Ricky wrote:
A question for the physics-minded among us, or for anyone who just has the answer. I have heard the Airacobra was underpowered and that got me to thinking; Does having an engine at the middle of the fuselage (in any plane for that matter, like the XP-58) and connected by a long shaft contribute to a loss of power delivered to the propeller? In other words; would there be more power delivered the closer the engine is to the prop? Does the shaft "eat up" power in any way? I am a mechanic and pilot and fairly knowlegable about a/c physics & aerodynamics but this has me stumped. The shaft itself won't eat up power, but the various gearboxes and shaft supports required will. Every bearing has a bit of friction; every gearbox has a bit of drag. A long drive shaft, and the gearbox required to let the cannon shoot through the hub, would cost more power than the straight installation. Whether it was enough to matter, in the case of the P-39, is another thing. ISTR the P-39's problem was the lack of a turbocharger rather than overall low power... the Airacobra started losing oommmmph above 12,000 feet, and it turned out that most of the combat was higher than that. Remember, Tex Johnston won the Thompson Trophy in a P-39, and set a speed record, besides. Ron Wanttaja |
Ron Wanttaja wrote: Ricky wrote: A question for the physics-minded among us, or for anyone who just has the answer. I have heard the Airacobra was underpowered and that got me to thinking; Does having an engine at the middle of the fuselage (in any plane for that matter, like the XP-58) and connected by a long shaft contribute to a loss of power delivered to the propeller? In other words; would there be more power delivered the closer the engine is to the prop? Does the shaft "eat up" power in any way? I am a mechanic and pilot and fairly knowlegable about a/c physics & aerodynamics but this has me stumped. [snip] Whether it was enough to matter, in the case of the P-39, is another thing. ISTR the P-39's problem was the lack of a turbocharger rather than overall low power... the Airacobra started losing oommmmph above 12,000 feet, and it turned out that most of the combat was higher than that. Combat in the ETO tended to be higher than other theaters, which, since the USAAC pulled the turbocharger from the P-39, hamstrung it in that arena. The Airacobra was also a small aircraft, with limited fuel, as it was designed as a point defense fighter, and lack of range hurt it, too. That said, the Russians liked it pretty well, since air combat on the eastern front tended to remain below 15,000', and it performed well down there against the Luftwaffe. (In spite of the 37mm cannon, the P-39 was used much more in the anti-air role, and not against German armor; the Il-2 was much better down in the mud.) The P-39/P-400 didn't exactly shine, not that it embarrassed itself, in the Pacific, partly due to the long distances that were common there. |
Ricky wrote:
A question for the physics-minded among us, or for anyone who just has the answer. I have heard the Airacobra was underpowered and that got me to thinking; Does having an engine at the middle of the fuselage (in any plane for that matter, like the XP-58) and connected by a long shaft contribute to a loss of power delivered to the propeller? In other words; would there be more power delivered the closer the engine is to the prop? Does the shaft "eat up" power in any way? I am a mechanic and pilot and fairly knowlegable about a/c physics & aerodynamics but this has me stumped. Thanks in advance for your ponderings and/or solution! Ricky It's a question often asked in connection with long shafts. The elastic angular compliance can be a positive help with vibrations, which are absorbed by a quill shaft. But a shaft drive train that's curved takes pillow blocks to support the curve, and these bearings take some (small) power on their own account. Otherwise, air drag, and bearing drag apart, there's no loss in a long quill shaft. Brian W |
On Nov 3, 8:51*pm, brian whatcott wrote:
Ricky wrote: A question for the physics-minded among us, or for anyone who just has the answer. I have heard the Airacobra was underpowered and that got me to thinking; Does having an engine at the middle of the fuselage (in any plane for that matter, like the XP-58) and connected by a long shaft contribute to a loss of power delivered to the propeller? In other words; would there be more power delivered the closer the engine is to the prop? Does the shaft "eat up" power in any way? I am a mechanic and pilot and fairly knowlegable about a/c physics & aerodynamics but this has me stumped. Thanks in advance for your ponderings and/or solution! Ricky It's a question often asked in connection with long shafts. The elastic angular compliance can be a positive help with vibrations, which are absorbed by a quill shaft. But a shaft drive train that's curved takes pillow blocks to support the curve, and these bearings take some (small) power on their own account. Otherwise, air drag, and bearing drag apart, there's no loss in a long quill shaft. Brian W I had a ME design a centrifuge application with the shaft running well above its critical speed a bunch of years ago, but don't remember the tradeoffs that led me to accept that embodiment. It was not an aviation application in any event. I did find the observation about wind profiles around a pusher imposing design constraints -- I'd have thought that far aft winds in the disk would be fairly uniform except at high angles of attack. Have you a sense of the improvement of thrust, if any, a given engine might have wing mounted vs nose mounted? There's less to blow against but the wind does extend to well past the prop disk so some of that air near the outside diameter is compromised by the wing. I'm thinking of an application where one wants the maximum endurance at fairly low speeds. That around the world airplane that came out of Scaled Composites might hold the answer. |
On Nov 3, 9:52*pm, a wrote:
On Nov 3, 8:51*pm, brian whatcott wrote: Ricky wrote: A question for the physics-minded among us, or for anyone who just has the answer. I have heard the Airacobra was underpowered and that got me to thinking; Does having an engine at the middle of the fuselage (in any plane for that matter, like the XP-58) and connected by a long shaft contribute to a loss of power delivered to the propeller? In other words; would there be more power delivered the closer the engine is to the prop? Does the shaft "eat up" power in any way? I am a mechanic and pilot and fairly knowlegable about a/c physics & aerodynamics but this has me stumped. Thanks in advance for your ponderings and/or solution! Ricky It's a question often asked in connection with long shafts. The elastic angular compliance can be a positive help with vibrations, which are absorbed by a quill shaft. But a shaft drive train that's curved takes pillow blocks to support the curve, and these bearings take some (small) power on their own account. Otherwise, air drag, and bearing drag apart, there's no loss in a long quill shaft. Brian W I had a ME design a centrifuge application with the shaft running well above its critical speed a bunch of years ago, but don't remember the tradeoffs that led me to accept that embodiment. *It was not an aviation application in any event. I did find the observation about wind profiles around a pusher imposing design constraints -- I'd have thought that far aft winds in the disk would be fairly uniform except at high angles of attack. Have you a sense of the improvement of thrust, if any, *a given engine might have wing mounted vs nose mounted? There's less to blow against but the wind does extend to well past the prop disk so some of that air near the outside diameter is compromised by the wing. I'm thinking of an application where one wants the maximum endurance at fairly low speeds. That around the world airplane that came out of Scaled Composites might hold the answer. Opps, not built by scaled composites after all. Interesting that the rear engine was the one that ran all of the time, so that was the more efficient location (but what does Rutan know?). |
US 269021 P63 Kingcobra 20070927 Columbus OH | Graham Harrison[_2_] | Aviation Photos | 0 | August 14th 08 06:27 PM |
Engine power question??? | [email protected] | Home Built | 24 | October 13th 07 02:40 AM |
Ship's Power (or portable GPS) Question | Kyle Boatright | Home Built | 9 | May 29th 07 03:17 PM |
O-360 takeoff power fuel flow question | argon39 | Owning | 13 | August 2nd 05 05:23 PM |
