Why don't wings have dimples 2
Old October 23rd 09, 05:07 PM posted to rec.aviation.homebuilt
Harry K
Default Why don't wings have dimples 2
On Oct 23, 5:22*am, "Anyolmouse" wrote:
"Jim Logajan" wrote in message
Dancing Fingers wrote:
The thing of it is that the car they used, as I remember, also had a
very aerodynamic shape and it still helped.
Disagree - it was not "aerodynamic" on the downstream side.
Do you recall when they showed the wind tunnel and water tank tests?
Do you
recall seeing that there was an area behind the car with turbulent
air?
Well if the car had been elongated so that the body tapered off such
that
it filled that area of turbulence, then I suspect they would have
gotten
different results.
Check out the following site:
http://www.grc.nasa.gov/WWW/K-12/rocket/shaped.html
Notice that the prism has a slightly lower drag coefficient than the
flat
plate. As that web site states "Comparing the flat plate and the
prism, and
the sphere and the bullet, we see that the downstream shape can be
modified
to reduce drag."
I wonder if they would have gotten the same results by attaching a foil
to direct some of the air down from the trunk to make the turbulent area
smaller. Back in the '70s an uncle of mine attached one to the rear of
his station wagon to keep the rear window cleaner. He swore it helped
his gas mileage as well.
We have met the enemy and he is us-- Pogo
Anyolmouse- Hide quoted text -
- Show quoted text -
Yeah, in the ?50s? the 'Kamm back' was tried on several makes. Hope
that "kamm" is the correct spelling.
Harry K
Old October 23rd 09, 05:11 PM posted to rec.aviation.homebuilt
Harry K
Do you
air?
that
gotten
different results.
flat
prism, and
modified
to reduce drag."
Ooops that was not a foil, it was a 'chopped' off back. And I think
it was in the 60s.
Harry K
Old October 22nd 09, 07:57 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Dancing Fingers" wrote in message
Last night the Mythbusters put about a 2 inch layer of clay a a sedan
and drove it at 65 mph and recorded their mileage. They put dimples
in the clay, like a golf ball, and repeated the same test and got 11%
better mileage. This again begs the question why don't wings have
dimples, especially for STOL type aircrat, where you still have
laminar flow? Heck, hexagonal dimples might reflect radar better for
all I know?
For conversation
Chris
Because wings aren't shaped like golf balls or cars.
The dimples in a golf ball help reduce drag by making the boundry layer
turbulant which helps it flow just a little further around the back side
and reduce the area behind the ball where the air flow is seperated
(compared to a laminar boundry layer). Also, the dimples work only across a
limited range of Reynolds numbers (less than 3*10^5).
The airflow around a wing isn't generally seperated (except near a stall)
so it just ain't a gonna help.
I would question the results they got with the car as well, but that's just
me.
Geoff
Old October 22nd 09, 08:41 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
Delve into the aerodynamics of blunt bodies, as automotive
aerodynamics is called.
Actually, dimples on the wings might actually help in certain
conditions.
So would tapering the thickness of the skins(!).
But both of these are impractical from a manufacturing stand point.
Might check into "vortex generators" for more insight into current
approaches as to getting the boundary layer energized.
Peter Dohm
all I know?
For conversation
Chris
Something along this line has been discussed here from time to time, and we
did not all agree at that time.
However, even ignoring the possibiliyt of measuring errors in the
Mythbusters tests, an automobile does not need to produce lift in order to
operate--and may work best if all lift can be eliminated.
The most classic case of dimpling, of which I am aware, is a golf ball.
There, the dimples provide a relatively clean breakaway of the airflow--so
that, even thought the cross section of the wake appears larger, the total
energy level of the wake is reduced.
There have also been some potentially interesting experiments involving
propellers, although I have never personally seen the sort of conclusive and
complete data that a really well designed experiment should be able to
provide. For example, there was an initially interesting article in
Experimenter several years ago--but the experiment was not sufficiently well
planned, and the aircraft was not sufficiently instrumented, to provide
really conclusive findings. (Actually, changes in the relationship of
engine RPM to airspeed without accurate monitoring of manifold pressure and
fuel flow can be extremely misleading--but that is a subject for nearly
endless future threads.)
So, the bottom line is that the results of dimpled wings could be
interesting--and there has been some successful experimentation of gliders.
But seemingly small changes in the installation be better or worse, might
have a softer or more abrupt stall, etc.
Peter
Dimples On Model Aircraft Could Greatly Extend Range Bret Cahill Aviation Marketplace 26 September 24th 09 02:15 AM
Dimples On Model Aircraft Could Greatly Extend Range Bret Cahill Home Built 47 November 9th 08 10:23 PM
PC-9 with all the wings :-) Glenn[_2_] Aviation Photos 1 August 19th 07 01:52 AM
Why don't wings have dimples? Dancing Fingers Home Built 56 June 17th 06 11:54 PM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
