On Oct 19, 2:47*pm, John Smith wrote:
Bruno wrote: I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Considering what a trailer is meant to bear and how long it will hopefuly remain in use, I would bite the bullet, remove the top and have the welding job done by a pro without compromises. Actually most good welders can do it without too much heat. Also you can usually slip an asbestos shield with a wet rag behind the welds to minimize the heat transfer to the glass matrix. There should be no need to pull the whole top off. I have seen several and helped get one welded a few years ago. |
On Oct 19, 11:40*am, Bruno wrote:
I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 Bruno, If you decide to go with gussets, suggest roughing up the area of overlap with sandpaper, then acid etch with dilute phosphoric acid (Jabsco Metal-Prep at Home Depot or AlumiPrep) wash with water and dry. Then use Loctite Depend 330 adhesive (available from McMaster- Carr on-line) along with mechanical fasteners if you wish, though those won't really be needed using 330. 330 comes as a two part (gel and spray primer) almost instant setting acrylic adhesive (actually one minute for bond - - 24 hours full strength) that is ideal for lots of materials. It has a shear strengh of 2,500 psi IIRC and, unlike most epoxies that cure brittle, retains some elasticity so it accomodates dissimilar thermal expansion of materials and shock loads etc. Do not buy a lot more than you need, though, as it has only a 1 year shelf life - - and they mean it! I think on day 366 the stuff stops working. A little goes a long way and a medium size "kit" from MC costs about $27. bumper zz |
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) | Stealth Pilot[_2_] | Aviation Photos | 1 | March 26th 09 07:20 AM |
gas welding aid 2 - welding clamp 2.JPG (1/1) | Stealth Pilot[_2_] | Aviation Photos | 0 | March 26th 09 03:58 AM |
gas welding aid 2 - welding clamp 2.JPG (0/1) | Stealth Pilot[_2_] | Aviation Photos | 0 | March 26th 09 03:57 AM |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
Aluminum welding | Ernest Christley | Home Built | 5 | April 24th 06 11:47 AM |
