On Sun, 11 Jan 2004 09:55:02 -0500, Air Force Jayhawk
wrote: An aircraft is only unstable if the aerodynamic center is forward of the center of gravity. If the wing root is sufficiently aft and the AC stays aft of the CG, stability remains. Why? Well it was tried with the X-29 but I never have read why no one has pursued it since. The advantage was supposed to be that the boundary layer (the thick air right next to the surface caused by friction and very annoying) builds up as the air moves aftward along the wing. With a FSW, the thickest part of the BL is at the root rather than near the control surfaces, enhancing control while at high angles of attack. There are other advantages but it's been a while so I can't recall them off the top of my head. I knew the USAF pilot on the X-29 project...he said it flew fine and had no issues with it. As I recall the X-29 project, one of the objectives was evaluation of the instability as a means of gaining agility for future highly maneuverable aircraft. The "urban legend" was that the aircraft required minimum of triple redundant FBW augmentation as loss of the augmentation would result in immediate excursions from stable flight and structural failure within seconds. The ultimate in "JC maneuvers". Always thought it made for an extremely ugly airplane. Wasn't the basic structure from an F-16A? Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
![]() "Ed Rasimus" wrote in message ... snip As I recall the X-29 project, one of the objectives was evaluation of the instability as a means of gaining agility for future highly maneuverable aircraft. The "urban legend" was that the aircraft required minimum of triple redundant FBW augmentation as loss of the augmentation would result in immediate excursions from stable flight and structural failure within seconds. The ultimate in "JC maneuvers". Always thought it made for an extremely ugly airplane. Wasn't the basic structure from an F-16A? Ed, I believe the basic structure was from an F-5. Brooks Ed Rasimus |
![]() "Ed Rasimus" wrote in message ... On Sun, 11 Jan 2004 09:55:02 -0500, Air Force Jayhawk wrote: An aircraft is only unstable if the aerodynamic center is forward of the center of gravity. If the wing root is sufficiently aft and the AC stays aft of the CG, stability remains. Why? Well it was tried with the X-29 but I never have read why no one has pursued it since. The advantage was supposed to be that the boundary layer (the thick air right next to the surface caused by friction and very annoying) builds up as the air moves aftward along the wing. With a FSW, the thickest part of the BL is at the root rather than near the control surfaces, enhancing control while at high angles of attack. There are other advantages but it's been a while so I can't recall them off the top of my head. I knew the USAF pilot on the X-29 project...he said it flew fine and had no issues with it. As I recall the X-29 project, one of the objectives was evaluation of the instability as a means of gaining agility for future highly maneuverable aircraft. The "urban legend" was that the aircraft required minimum of triple redundant FBW augmentation as loss of the augmentation would result in immediate excursions from stable flight and structural failure within seconds. The ultimate in "JC maneuvers". Always thought it made for an extremely ugly airplane. Wasn't the basic structure from an F-16A? Here is a photo; the F-5 ancestry is evident in this view: http://www.dfrc.nasa.gov/Gallery/Pho...EC90-357-7.jpg Brooks Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
![]() "Ed Rasimus" wrote in message ... On Sun, 11 Jan 2004 09:55:02 -0500, Air Force Jayhawk wrote: An aircraft is only unstable if the aerodynamic center is forward of the center of gravity. If the wing root is sufficiently aft and the AC stays aft of the CG, stability remains. Why? Well it was tried with the X-29 but I never have read why no one has pursued it since. The advantage was supposed to be that the boundary layer (the thick air right next to the surface caused by friction and very annoying) builds up as the air moves aftward along the wing. With a FSW, the thickest part of the BL is at the root rather than near the control surfaces, enhancing control while at high angles of attack. There are other advantages but it's been a while so I can't recall them off the top of my head. I knew the USAF pilot on the X-29 project...he said it flew fine and had no issues with it. As I recall the X-29 project, one of the objectives was evaluation of the instability as a means of gaining agility for future highly maneuverable aircraft. The "urban legend" was that the aircraft required minimum of triple redundant FBW augmentation as loss of the augmentation would result in immediate excursions from stable flight and structural failure within seconds. The ultimate in "JC maneuvers". Always thought it made for an extremely ugly airplane. Wasn't the basic structure from an F-16A? Grumman modified an F-5. |
On Sun, 11 Jan 2004 18:20:34 GMT, Ed Rasimus
wrote: As I recall the X-29 project, one of the objectives was evaluation of the instability as a means of gaining agility for future highly maneuverable aircraft. The "urban legend" was that the aircraft required minimum of triple redundant FBW augmentation as loss of the augmentation would result in immediate excursions from stable flight and structural failure within seconds. The ultimate in "JC maneuvers". Well, it didn't have to have all three computers working, just one, which could have been the fourth, back-up one. But that wasn't a long-term sort of thing. However, it didn't hang around for seconds before it pitched up. stalled, and departed controlled flight. Time to double amplitude was a small fraction of a second, although I can't remember the number. It was smaller than that of the F-16, but the F-16 isn't very unstable (it's neutrally stable clean and full of fuel and could be flown, albeit rather oddly, without augmentation until enough fuel burned off, not that anyone except VISTA would try this). The X-29 was statically unstable because the project was a technology demonstrator for agile aircraft with forward-swept wings, aircraft that were stall-resistant. It wasn't statically unstable because it had a forward-swept wing. Always thought it made for an extremely ugly airplane. I thought it wasn't all that bad looking, myself. The X-31 was rather plain, but the X-29 was OK. Wasn't the basic structure from an F-16A? No, that was the X-31, I think, at least for the gear and cockpit. The X-29 used a couple of F-5s for the fuselages. I don't remember how far aft the F-5 airframe went, but it definitely included the cockpit and surrounding structure, as well as the gear, as I recall. Mary -- Mary Shafer Retired aerospace research engineer |
![]() "Mary Shafer" wrote in message ... snip However, it didn't hang around for seconds before it pitched up. stalled, and departed controlled flight. Time to double amplitude was a small fraction of a second, although I can't remember the number. It was smaller than that of the F-16, but the F-16 isn't very unstable (it's neutrally stable clean and full of fuel and could be flown, This is closer than Mary's claim that the F-16 is statically unstable, but the F-16 continues to remain 5% pitch stable. |
All rearward swept wings suffer a loss of lift to some degree because
of span-wise flow. Hence wing fences on some. Forward swept wings do not, for obvious reasons. Forward swept wings do suffer a weight penalty because the bending moments are self-generating - any twist results in a force tending to increase that twist, thus they must be considerably stronger than the alternative. IMHO aircraft designed for lower G limits would profit efficiency-wise from forward sweep. Walt BJ |
![]() "James Dandy" wrote in message m... Pardon my ignorance on all matters concerning modern aviation but just why the hell would you want to sweep a wing forward? ..........manuaverability Doesn't that make any aircraft unstable? ..........Yes If so, why would any pilot feel safe in it? ..........Computers Has anyone ever made one work? ..........Yes, several |
German forward swept wing WWII fighter projects. | Charles Gray | Military Aviation | 4 | January 11th 04 01:49 PM |
Canard planes swept wing outer VG's? | Paul Lee | Home Built | 8 | January 4th 04 08:10 PM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
