radio transmission trouble
Old October 14th 09, 05:17 AM posted to rec.aviation.soaring
SD[_2_]
Default radio transmission trouble
I am hoping someone can help with a problem I am having in
mySZD55.while thermaling some transmissions are lost as I turn.it
seems to recieve fine no matter if I am turning or not.it's an older
avionic dittle 720c.how do I diagnose if it's antenna related or just
a bad radio?
Thanks, Dennis Vreeken. aka 4Q
Old October 14th 09, 06:49 AM posted to rec.aviation.soaring
Bart[_4_]
Might it be caused by increased g-loading in a turn? Try transmitting
while pulling up. If you experience similar problems then look for a
loose connection somewhere in your radio.
Bart
Old October 14th 09, 08:05 AM posted to rec.aviation.soaring
Andy[_10_]
Bart
I found that my transmission clarity was strongly related to where my
mouth was relative to the Dittel boom mike I use - not the radio
itself. Do you use a boom mike? Does it move when you are pulling G's
in a turn?
9B
Old October 14th 09, 01:35 PM posted to rec.aviation.soaring
JJ Sinclair
Blanking can occur in a cone in line with the antenna and the elevator
push-rod. This is perceived as fading in and fading out while
thermaling. The early LS-6 had this problem and the fix was to replace
the elevator push-rod with non metal rod.
JJ
a bad radio?
Old October 14th 09, 07:21 PM posted to rec.aviation.soaring
Tim Mara[_2_]
This isn't all that uncommon, depending on the antenna type and it's
location you may blanket the "line-of-sight" transmission to some degree. I
assume you have the standard tail mounted antenna from the factory, even
with this there can be some reflection from other grounding or metal
surfaces that will limit the transmission cone.
I've seen this with antennas mounted on the belly of airplanes reflecting
off landing gears, also transmitting essentially down to the ground so
ground communications are poor, even raspy as the signal is bounced from the
antenna off the ground or gears to the antenna again.. also poor
communications to the ground from the air with top mounted antennas where
the signal air-to-air is 5x5 because of the ground plane blocking this
transmission cone.
just a thought...try it, see if the direction of the transmission is in the
way you are in relation to the other gliders in the thermals or in a
straight line to see if this isolates your issue....if it doesn't then we'll
look for other suspect problems
tim
"SD" wrote in message
a bad radio?
Old October 14th 09, 10:29 PM posted to rec.aviation.soaring
Andy[_1_]
a bad radio?
If you recieve ok with a given aircraft attitude and heading but do do
not transmit at the same attitude and heading then the law of
reciprocity rules out an antenna problem. An antenna system works
just the same for receive and transmit.
You can expect the antenna performance to change as you circle.
Whether you receive ok depends on the received signal strength and
your receiver squelch setting. Whether others hear you depends on
their received signal strength (which will vary as you circle while
transmitting) and their squelch setting. What you are experiencing
may be completely normal. Try setting squelch off or at minimum at
both receivers and see if you can detect a slowly varying signal or
sudden loss as you circle.
I don't know of any aircraft VHF tranceivers that provide an S meter
but when I built my RST years ago I brought out the AGC line so I
could do signal strength tests.
Andy
Old October 15th 09, 12:18 AM posted to rec.aviation.soaring
5SZ
a bad radio?
reciprocity rules out an antenna problem. *An antenna system works
your receiver squelch setting. *Whether *others hear you depends on
transmitting) and their squelch setting. *What you are experiencing
may be completely normal. *Try setting squelch off or at minimum at
Andy
I had a similar problem just this last month. I had a bad push to talk
switch on the control stick. Seems I had to really push hard on the
button to transmit. Replaced the switch and it now works OK. This was
in a SZD55 #096 N55SZ. Hope this helps, Paul
Old October 15th 09, 04:24 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
a bad radio?
Not sure how to recommend diagnosis, but I can relate a problem I had
last year with my Dittel radio cutting out intermittently. My problem
turned out to be caused by a broken center pin on the coax cable
carrying the antenna into the radio. It was completely detached at the
point where it was soldered to the coax center wire, but contained in
the coax connector, it would sometimes contact, and other times not.
This is the sort of fault that could be g-effected, depending on how
your antenna wiring harness is supported.
Easy enough to check.
Good luck.
Bob
Old October 15th 09, 04:43 AM posted to rec.aviation.soaring
SD[_2_]
a bad radio?
Good luck.
Bob
thank you to all that have responded, you have given me lots of things
to check!! as usual this group is always helpful. 4Q
Old October 15th 09, 07:40 AM posted to rec.aviation.soaring
Alan[_6_]
In article Andy writes:
a bad radio?
True for most VHF systems, but not true in general.
The reciprocity will provide the same ratio of received power to
transmitted power, but will not guarantee the same signal/noise in
the received signal.
This is easily seen on HF, where atmospheric noise is substantially
more than the front end noise of the radio. The poor antenna receives
the signal attenuated by (for example) 20 dB, but also attenuates the
noise by 20 dB. The resulting signal/noise ratio as heard by the radio
is pretty much the same as when heard with an excellent antenna. However,
the 20 dB attenuation on transmit with the poor antenna means that the
signal received at the other end will be 20 dB down with unattenuated
noise, so that end has a 20 dB s/n loss of receive performance.
Normally the aircraft radio will not have as much atmospheric noise,
but I have heard precipitation static and ignition noise being pretty
bad.
Alan
radio interference with transmission/reception with Solo 2625-01running Darryl Ramm Soaring 0 October 27th 08 10:03 PM
radio interference with transmission/reception with Solo 2625-01running November Bravo Soaring 0 October 26th 08 04:08 AM
radio interference with transmission/reception with Solo 2625-01running November Bravo Soaring 2 October 26th 08 03:59 AM
"scratchy" radio transmission; update [email protected] Home Built 4 January 20th 06 11:42 PM
"scratchy" radio transmission update [email protected] Home Built 0 January 8th 06 09:43 PM
