Alan Baker wrote:
In article , brian whatcott wrote: Alan Baker wrote: In article , brian whatcott wrote: Alan Baker wrote: Interesting comment: what would YOU call it when the fabric on the upper wing surface wants to pull away from the ribs? Air pressure from inside the wing pushing up on it more than the air above is pushing down... Let me take a wild guess he you did physics for an uundergraduate degree. Is that right? Brian W No. But it doesn't matter. If the fabric is moving upward, it can only be because there is more pressure on its bottom surface than there is on its top surface. It seems that you are uncomfortable with the entire concept of suction. For example, how do you suppose suction cups work? The pressure outside the cup keeps it in place. Or how about a suction pump that happens to be limited to a 30 ft lift? Because a vacuum cannot do any actual pulling, you can only lift water as far as the pressure allows, right. Well duh, it's also atmospheric pressure that enables suction pumps and suction cups etc., etc. Yes indeed , but it's an academic issue at the junior high level, isn't it? Yup. OK you certainly cut the cookie at Junior High. Now can we go back to using terms like suction the way 99.99% of the technical and scientific population understands it? :-) Brian W |
brian whatcott wrote: Alan Baker wrote: In article , brian whatcott wrote: Alan Baker wrote: In article , brian whatcott wrote: Alan Baker wrote: Interesting comment: what would YOU call it when the fabric on the upper wing surface wants to pull away from the ribs? Air pressure from inside the wing pushing up on it more than the air above is pushing down... Let me take a wild guess he you did physics for an uundergraduate degree. Is that right? Brian W No. But it doesn't matter. If the fabric is moving upward, it can only be because there is more pressure on its bottom surface than there is on its top surface. It seems that you are uncomfortable with the entire concept of suction. For example, how do you suppose suction cups work? The pressure outside the cup keeps it in place. Or how about a suction pump that happens to be limited to a 30 ft lift? Because a vacuum cannot do any actual pulling, you can only lift water as far as the pressure allows, right. Well duh, it's also atmospheric pressure that enables suction pumps and suction cups etc., etc. Yes indeed , but it's an academic issue at the junior high level, isn't it? Yup. OK you certainly cut the cookie at Junior High. Now can we go back to using terms like suction the way 99.99% of the technical and scientific population understands it? :-) Brian W No one understands "suction" to actually mean a pulling force. Not since they tried to pump water out of mines and discovered that they could only "pull" it a certain number of feet, but no further. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Alan Baker wrote:
No one understands "suction" to actually mean a pulling force. Remember folks: no more talk of sucking soda through a straw! Just suck it up! Brian W :-) |
Pressure Distribution Charts | sisu1a | Soaring | 0 | September 21st 08 05:53 PM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
Alternator load distribution in a Baron | Viperdoc | Owning | 7 | December 9th 03 10:27 PM |
