-16 Source Code | Charles Talleyrand | Military Aviation | 40 | December 26th 03 01:40 PM |
